SGKent Samba Member
Posted: Tue Apr 14, 2020 6:21 pm Post subject: Re: Frusting Brake Bleeding Issue |
Whaanga wrote: |
Thanks again to all who offered help and advice.
Steve, the first thing I did was check the push rod length and discovered it was way out of adjustment. I put it back to spec per Bentley. I started the bleeding process at the right rear wheel and noticed that the bleeder valve, when opened a quarter turn, was loose in the threads (like a loose tooth). Luckily, I had some extras so I installed them, did a one person bleed and it didn't take long before the pedal was back to full function and appropriate travel.
I think between the rod being out of adjustment and the loose bleeder valve (allowing air to enter the system) I found the cause of my Frustrating Brake Bleeding Issue.
Thank Again for all the help,
Jeff |
Jeff - super happy that is all it was. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Whaanga Samba Member
Joined: May 07, 2016 Posts: 626 Location: Rochester, NY
Posted: Tue Apr 14, 2020 10:11 pm Post subject: Re: Frusting Brake Bleeding Issue |
Quote: |
Jeff - super happy that is all it was. |
Thanks Steve, me too. I’m a little embarrassed that I wasn’t able to diagnose this myself but am grateful to learn from everyone who contributed here.
In these strange times of Covid 19, I am very glad for our VW community. _________________ Late 1973 Bay w/a transplanted 914 Engine |
SGKent Samba Member
Posted: Tue Apr 14, 2020 11:02 pm Post subject: Re: Frusting Brake Bleeding Issue |
Whaanga wrote: |
In these strange times of Covid 19, I am very glad for our VW community. |
It can be a great place when we all work together. There are two adjustments on the servo. One is between the servo and the master in the form of a rod. On some cars that rod is adjustable. There is a cup in the master that the rod sits in, and a cup (indent) in the servo. I don't think that rod is adjustable on a bus and it has been too long since I have had it out to remember if it is or not. If that rod sits on the edge of the cup and not in the cup it will throw the geometry off. If you aren't sure you got it into the indents then pull it and check it. Also did you replace the O-ring between the master and the servo? That helps seal the vacuum. Who did the work on the servo, where did you send it? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Wed Apr 15, 2020 2:53 am Post subject: Re: Frusting Brake Bleeding Issue |
On my flotilla of VW, BMW, and Volvo I have evolved to the point of replacing bleeder screws with OEM whenever I do my semiannual fluid change. I don’t know if the supply chain for brake hardware for Bays is as good as the other two, but the worse it it, the even better this idea might be.
$20 every two years for hardware , vs a snapped bleeder and hours of conduct/language unbecoming of the Creator. _________________ .ssS! |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Wed Apr 15, 2020 5:47 am Post subject: Re: Frusting Brake Bleeding Issue |
I'm going to build a pressure bleeder this weekend (I hope) as Jetfxr69 and I replaced my MC last fall, then I replaced some lines and WCs so want to pressure bleed the system. I have a vacuum bleeder but sounds like the pressure process is worth doing?
IIRC, I read someplace that the late bay reservoir cap is the same size as some general household cap, do I have that right? _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
SGKent Samba Member
Posted: Wed Apr 15, 2020 8:32 am Post subject: Re: Frusting Brake Bleeding Issue |
ImAddicted wrote: |
IIRC, I read someplace that the late bay reservoir cap is the same size as some general household cap, do I have that right? |
Save your time: https://www.amazon.com/Motive-Products-0104-Volkswagen-Bleeder/dp/B0002KM5LK
SGKent wrote: |
you can buy just the adapter if you want. 1104 Air Cooled Vw Adapter
http://motiveproducts.3dcartstores.com/1104-Air-Cooled-Vw-Adapter-_p_97.html
Summit, Amazon, Ebay and more have them. Or send it back and ask for the correct adapter. Use like 5 - 7 psi pressure is usually adequate, never over 10 even thought it says 15 PSI in the instructions. The old plastic tubes, hoses and reservoirs can and do split. One guy in a Ferrari forum put brake fluid all over his paint and engine bay when a hose broke at 15 PSI, then spent hours cleaning it up before it ate the paint.
I've used mine on the bus and with another adapter our Sable Wagon. On both cars it got out small bubbles after caliper rebuilds that would not come out with normal bleeding - especially on the Sable. |
Posted: Wed Apr 15, 2020 10:16 am Post subject: Re: Frusting Brake Bleeding Issue |
I'll start trial an error, just thought I had seen it someplace that there was a standard household cap that was the same size. As I mentioned in another thread, delivery isn't an option if I want to have it before snow flies. Thanks for posting the links, I bet someone else will be glad you did. Stay safe, stay home _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Posted: Wed Apr 15, 2020 1:02 pm Post subject: Re: Frusting Brake Bleeding Issue |
If anyone is interested, so far the best fit and design has been the top of a Dawn dish soap bottle. The spout fits a piece of vinyl tubing with a small clamp with just enough meat to be secure, the threads are spot-on for the upper reservoir on a late bay (after a good cleaning to remove the detergent residue, of course).
KC1MUR
strfish7 wrote: |
SGKent Samba Member
Posted: Wed Apr 15, 2020 1:33 pm Post subject: Re: Frusting Brake Bleeding Issue |
ImAddicted wrote: |
I just realized you hijacked the Whaanga's thread, but good luck with your project. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Wed Apr 15, 2020 3:47 pm Post subject: Re: Frusting Brake Bleeding Issue |
ImAddicted wrote: |
Scott, Even I was able to build one! I just used a garden pump up sprayer I had got from "the mart" on clearance and i just bought another cap so I didnt have to fiddle with it. So simple even a caveman can do it!
did i bleed the brakes? Nooooo
did i even get the brakes reassembled? Noooo
but i did manage to build the bleeder. Now i just cant find it _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
Posted: Wed Apr 15, 2020 4:42 pm Post subject: Re: Frusting Brake Bleeding Issue |
Quote: |
Also did you replace the O-ring between the master and the servo? That helps seal the vacuum. Who did the work on the servo, where did you send it? |
I did not replace the O ring but when I read you post, I got on line and ordered one. I should have thought of this so thank you for brining this up.
These are the folks that did the rebuild (I learned about them from Robbie) - they're based in Fort Wayne, IN.
http://www.BrakeMaterialsAndParts.com
Very nice folks and they did a great job. _________________ Late 1973 Bay w/a transplanted 914 Engine |
