jetmech Samba Member
Joined: October 24, 2019 Posts: 135 Location: Hamilton ON, Canada
Posted: Sat Mar 28, 2020 1:22 pm Post subject: broken bolt and broken extractor any help? |
So I was removing the cover to the rear torsion bar and the bottom front bolt snapped off, I figured it would be no problem I've removed broken bolts before. So I filed the bolt flat used a center punch and drilled a small hole and stepped it up to a 7/32 hole, I heated the area around the broken bolt and inserted my bolt extractor and as I was turning the extractor it snapped flush with the broken bolt. Now what do I do, the extractor is made of a very hard steel so trying to drilling into it is next to impossible. _________________ 74' Super Beetle |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Sat Mar 28, 2020 1:52 pm Post subject: Re: broken bolt and broken extractor any help? |
If you can borrow a MIG welder you could try this....
_________________ AshMan40
Starbucket Samba Member
Posted: Sat Mar 28, 2020 2:05 pm Post subject: Re: broken bolt and broken extractor any help? |
If you have a small cold chisel and some safety glasses you could chip it out. If you tried to extract it while it was hot THAT is probably caused the easyout to break it needs to be cold so it's not expanded in the threads. If you can drill it after you get the broken pc. out keep drilling until you are almost touching the female threads then put a torch (acc/ox or propane) and heat it and it may curl inward to itself. |
modok Samba Member
goober Samba Member
Posted: Sun Mar 29, 2020 9:47 pm Post subject: Re: broken bolt and broken extractor any help? |
I'd probably try a small die grinder/Dremel with small stones and/or small pointed carbide cutters. I'd work around the broken extractor, add a little light oil, heat up, tap with a small pin punch, repeat until I removed the broken extractor.
When I had the broken extractor out of the way, I go down the hole enlarging it until I could tap/pick the broken bolt fragment out. It may take a while. |
Posted: Mon Mar 30, 2020 3:16 am Post subject: Re: broken bolt and broken extractor any help? |
So I did try the suggestion of welding a nut onto the broken bolt, with no success. It could have been my inexperience on welding since I only bought the welder around Christmas, I will be looking into the grinding option I do have access to many different carbide tip grinding bits from work. If the grinding option works I think I will end up enlarging the hole and then inserting a steel plug then re drilling and tapping the hole for a new bolt. _________________ 74' Super Beetle |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Mon Mar 30, 2020 4:29 am Post subject: Re: broken bolt and broken extractor any help? |
I would try using a 1/8" carbide ball end mill in a Dremel to get a hole thru the center.Then maybe you can get a drill bit in there trying not to cut bigger than the minor diameter of the thread.
A left hand drill bit may remove whats left of the bolt. _________________ '72 Beetle |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Mar 30, 2020 4:59 am Post subject: Re: broken bolt and broken extractor any help? |
I don't remember, but are those threaded holes open both sides? Maybe you could punch from the other side? |
Posted: Mon Mar 30, 2020 5:27 am Post subject: Re: broken bolt and broken extractor any help? |
It is open on both sides and I did try drilling it out, but once it hit the extractor the drill would not drill any more. I tried using a punch after drilling it but I had tried the welded nut on the other side first so my guess is that the extractor is welded in place so punching it out is no use. I just picked up a few different types of carbide bits, so when I get home today I'll give them a shot. Fingers crossed. _________________ 74' Super Beetle |
Posted: Mon Mar 30, 2020 7:29 am Post subject: Re: broken bolt and broken extractor any help? |
Call your local machine shops and see if one has an E.D.M. machine, It will burn the stud and extractor out in no time. |
Posted: Mon Mar 30, 2020 9:27 am Post subject: Re: broken bolt and broken extractor any help? |
I thought of an EDM machine but I don't think they could fit the entire car on the machine. After all it is the torsion tube flange, that is part of the main frame, that the entire car is attached to. I did not see any portable EDM machines on the market. But thank you for the suggestion it would definitely do the job. _________________ 74' Super Beetle |
green1303 Samba Member
Joined: February 04, 2014 Posts: 748 Location: Alexandria, VA
Posted: Mon Mar 30, 2020 11:54 am Post subject: Re: broken bolt and broken extractor any help? |
I broke two of those bolts on a spring plate cover and had the same problem with one of them. You may be able to drill into the bolt from the back side and punch out what’s left of the extractor. Others have mentioned Dremel grinding, which I did very memorably and with a lot of swearing.
Definitely replace the bolts.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113598200 _________________ 1973 green Super Beetle |
Posted: Mon Mar 30, 2020 1:23 pm Post subject: Re: broken bolt and broken extractor any help? |
So I got home from work today with carbide bits in hand, I used my angle grinder to flatten the bolt/extractor flush with the flange, I then used my Dremel with the very small round bit to start grinding into the extractor and it was going though it like butter (very happy to see that happening) I then decided to try tapping the extractor from the other side and what do you know, it finally popped out. So I drilled out the remainder of the bolt, now I need to place a steel plug in the hole and redrill and tap for a new bolt.
Thanks for all of the suggestions and comments, they were very helpful. _________________ 74' Super Beetle |
Posted: Mon Mar 30, 2020 2:30 pm Post subject: Re: broken bolt and broken extractor any help? |
Rather than inserting a solid steel plug, why not try one of these thread repair options?
https://dsportmag.com/the-tech/three-ways-to-fix-damaged-threads/
The bolts themselves are only torqued to 25lb-ft so they are not high stress. _________________ AshMan40
graz126 Samba Member
Joined: January 16, 2020 Posts: 49 Location: Doncaster England
Posted: Mon Mar 30, 2020 3:21 pm Post subject: Re: broken bolt and broken extractor any help? |
I also snapped a bolt in the same place. Gonna try drilling it out tomorrow. 😕 |
Posted: Mon Mar 30, 2020 3:24 pm Post subject: Re: broken bolt and broken extractor any help? |
I agree with Ashman.
The plug you made has nothing to hang on to. _________________ '72 Beetle |
modok Samba Member
Posted: Tue Mar 31, 2020 12:56 am Post subject: Re: broken bolt and broken extractor any help? |
I believe by "plug" he means threaded. Like a pipe plug. |
Posted: Tue Mar 31, 2020 3:49 am Post subject: Re: broken bolt and broken extractor any help? |
I was thinking of a solid plug but after reviewing it more I did not open up the hole too much so I could use a helicoil insert. I hope that I don't have the same problem on the other side but with my luck and given the age of the car it will most likely happen again, as least this time I will have a plan and the tools to fix it quicker. _________________ 74' Super Beetle |
