tjet Samba Member
Posted: Sun Mar 29, 2020 1:51 pm Post subject: Transaxle temperature sender - where to mount? |
I'm considering installing trans temp gauge to my Syncro trans.
Where do you install the sending unit / sensor?
Thanks |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Sun Mar 29, 2020 2:24 pm Post subject: Re: Transaxle temperature sender - where to mount? |
Without drilling and tapping the case you are somewhat limited. Ideally it would be in the actual fluid, so the obvious place would be the drain plug. You’d loose the magnet feature and that is a low point, so sensor wire might get hooked. Next option would be the fill plug. It’s above the fluid level, but going down the road, would have splash. Problem is at some point it might be reading case temp, not fluid temp. Can’t point to a place on the case that would be ideal if you were drilling and tapping. There’s a really good thread where member “Gears” goes through the ultimate Syncro build. _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Sun Mar 29, 2020 2:47 pm Post subject: Re: Transaxle temperature sender - where to mount? |
MarkWard wrote: |
Without drilling and tapping the case you are somewhat limited. |
Yes and ecumbering either fill or drain plug adds trouble.
Don't choose a location that creates an impediment to clean lubricant.
(if you're capable to drill/tap properly)
I would not think even one second about the few soft magnesium bits that could escape if you pressurize the case while drilling and tapping. Magnesium is a very soft metal, and almost everyone is getting 150,000 miles driving around with with hardened steel throughout their trans lubricant.
Magnesium is almost a cushion in comparison to steel.
The hardest thing about it is convincing other people that tiny bits of magnesium can't possibly matter.
You know how they suggest, for confidence in public speaking, imagine that your audience is naked?
Imagine them telling YOU that magnesium is bad, yet driving with steel in the lubricant for 30,000 miles is "OK".
From this perspective, you can easily conclude that they are nuts (not you)..
A pretty good location is on the flat area (by the serial number).
The sensor is over on the left side of the pic.
I don't know whose pic this is.
The big brass unit is a thermoswitch (Weddle).
It's cheap but non-statisfying due to wild inaccuracy.
I do NOT prefer them.
You have to make a HUGE hole in your case.
And I had a run-in with the mfr (Nason) that was rather distasteful and Weddle didn't respond very favorably either.
But we're not talking about that thermoswitch.
There's plenty of space behind both of those locations, at least an inch, maybe towards 2 inches.
Pic from thasty07 thread: Syncro Transaxle temp sensor
There's something to be said for tapping it to 1/4NPT.
Then use a brass adapter 1/4NPT to 1/8NPT that you screw/glue in "once".
So your 'working thread' is then 'renewable'.
Also you can change it to 1/8-27NPT USA or 1/8-28 Metric if you have to.
And you can use a 1/4NPT sensor too. _________________
....KTMs, GasGas, SPOT mtb
jimf909 Samba Member
Posted: Sun Mar 29, 2020 3:22 pm Post subject: Re: Transaxle temperature sender - where to mount? |
Location of the sender on my 2WD manual trans...
_________________ - Jim
Abscate wrote: |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sun Mar 29, 2020 7:10 pm Post subject: Re: Transaxle temperature sender - where to mount? |
I did this on the driver side but I’m not sure it is effective. The hypothesis was that hot fluid would be tosses into this area. My gauge rises as the case temp rises but it is about 40’ cooler than the case. Could be my wire connections or sender or the location?
Super easy to do and I wouldn’t hesitate to drill on the trans in place.
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Syncro Jael Samba Member
Posted: Sun Mar 29, 2020 7:17 pm Post subject: Re: Transaxle temperature sender - where to mount? |
My first attempt was to JB weld a sensor in between fins on the transaxle. It was better than nothing but no where near as accurate as being able to "read" the gear oil temperatures. Drill and tap. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
bsrad Samba Member
Joined: April 17, 2012 Posts: 258 Location: Coeur d’Alene, Idaho
Posted: Sun Mar 29, 2020 8:05 pm Post subject: Re: Transaxle temperature sender - where to mount? |
Ok Sodo and Jim, I have to ask. What CV boots are those? _________________ Bill
1987 Syncro Westy
1967 OG Single Cab
1976 FJ40 |
tjet Samba Member
Posted: Sun Mar 29, 2020 8:13 pm Post subject: Re: Transaxle temperature sender - where to mount? |
Can I get by with a shorter sender (see below), or does it need to be the longer one?
I can drill and tap, no prob.
Sodo wrote: |
And you can use a 1/4NPT sensor too. |
I will do this as well
Posted: Sun Mar 29, 2020 8:29 pm Post subject: Re: Transaxle temperature sender - where to mount? |
bsrad wrote: |
Ok Sodo and Jim, I have to ask. What CV boots are those? |
Rockford 100mm CV boots. _________________ - Jim
Abscate wrote: |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Sun Mar 29, 2020 9:06 pm Post subject: Re: Transaxle temperature sender - where to mount? |
I asked my transmission builder and took a close look at the mechanicals and the most heat generating spot is the rear bearing, and that bearing is the most likely to fail because of the heat there and its isolation from oil circulation. So I glued a standard 10k temp sensor on the flat surface above the bearing using heat conducting glue. This applies to a 5-speed diesel trans, not Syncro. Should be the same principle though. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
