Rengroulx Samba Member
Posted: Wed Mar 25, 2020 12:19 pm Post subject: Custom Exhaust Thoughts |
Just looking for thoughts and opinions! Should I refurbish this exhaust system or invest in a new one. I haven't found anything like it online... Must be custom made.
Running a Stock 1600 DP with Kardons.
Cheers,
[/img]
**UPDATE**
These are Doug Thorley Bug Pipes.. Thunderbird did make similar style headers
Credit to spencerfvee and SBD
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Mar 25, 2020 12:29 pm Post subject: Re: Custom Exhaust Thoughts |
The exhaust is just an old dual system. The bolt on tips are home made. That exhaust system came with two bolt on glass pack mufflers when new. You would actually get a tiny bit more performance buying a new cheap 4-into-1 header. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed Mar 25, 2020 12:37 pm Post subject: Re: Custom Exhaust Thoughts |
Hi vwracerdave, thanks for the info!
I'd be curious to see what the original exhaust with the glass packs looks like...
Considering merged vs Dual Cannons |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Mar 25, 2020 12:50 pm Post subject: Re: Custom Exhaust Thoughts |
Generator needs to be rotated 90* clockwise. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 25, 2020 1:45 pm Post subject: Re: Custom Exhaust Thoughts |
Noted! Thanks Glenn |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Mar 25, 2020 8:21 pm Post subject: Re: Custom Exhaust Thoughts |
Rengroulx wrote: |
I found this picture. At least one manufacturer was Thunderbird. They were available in all chrome or black with chrome mufflers. They were loud. And they got LOUDER as they wore out!
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Thu Mar 26, 2020 3:38 am Post subject: Re: Custom Exhaust Thoughts |
Dual cannons and Kadrons is about as bad as you can get for poor idle and low rpm drivability. Some people can live with it, I couldn't even though I was determined to retain the classic dual cannon look.
What you have now is better than dual cannons but I would expect an improvement with a 4 into 1 system.
How comfortable are you with building your own system? |
spencerfvee Samba Member
Posted: Thu Mar 26, 2020 3:48 am Post subject: Re: Custom Exhaust Thoughts |
Rengroulx wrote: |
Cheers,
[/img] ........................................................................................................................
.that's a 1970s doug Thorley header not a cheap repo spencerfvee |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Thu Mar 26, 2020 4:34 am Post subject: Re: Custom Exhaust Thoughts |
I like the custom shroud plug on the left... _________________ '63 Ragtop |
EVfun Samba Member
Posted: Thu Mar 26, 2020 12:08 pm Post subject: Re: Custom Exhaust Thoughts |
oprn wrote: |
I would be curious how this system works with the Kadrons. I agree, Kadrons and dune buggy duals are crabby at lower rpms and the idle is mostly 2 cylinders and unburnt fuel. But this exhaust system is exactly the opposite of old school duals. The regular way both the intake and exhaust hit the rear cylinder, then front cylinder, then a long pause to hit the other side before repeating. Number 4 if filling when #3 is on exhaust. With this dual setup the intake still hits rear then front then pause, but the exhaust hits the rear cylinders second. When both 3 of 4 are filling the other cylinder is not on its exhaust stroke into a common collector. I wonder if that would reduce the idle problems? _________________
Wildthings wrote: |
Posted: Thu Mar 26, 2020 1:42 pm Post subject: Re: Custom Exhaust Thoughts |
@SBD oh I beleive you! these pipe are LOUD.. Thanks for the pic, looks neat
@oprn I didn't know Dual cannons and Kadrons were a poor combo... Might actually clean these up and send it to a chrome shop, I don't have the pipe bending equipment to fabricate a system. What did you have in mind?
@spencerfvee Thanks!! That ad looks awesome, couldn't find a pic of this system anywhere
@Mark Evans ahaha never really noticed.. I took this shroud off, I'm installing a complete chrome dress up kit, However I will keep that shroud for another project. Thanks!
@EVfun The pic I posted was actually the first time I ever started that engine! I did a compression test, rebuild the carbs, tuned up the ignition system, changed the oil and hoped for the best... It fired up and idled very good, I was very suprised. I will upload a video if I can figure it out |
oprn Samba Member
Posted: Thu Mar 26, 2020 4:28 pm Post subject: Re: Custom Exhaust Thoughts |
On my system I paired the cylinders properly to get even exhaust pulses. That means pairing the 2 front cylinders together and the back 2 cylinders together. It's awkward to do and that is why it's not done commercially. I bought "U" bends and straight pipe, cut them up, pieced it together and welded it up. I am very happy with the results. The engine is very smooth with lots of bottom end torque. It has quite a unique sound too.
