gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Thu Apr 09, 2020 6:26 pm Post subject: Shift linkage |
57 bus. Can the shift linkage , the shifter ball to shift rod, get so worn that I end up with a lot of sideways movement.? Seems fine otherwise. M clip is in good shape along with the spring bushing inside the tube. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Thu Apr 09, 2020 9:17 pm Post subject: Re: Shift linkage |
I would think it odd to get a lot of sideways wear in the ball and socket.
The majority of the forces when shifting are fore and aft, so one would expect that to be higher wear than side to side.
Also, if there is significant wear on the shifter ball/socket, you may have a hard time finding 3/4 or 1/2.
Have you checked that all the grub screws are snug in both the linkage couplers? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Thu Apr 09, 2020 9:51 pm Post subject: Re: Shift linkage |
I never seen the ball/cup worn out from side to side movement. I'd have someone wiggle the shifter while I crawl underneath and inspect it. Looking for play in the linkage. Also maybe the hockey stick inside the transmission could be worn a bit. _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
Posted: Fri Apr 10, 2020 9:19 am Post subject: Re: Shift linkage |
Thank y'all. I'll check that out. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
