airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Tue Apr 07, 2020 6:46 pm Post subject: Re: Ball joint comparison: Meyle, Lemförder, Moog, SKF and Heyd |
busdaddy wrote: |
asiab3 wrote: |
with the spindle removed.) |
But if the joint gets moved from it's operating position the play may change. They would be better measured with everything in place while prying between the arms and spindle. |
Are you saying the angle of joint operation will give a different reading? I have the SGKent-Donated Ball Joint Checker tool, (Bentley "Special Tool,") and it gives about the same reading as a joint without the spindle.
Anyone doing joints or boots at home probably has calipers to do this…
I personally think that most people replace joints before they have to, or replace joints that only need boots and a bit of fresh grease. But who would want to go through the work of removing the spindle just to replace a $10 boot, when they can spend $300 to make their car drive worse……
www.airschooled.com |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Tue Apr 07, 2020 7:30 pm Post subject: Re: Ball joint comparison: Meyle, Lemförder, Moog, SKF and Heyd |
asiab3 wrote: |
Robbie |
Is this true for tie rods as well? or is that wear more on the lateral or horizontal? _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Tue Apr 07, 2020 9:07 pm Post subject: Re: Ball joint comparison: Meyle, Lemförder, Moog, SKF and Heyd |
Ok, I'm going off-book here…
If you can feel play in your tie rod ends, replace the tie rod end. If not, make sure the boot is good.
And drive on.
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 462 Location: France
Posted: Wed Apr 08, 2020 6:32 am Post subject: Re: Ball joint comparison: Meyle, Lemförder, Moog, SKF and Heyd |
Cool little made in 🇩🇪 tool designed for the vanagon, but will also do bay windows and a lot of others air cooled Vw's |
Chrisbezui Samba Member
Joined: October 13, 2020 Posts: 8 Location: South Africa
Posted: Wed Apr 14, 2021 8:21 am Post subject: Re: Ball joint comparison: Meyle, Lemförder, Moog, SKF and Heyd |
I've heard that the T3's lower ball joint fits the T2 lower and upper. Is this correct and would anyone recommend this?
Perhaps these are better quality than the currently available T2 ball joints.
If so, I would also wonder how these would be installed, as they do not have the same notches to assist with alignment. |
John Pedersen 1 Samba Member
