ghiafreek Samba Member
Joined: December 19, 2002 Posts: 937 Location: San Antonio, Tx
Posted: Sat Mar 28, 2020 2:26 pm Post subject: rotisserie design |
Anyone have a design for a pan rotisserie?
Have a '65 squareback that needs it.
thanks. |
OKType3Tim Samba Member
Joined: April 30, 2011 Posts: 279 Location: Northeast Oklahoma
Posted: Sun Mar 29, 2020 8:34 am Post subject: Re: rotisserie design |
Not a plan, but an example. Made from two harbor freight low end engine stands. Extend the height of the stands. Used a long square tube to connect the stand together from the bottom (not show in pictures. Fabbricated brackets for each end.
_________________ '69 Squareback restoration
'69 Fastback restoration
'66 Type34 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Sun Mar 29, 2020 8:41 am Post subject: Re: rotisserie design |
That'll work. Keep in mind with those things that you want a center to outside measurement (widest point), plus a couple of inches to set the height at the ends. I only say that, because if you get it off, it'll only flip most of the way over and stop (crash into the tie bar along the bottom). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Mar 29, 2020 12:13 pm Post subject: Re: rotisserie design |
Perfect! Much appreciated. |
Posted: Mon Mar 30, 2020 8:58 am Post subject: Re: rotisserie design |
Also note: that when I welded in the height extension, I made sure that the tube at the top was positioned "level". The low cost engine stands have them cocked slightly up hill. _________________ '69 Squareback restoration
'66 Type34 |
Posted: Mon Mar 30, 2020 12:45 pm Post subject: Re: rotisserie design |
OKType3Tim wrote: |
Also note: that when I welded in the height extension, I made sure that the tube at the top was positioned "level". The low cost engine stands have them cocked slightly up hill. |
Yup, when I built the one I used on the Trans Am I'm working on, I worked off the centers of both ends and in my case the centers of the body. A buddy of mine thought I was crazy double and triple checking my measurements, but in the end, it worked just fine (I had 2 inches to spare), and would do a full roll over. In fact, my biggest concern actually was clearing my roof supports (rafters), as I have 7 foot ceilings in my garage. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
