a2wolfsburggli Samba Member
Eric_Taylor Samba Member
Joined: January 21, 2011 Posts: 291 Location: Bend, Oregon
Posted: Fri Apr 10, 2020 12:29 pm Post subject: Re: Dash Out Projects Gut Check |
Just did this job and it's not horrible, but take your time. There are a lot of little parts that go along with it. Are you going to leave the heater core? I would replace it while you're in there. Unless your heater box (or whatever the right term is) has never been opened, I would want to avoid taking it apart any more than you have to. When I got to mine, someone had clearly been in there before and done a marginal job of getting it back together as stock. Lots of extra little screws, and they had to glue it together. This made for a real pan and lots of brittle plastic and associated issues. At any rate, if you're opening it up for the blower, I'd do the heater core.
Have you considered the BMW brake booster upgrade? That appears to be a dash pull job. When you get the dash out, you'll see just how much easier it is to get to then. It's an upgrade for sure, so not required, but if you're thinking about it, again, do it now. I did not and wish I had.
I also cleaned and replaced my grounds as necessary, which is just peace of mind.
I'd consider dealing with lighting etc. for the heater controls. Again, brittle plastic that you'd like to avoid taking apart more than once. Now is the time and the stuff is cheap.
Good luck. It's a satisfying job to complete. It's a bit tedious when you're doing it and one issue seems to trigger another but it's totally workable. However, I wouldn't want to do it often. So much old plastic. |
Merian Samba Member
Posted: Fri Apr 10, 2020 1:20 pm Post subject: Re: Dash Out Projects Gut Check |
electrical mods
stash an amp for stereo
rust control _________________ .... |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Apr 10, 2020 1:47 pm Post subject: Re: Dash Out Projects Gut Check |
Good time to install A/C. _________________ ☮️ |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Fri Apr 10, 2020 2:12 pm Post subject: Re: Dash Out Projects Gut Check |
There is no need to replace the heater core. They never fail. Peter from Van Cafe told me that. He sold them because people requested them but he'd never seen one leak.
My 89 Tristar with 408K miles has its original core, The blower motor squeaks and the vents are leaky but the core is solid.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Fri Apr 10, 2020 4:08 pm Post subject: Re: Dash Out Projects Gut Check |
Good time for the BMW brake booster mod. I cant speak from personal experience though I am about to do mine. From what I hear, it’s a great upgrade especially when paired with bigger brakes. Good luck with your projects! _________________ 1991 multivan, FAS 1.9 tdi, Peloquin limited slip
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Fri Apr 10, 2020 4:17 pm Post subject: Re: Dash Out Projects Gut Check |
If you plan on opening the heater box, don't forget the small clips to hold the tabs together when you close it.
Another option, which I did and worked well, is drill small holes in the tabs and insert small zip ties. It worked great. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Apr 10, 2020 4:59 pm Post subject: Re: Dash Out Projects Gut Check |
Is the front blower bearing "lube tube" on your list? That'll keep your new motor happy for a long time...
Otherwise, sounds like you're right on track...grease everything and Git 'r DONE!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Fri Apr 10, 2020 5:08 pm Post subject: Re: Dash Out Projects Gut Check |
sound insulation on the front panel. |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Fri Apr 10, 2020 5:33 pm Post subject: Re: Dash Out Projects Gut Check |
Examine the clutch and brake assembly , the wear points..
Lots about that here on Samba.
Lube the shaft and bushings, no real need to take apart to get lube in, just get some light oil in there.
Maybe your heater control cables have kinked ends at the control lever end. Good time to replace them.
Have fun!
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
tencentlife Samba Member
puchfinnland Samba Member
Joined: December 26, 2005 Posts: 279 Location: Deale Maryland
Posted: Sat Apr 11, 2020 8:14 am Post subject: Re: Dash Out Projects Gut Check |
Stan- much to think about, all good ideas,
As we do not smoke if the head was similar to the ashtry in size it could be a great concept for us.
I would like to find a system that works on low power house battery , and high power when engine is running or on shore power so not to consume the battery while camping _________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
Posted: Sat Apr 11, 2020 4:37 pm Post subject: Re: Dash Out Projects Gut Check |
Thanks everyone for the suggestions. I put a Mullendore Port in quick. Otherwise I pretty much stuck to my plan.
All the projects are complete and now it's time to reassemble. _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Past: '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense
Last edited by a2wolfsburggli on Sat Apr 11, 2020 5:44 pm; edited 1 time in total |
jimf909 Samba Member
Posted: Sat Apr 11, 2020 4:54 pm Post subject: Re: Dash Out Projects Gut Check |
Some one has mentioned relocating the fan resistor to behind the front grill for easy access in the future. I'm don't know if the Jeep mod includes that so ignore me as needed.
Thanks for the thread with all the links. Bookmarked. _________________ - Jim
Abscate wrote: |
oldskewlsk8ter Samba Member
Posted: Sat Apr 11, 2020 5:42 pm Post subject: Re: Dash Out Projects Gut Check |
I’d skip that ball valve and find one of these 3/4 pex mini valves...I did and it fits so much better
https://www.dahlvalve.com/product-search.php?page=...%2C+plated _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
Posted: Sun Apr 12, 2020 3:29 pm Post subject: Re: Dash Out Projects Gut Check |
For those that didn't see my post on the VOG here is what I discovered when I got the heater box off.
I was SHOCKED by the amount of shit in there.
All cleaned up
New foam
Jeep Resistor mod. I'm mixed on this one honestly only because I'd like to find a resistor that perhaps has a bit of a slower lowest speed. It's works perfectly though.
Box back in and sound deadening in. I'm really happy with how much less "35yo VW" the van sounds like right now. It's not really quieter per se. It's just feels a little more solid I guess? Next up with sound deadening is the wheel arches and doors for sure. Work my way back though the van as time allows. Suppose I'll have to pull the fridge again. ugh.
Dash almost all buttoned up.
Last edited by a2wolfsburggli on Mon Apr 13, 2020 8:56 am; edited 1 time in total |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Sun Apr 12, 2020 10:08 pm Post subject: Re: Dash Out Projects Gut Check |
Looks like you were running a Rodent Ranch in there! |
Merian Samba Member
Posted: Mon Apr 13, 2020 12:14 pm Post subject: Re: Dash Out Projects Gut Check |
Yes, rodents are "preppers"
Be sure to put wire mesh over the entry points, and be careful about leaving the doors/hatch open as well as storage.
I once had a Zapus (jumping mouse) jump right into my Bay bus going over my leg while I was sitting in the slider. _________________ .... |
zimflux Samba Member
Posted: Fri May 08, 2020 5:50 am Post subject: Re: Dash Out Projects Gut Check |
Nice Job!
What are the thicker seals used for?
https://www.amazon.com/gp/product/B0773H12TT/
Anything else recommended or parts missing from your above list?
Thanks. _________________ 84 1.9 Westy |
Posted: Fri May 08, 2020 6:46 am Post subject: Re: Dash Out Projects Gut Check |
replacing the seal around the blower motor.
Watch this portion of the blower motor vid: https://youtu.be/h7wgsznvcCE?t=474 _________________ Current: '87 Westfalia | '16 Audi Q5 3.0T S-Line w/sport package.
Never underestimate the entertainment value of OCD overruling Common Sense |
