fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Sun Mar 29, 2020 1:31 pm Post subject: my 2332 which engine case - White Rhino or TF-1? |
In 3 weeks I'll be ordering my engine case for the 2332. I was going to go with the CB Super case, but a lot of folks recommend I get one of their aluminum (White Rhino) cases for the strength it provides.
That said, I'm torn between the White Rhino and a TF-1. I've not heard anything but praise for the TF-1, but wanted to ask before I pay that chunk of change! If I go with the TF-1, I'll be running 10mm head studs w/ no case savers instead of the 8mm studs (w/ case savers) I would option the CB White Rhino with.
Should I go with the CB aluminum case or the TF-1?
parts collected for my 2332 to date:
Super Pro 45 x 37.5 heads w/ 52cc chambers, 650 springs and Ti retainers
CB 1.4 rockers
CB 84mm 4340 Chevy crank
CB Lightened 4340 chromoly flywheel
CB h-beam 4340 5.5 rods (for now)
Mahle 94mm P&Cs
CB 1 3/4 merged exhaust
Spanish 48 IDAs
Spanish 48 IDFs |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sun Mar 29, 2020 1:33 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
A factory Mag case would work great for your 2332. If you insist on an aluminum case then get the CB case. The TF-1 is overkill. 8mm head studs fine for your engine, no need for 10mm. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Sun Mar 29, 2020 2:09 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
vwracerdave wrote: |
A factory Mag case would work great for your 2332. If you insist on an aluminum case then get the CB case. The TF-1 is overkill. 8mm head studs fine for your engine, no need for 10mm. |
Thanks - I have a nagging suspicion the TF-1 is overkill, but it also sounds like it will last for quite a while and is basically bullet-proof.
You have made some good arguments for being practical with the case I choose. I'll give consideration to what you mentioned - appreciate it! |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
ditchbuggy Samba Member
Joined: January 13, 2016 Posts: 37 Location: perry ga.
Posted: Sun Mar 29, 2020 2:52 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
sounds like the same engine i'm collecting parts for as well
what are your thoughts on a camshaft? |
RickS Samba Member
Posted: Sun Mar 29, 2020 3:46 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
What is the current price and availability on a TF-1 case? |
Posted: Sun Mar 29, 2020 3:57 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
Thanks Guys.
For my cam I'm planning on the FK46 called for in the proven 200+ hp engine build thread created by the late Mark Herbert (rip sir) :
https://www.thesamba.com/vw/forum/viewtopic.php?t=106877
Todd is working up an exact shipping quote, but the block is 1450.00 + 165.00 for the .100" drop cam gear (case lowers cam by this much to allow for drop in fitment of even an 86mm crank!) + a ballpark for shipping to the east coast of 110.00. He said right now he can ship as soon as a day or two.
I am entertaining getting this case to "buy once, cry once" and hopefully never need to buy another case, at least for this big engine. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Mar 29, 2020 5:44 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
I would go for the TF-1. I wish I did and my engine is much smaller
The extra $600 is worth it if you have cash |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sun Mar 29, 2020 5:47 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
Buy the TF-1. The only disadvantage is the cost and added weight. It’s stronger in just about every way imaginable. The cam gears are expensive, but your also buying the best (CEs). _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
jason Samba Member
Posted: Sun Mar 29, 2020 7:00 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
I also read it’s a good idea to have the heads machined at the pushrod tube holes. The dropped cam changes the p tube angle and leaks easier. |
slalombuggy Samba Member
Posted: Sun Mar 29, 2020 8:24 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
I don't think you would gain anything by using the TF1 case for your combination. Built right a cb case will have the same lifespan, built wrong neither of them are bulletproof. It's all in the build. I know guys who can break a crowbar in a sandbox. Use 8mm studs like Dave said, you'll thank him when your putting it together. |
Posted: Sun Mar 29, 2020 8:25 pm Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
With a 84mm crank there is no reason you need a .100" drop cam.
My suggestion for a 200 HP engine the CB case will be plenty strong enough and last just as long. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Mar 30, 2020 4:48 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
Either way you go make sure the lifter bores are bushed with that cam _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Mar 30, 2020 5:21 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
Aluminum case won't need the lifter bores bushed. They are pretty tough as cast.
TF-1 has a .100" dropped cam for big stroke cranks.
No need for all that.
I would highly recommend the Aluminum Autolina case.
They are really tough. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Mon Mar 30, 2020 5:48 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
I’m building on a TF-1 right now.
No disappointments here.
What a beautifully designed and manufactured part.😀😀
_________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Posted: Mon Mar 30, 2020 6:07 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
slalombuggy wrote: |
Thanks Brad, I respect yours and Daves (and everyone else's!) opinions. I have to balance my desire to have the best parts with the amount of time its going to take me to get my engine running, and the CB case is definitely nice enough. |
Posted: Mon Mar 30, 2020 6:11 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
My suggestion for a 200 HP engine the CB case will be plenty strong enough and last just as long. |
Good point. This is overkill for my 84 stroke crank. The TF-1 will allow an 86mm crank to drop right in. I think the CB case will too. |
Posted: Mon Mar 30, 2020 6:13 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
jbbugs wrote: |
That is a beautiful engine you have there! In the photo is that the special cam gear that cam with the case? Are you using T-4 mains?
Thanks for the feedback. |
Posted: Mon Mar 30, 2020 6:14 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
jason wrote: |
Thanks Jason, I wasn't aware of this! |
Posted: Mon Mar 30, 2020 6:19 am Post subject: Re: my 2332 which engine case - White Rhino or TF-1? |
Looks like too the TF-1 comes with a couple of oiling mods:
1) a provision to run the Hoover mod if desired
2) a hole is drilled near the #3 exhaust lifter bore to route over pressurized oil back to the very bottom of the sump ready to be picked up and used again by the oil pump |
