BFB Samba Member
Posted: Fri Apr 10, 2020 8:17 pm Post subject: RGB disk brake conversion ? |
has anyone converted their RGB's to disk brakes? if so , love to see some pics and info. esp if its a large nut RGB as i figure theres less interchangeable parts for them |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Posted: Sat May 23, 2020 12:31 am Post subject: Re: RGB disk brake conversion ? |
I had thought about this myself for my split bus. The best solution I could think of was to use a bay window rear hub, with a spacers made from another set of hubs to get the correct bearing preload. Basing the total width off a drum's splined area. And then use a set of Mercedes 5X112 rotors, modifying them or the hubs to fit, And then all you'd have to do is find calipers that would work and make some brackets. _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
1978 Westfalia Camper
Transmissions For Dummies |
BFB Samba Member
Posted: Sat May 23, 2020 8:33 am Post subject: Re: RGB disk brake conversion ? |
that's a pretty good idea to use a hub. i suppose the stock drum could even be machined down to a hub and then find a rotor to use. the roundy round parts guys have bolt on rotors and brake hats _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
