striker catch plate fell inside the Pillar - now what?
chamilka
chamilka is offline
PostPosted: Tue Apr 14, 2020 1:32 pm    Post subject: striker catch plate fell inside the Pillar - now what? Reply with quote
Hi All,
I removed the front passenger door striker plate last weekend. White removing it, the loose catch plate (where the screws go) behind the Pillar fell to the bottom of the pillar. I am unable to retrieve it.
What are my options?
1966 Bus.
early
early is offline
PostPosted: Tue Apr 14, 2020 1:59 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
yikes, I hadn't realized that this would happen.
i'm following this thread because I was just about to remove the same plates on my bus .
I suppose I would try a combination of a stiff wire and a magnet to try to retrieve it but you probably already thought of that .
good luck and following.....
early-
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
chamilka
chamilka is offline
PostPosted: Tue Apr 14, 2020 6:35 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
I think if you remove one screw at a time, you have time to hold on to it. I did't think it would fall.
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Tue Apr 14, 2020 8:07 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
chamilka wrote:
early wrote:
yikes,
I didn't think it would fall.
Bummer
Perhaps try using a strong rare earth magnet on the outside of the B pillar where you suspect the nut plate to be.
You may be able to "grab" the nut plate through the B pillar and slide both the magnet and the nut plate up the pillar.
Short of that, you may be cutting into the B pillar.
Edit: One other consideration is cutting into the B pillar from the bottom - through a portion of the inner dogleg and retrieve it from the bottom. That would not mess up any exterior paint at least and the patching of the cut would require less finishing.
Good luck with it.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Tue Apr 14, 2020 8:29 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
You could always turn it upside down and shake like getting change from your Piggy Bank.
Sorry, I deal with problems with bad humour...I'm not proud of it.
But to be honest, you could use a borescope in one screw hole and a wire down the other to hook it.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
perello
perello is offline
PostPosted: Wed Apr 15, 2020 7:31 am    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
yeah I did this
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Apr 15, 2020 7:33 am    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
I pulled wire for commercial A/V jobs for years. One little trick I would use is a tool called a wet noodle. Basically a small magnet on a ball chain.
That's what I'd try. Good luck!
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
early
early is offline
PostPosted: Tue Apr 28, 2020 1:55 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
wondering if you found a solution ?
my question is : Does the Striker plate attachment bolts Not welded to the inside of the B pillar?
I cant believe that this could happen. I want to remove my strikers for painting rather than mask them.
has anyone else had this issue?
thx
early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue Apr 28, 2020 2:19 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
We hava' nicely patina'd 1962 SO33 and the bottom-fastening-bolts were rusted to that plate. So, I cut the metal, behind the plate - which is outside, on the outer skin - I was able to access that plate and squirt some rust buster on and remove everything -
- by the way, that plate is (supposed) to be held in place with metal tabs. So even if you unscrew all the fastening-bolts, the nut-plate should remain in place - a good design GMOG reminded me that, that screw-plate moves around, a little when held in place, by the tabs - for perfect door adjustment, too.
I fabricated a (little larger) metal plate, with a piece, from my 1961 parts bus, to cover my new access hole. So I (or someone, down-the-road, someday) could get in there if they had to... the new access is very visible and I like that - a great conversation-starter and i'm not real-anal 'bout imperfections... for imperfections-makes-perfect.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
russ c
russ c is offline
PostPosted: Tue Apr 28, 2020 4:47 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
Can you fish a long thin flat headed screw driver in there to lift the plate so that you can get a screw started. Once you get one started itíll hold it in place. Good luck it sucks dealing with that stuff
ZENVWDRIVER
PostPosted: Tue Apr 28, 2020 7:18 pm    Post subject: Re: striker catch plate fell inside the Pillar - now what? Reply with quote
Ö not much of a fisherman - just wanna get in there and fix things - same thing happened to me, on the rear cargo-door and I cut a 3 sided access and bent the metal down - worked through the little hole, I made and bent the hole closed, when done - put a piece of tape over it and never thought 'bout it again - my inner-zen-master told me to do it that way and He's "the man".
1960 single cab
'87 Toyota MR2
