BusBerd Samba Member
Joined: November 19, 2005 Posts: 834 Location: Minneapolis, MN
Posted: Thu Apr 02, 2020 3:20 pm Post subject: Cylinder leak? |
I wasn't planning on taking off my cylinders, but this looks like an oil leak, right?
Likely causes & solutions graciously accepted.
Thanks!
Robert
[/img] _________________ "The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission |
raygreenwood Samba Member
Posted: Thu Apr 02, 2020 3:26 pm Post subject: Re: Cylinder leak? |
yep.
Could be caused by using only original stock paper gaskets if yours used it or lack of sealing compound around the cylinder base and gaskets or all of that could be in place and it simply failed because of age, vibration...or excessive case pressure. Check your PCV valve and case venting.
Ray |
Posted: Thu Apr 02, 2020 3:41 pm Post subject: Re: Cylinder leak? |
Its a pretty common leak, in general its a run it as is until something else gives out kind of problem.
If you have the engine out and want to go at it, don't let us stop you though. Yes the replacement style all metal cylinder base gaskets need a sealant, I have gone to using a judicious amount of High Temperature Copper Silicone and am sure others have their favorite goop to use here. Expect to spend a wad of money as you open things up further as other defects will show themselves. At a minimum I would have the valve guides checked/replaced and have the exhaust valves replaced. Since you would also be pulling the cylinders off the pistons new rings might be called for. |
SGKent Samba Member
Posted: Thu Apr 02, 2020 3:43 pm Post subject: Re: Cylinder leak? |
BusBerd wrote: |
Thanks!
Robert
[/img] |
as others have said - don't go there unless you are ready to rebuild the whole engine cause that is where it is headed. The only other thing you could consider is re torquing the heads. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
airschooled Air-Schooled
Posted: Thu Apr 02, 2020 4:39 pm Post subject: Re: Cylinder leak? |
SGKent wrote: |
The only other thing you could consider is re torquing the heads. |
Since the engine appears to be out at the moment, I would consider removing the rocker/upper tin and doing that. Clean and lubricated threads, always.
Good luck,
www.airschooled.com |
Posted: Thu Apr 02, 2020 5:07 pm Post subject: Re: Cylinder leak? |
Thanks guys!
Yes the engine is out (transmission too), but I don't know that I want to get into that much work right now by taking off the heads. I am a little hazy on the stuff past taking off the heads. I've done it before, but I don't do it every day, and I would need lots of research and refresher time to make sure I am doing everything correctly.
My original intent in taking the engine and transmission out was to just clean everything up, fix a few minor things, and inspect before I put everything back in the bus. I have not been losing that much oil, so I may kick this can down the road and fix this cylinder leak on a different day.
We are planning a road trip from Mpls to Teddy Roosevelt National Park in ND this summer (if COVID is safe by then.) So, I wanted to take the engine out before then and give it a once over. It is about 1,000 miles roundtrip.
