67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Sat Apr 04, 2020 9:19 am Post subject: Need some suggestions on bell housing |
I bought an engine from a guy a few years ago and he gave me this bell housing... I want to attach it to my engine stand to be able to start and run my freshly built engine. Apparently he drilled holes in it to cut it down☹️
Can I just cut it flat and weld it to a metal plate to attach it to my engine stand?
_________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
jsturtlebuggy Samba Member
Posted: Sat Apr 04, 2020 9:50 am Post subject: Re: Need some suggestions on bell housing |
Since the transaxle case is magnesium you are going to have to get the correct rod to weld with.
Also you are going to have to clean it very well before trying to weld on it.
Oil soak magnesium does not weld well.
You may find it cheaper to find another case or bell housing from a Bus. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Cant weld aluminum or magnesium to steel _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15307 Location: Deep in the 405
Posted: Sat Apr 04, 2020 9:54 am Post subject: Re: Need some suggestions on bell housing |
set the engine on the ground, bolt up the bell housing and start up the engine. It will run fine sitting on the garage floor or on top of a wooden pallet. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Sat Apr 04, 2020 10:06 am Post subject: Re: Need some suggestions on bell housing |
If you do decide to attach the belhousing to a plate I would use the clutch cross shaft as the point to weld a steel plate to. Then add some tabs that bolt to the bellhousing and weld to the steel plate. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Apr 04, 2020 10:15 am Post subject: Re: Need some suggestions on bell housing |
vwracerdave wrote: |
set the engine on the ground, bolt up the bell housing and start up the engine. It will run fine sitting on the garage floor or on top of a wooden pallet. |
+1 _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sat Apr 04, 2020 2:33 pm Post subject: Re: Need some suggestions on bell housing |
Thanks for the opinions! I don’t want to set it on the floor or a pallet because I have a cb slim sump that is attached to the oil strainer hole and it would put a lot of pressure on it.
An old tire sounds like a good choice at this point.
I was thinking that since I had it I would use it. Gonna be too much trouble I guess. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Apr 04, 2020 4:06 pm Post subject: Re: Need some suggestions on bell housing |
67 Sunroof wrote: |
I was thinking that since I had it I would use it. Gonna be too much trouble I guess. |
You can still use it to attach the starter to your engine and fire it up on an old tire. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Apr 04, 2020 4:07 pm Post subject: Re: Need some suggestions on bell housing |
Butchered to a point only thing it's good for is mounting starter... IF you want a mount to attach to engine stand I would look for a 002 bus bellhousing...
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Apr 04, 2020 6:03 pm Post subject: Re: Need some suggestions on bell housing |
Maybe get creative and bolt some brackets to the housing, then weld your plates to the brackets. Then weld or bolt the plate to the stand. If you're creative enough, you could make it removable from the stand when not needed. |
Posted: Sat Apr 04, 2020 7:06 pm Post subject: Re: Need some suggestions on bell housing |
Gotcha! I read through most of the engine start stand threads. Some really really cool looking ones too!
I figured I had it and why not use it. Agreed I could just use it for the starter too.
I love the 002 housing idea. That would easily adapt to my current engine stand. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sat Apr 04, 2020 9:36 pm Post subject: Re: Need some suggestions on bell housing |
That’s cool! I just don’t want it sitting on the floor with all of the weight on the sump.
I have an empi engine dolly with the caster “wheels” (I guess they could be considered wheels) _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Sat Apr 04, 2020 9:55 pm Post subject: Re: Need some suggestions on bell housing |
I just think the best engine stand is the car.
As a bonus, if you don’t have any leaks, you don’t have to move the engine again. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sat Apr 04, 2020 10:26 pm Post subject: Re: Need some suggestions on bell housing |
I see your point. It will be a first start to my first engine build and, as much as I want to think everything will be perfect, I’m certain I will have some newbie issues to resolve before it goes into my car. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Apr 05, 2020 4:02 am Post subject: Re: Need some suggestions on bell housing |
I don't see how going through all that is easier than just putting it in the car?? |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Sun Apr 05, 2020 4:10 am Post subject: Re: Need some suggestions on bell housing |
Maybe the car isn't ready yet... |
rayjay Samba Member
Posted: Sun Apr 05, 2020 5:50 am Post subject: Re: Need some suggestions on bell housing |
67 Sunroof wrote: |
I see your point. It will be a first start to my first engine build and, as much as I want to think everything will be perfect, I’m certain I will have some newbie issues to resolve before it goes into my car. |
You are being smart. On the test stand you can run the motor, set the timing and properly break in the cam and be able to easily look for oil leaks or listen for bad noises, at a comfortable height with no bodywork in the way. Once the motor is ready to go you stick it in the car, fire it up and drive away. Absolutely no drama. No crawling around on the floor adjusting the valves after cam break in, etc. You might still have to tinker with the carb to get the accelerator pump adjusted correctly but that is no big deal. |
lelef Samba Member
Posted: Sun Apr 05, 2020 6:09 am Post subject: Re: Need some suggestions on bell housing |
use long long nuts and bolts and use your motor stand as usual but with the bell housing _________________ 13b Buggy
Supercharged 1302
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Sun Apr 05, 2020 6:24 am Post subject: Re: Need some suggestions on bell housing |
Place some wood blocks under the heat exchangers/j pipes to protect your precious sump.
I know the CB sump is stout enough to withstand install with floor jack so how is resting it on a pallet going to harm it? |