I must warn you though that it will not be cheaper than buying a complete type 1 system. In my case there were very few "store bought" options because it is a type 4 engine so the decision made more sense. It took me about 2 weeks of spare after work time to build.
Actually I am not that surprised that your system idles reasonably well. This I believe is due to the tubes being a lot longer than typical dual cannons. The front 2 cylinders are the ones that don't want to idle on conventional cannons and they are the shortest pipes.
Your system is unique and I don't blame you for wanting to save it!
Posted: Thu Mar 26, 2020 5:47 pm Post subject: Re: Custom Exhaust Thoughts |
@oprn your exhaust system looks great! Ive never seen anything like it, bending everything to fit mustve been a chore and a half 😅.. You dont see many with type 4 engines on buggys!
Thanks for the info! Im set on restoring these bug pipes.
Any suggestion to modify this header (add glasspacks, merge it together, buy a muffler) etc.
Cheers! |
Posted: Thu Mar 26, 2020 5:54 pm Post subject: Re: Custom Exhaust Thoughts |
Rengroulx wrote: |
..years ago .we used these on are first race car . running dual straight pipes 11:1 cr big cam dual dcnf 40 weber carbs they would wake the dead up lol on the starting line they sounded like a old gasser we only ran 14s in the 1/4 mile back then. we thought we were bad ass in those days lol those were the fun days nice to see that a set is still around . spencerfvee |
oprn Samba Member
Posted: Fri Mar 27, 2020 3:59 am Post subject: Re: Custom Exhaust Thoughts |
If it were mine I would try a pair of glass packs. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Fri Mar 27, 2020 5:25 am Post subject: Re: Custom Exhaust Thoughts |
He has the basis for a tri-y header there but I don't know if the cyl pairing is correct. Also the primary lengths are probably way longer than desired. Still, it would be fun to fab up a 2 into 1 to bolt to those flanges and see what sort of power, driveablity and ex note you ended up with.
Or 2 u-bends to 2 mufflers but with an 'H' pipe connecting the 2 sides. |
Posted: Fri Mar 27, 2020 8:00 am Post subject: Re: Custom Exhaust Thoughts |
@spencerfvee That's an awesome story! The good ol' days indeed, I've never herd pipes loud like these. The slightest throttle snap will blow anyone away lol.. Sounds a lot bigger than a 1600 haha
@oprn would you bolt on galsspacks on the ends going 90* both ways or include it in the J-tube somehow ?
@rayjay Agreed! I'll design something.. Maybe I'll find a pipe I could easily modify to fit, all part of the fun!
Cheers Gents! |
oprn Samba Member
Posted: Sat Mar 28, 2020 6:00 am Post subject: Re: Custom Exhaust Thoughts |
Personally I would do as rayjay suggested, 90s and glass packs. The balance tube between them is a very interesting idea though and without a doubt would change the sound.
Yes I was thinking seriously about a tri Y when I built this system but stuck with duals for nostalgic reasons. I could still... some day...
It's pretty much impossible to get the primaries as short as recommended on an opposed engine without doing it directly under the engine case. That leads to serious ground clearance issues. Longer primaries just tunes it to a lower rpm so for me it's not an issue, lots of grunt off the start.
As for pairing, this is the only way they can be paired properly to get alternate firing cylinders paired together. It seems some of the Jap performance cars do not pair them like this but they are ultra high reving engines with little to no torque at the bottom end. That fits with my observations with the dual cannons vs 4 into 1 systems. I found no real discernible difference between the two on power and drivability on the highway but around town the dual cannons sucked! |
EVfun Samba Member
Posted: Sat Mar 28, 2020 10:19 am Post subject: Re: Custom Exhaust Thoughts |
I used to run the short tube dune buggy duals, the kind with no heater box or j-tube and short little glass packs (with the glass blown out.) One of my amusements was to smack the throttle while coasting in a parking lot. I could often set off multiple car alarms it was so loud. I always lightened up on the throttle a little extra when a cop was in sight. _________________
Wildthings wrote: |
oprn Samba Member
Posted: Sat Mar 28, 2020 11:55 am Post subject: Re: Custom Exhaust Thoughts |
As much as I do enjoy the "pair of badly tuned Harleys" sound that you get from cannons the first 3 hour day trip I did with mine left my ears ringing for the evening! What I have now has a definite throaty bark when on the load peddle hard but at cruise you cannot hear the exhaust over the wind noise. |
