jimf909 Samba Member
Posted: Sat Apr 04, 2020 1:37 pm Post subject: Another dumb R&P question(s)... |
You may recall that last week I asked a n00b R&P question (how much of the tranny needs to be disassembled to R&R an R&P...answer: all of it). I've got a 4spd manual.
My question this week is: does the Ring get installed into the differential?
Reading from this post about the Country Homes Camper 3.27 R&P...
In 2020 we will install this same 3.27 R&P into our differential and after another 60,000 miles we’ll pull it out again to check the durability.
https://countryhomescampers.com/ring-and-pinion-reliability/
Does the R&P actually get installed into the differential or is it more of a case of the ring being installed on the differential with the pinion engaging the ring ON the diff?
Is the 3.27 for an Auto trans (3.27 sounds really tall for a manual trans which typically have ratios in the 4.5 to 5.8 range) and therefore different from a manual?
Likewise, if a Peloquin is installed, is the ring gear basically removed from the old diff and installed on the Peloquin?
Words may be more helpful than this picture...
No luck yet searching for actual photos.
Thanks. _________________ - Jim
Abscate wrote: |
Posted: Sat Apr 04, 2020 1:48 pm Post subject: Re: Another dumb R&P question(s)... |
Okay... here's the pinion, the round gear at the end of the shaft in the BOTTOM LEFT. Is that correct?
Abscate wrote: |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat Apr 04, 2020 1:55 pm Post subject: Re: Another dumb R&P question(s)... |
The country homes ring and pinion is for an automatic. I’m 90% sure. So that’s of no help to you. What exactly are you asking for? A manual transaxle is built around the pinion shaft pretty much. The only real task you can do with minimal effort and tools is to swap the stock open differential for another type. _________________ ☮️ |
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Sat Apr 04, 2020 2:16 pm Post subject: Re: Another dumb R&P question(s)... |
jimf909 wrote: |
I believe it is 8 bolts. It just bolts onto the diff.
jimf909 wrote: |
Yes. No need to touch the pinion or the rest of the transmission. Carrier bearings will have to be moved over or replaced though.
Here is a ring on a Peloquin. You can see the bolt heads on the back side. (The pinion and gears are not installed in this pic)
Pinions all by themselves.
Ring by itself.
Posted: Sat Apr 04, 2020 2:30 pm Post subject: Re: Another dumb R&P question(s)... |
MarkWard wrote: |
The country homes ring and pinion is for an automatic. I’m 90% sure. So that’s of no help to you. What exactly are you asking for? A manual transaxle is built around the pinion shaft pretty much. The only real task you can do with minimal effort and tools is to swap the stock open differential for another type. |
I'm trying to figure out how the parts go together. This has been on my mind and was spurred when reading the Country Homes Camper post. Yes, the 3.27 sure looks different from the manual Ring.
Old man's photos put it together for me. Thanks! _________________ - Jim
Abscate wrote: |
Posted: Sat Apr 04, 2020 2:39 pm Post subject: Re: Another dumb R&P question(s)... |
Bam! Now I can see it. Thank you.
This post from Gears also shows me the way (the entire thread is remarkably helpful)...
https://www.thesamba.com/vw/forum/viewtopic.php?p=6844109#6844109
Until next time, those are my R&P questions. _________________ - Jim
Abscate wrote: |
Zeitgeist 13 Samba Member
Posted: Sat Apr 04, 2020 9:25 pm Post subject: Re: Another dumb R&P question(s)... |
The R&P are a matched set. You can remove the ring without removing the pinion or taking the transmission section apart, but you can't swap another ring in without a matching pinion. The pinion is an integral part of the gear cluster in the transmission section. So, any R&P swap in a manual requires a complete transaxle tear down.
The automatics have entirely separate differential and transmission sections that can be...well, separated. This allows the automatics to have the R&Ps swapped out without having to break into the transmission section. Very different units. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Apr 05, 2020 11:18 am Post subject: Re: Another dumb R&P question(s)... |
^^^ Thanks. That's helpful in learning about these things.
old_mans thread along with the one from gears was also helpful.
https://www.thesamba.com/vw/forum/viewtopic.php?t=732709 _________________ - Jim
Abscate wrote: |
