pupjoint Samba Member
Posted: Tue Apr 14, 2020 8:14 am Post subject: IDA floats brass or new plastic |
do they still make new brass ones? any advantages over the plastic ones? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Tue Apr 14, 2020 8:28 am Post subject: Re: IDA floats brass or new plastic |
pupjoint wrote: |
https://www.dellorto.co.uk/shop/weber-carburettors...ida-float/
Brass. IDK if there are any Plastic floats available.
Good Luck _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
jsturtlebuggy Samba Member
Posted: Tue Apr 14, 2020 9:34 am Post subject: Re: IDA floats brass or new plastic |
The 48ida rebuild kit I just received from Pierce Manifolds in Gilroy, CA has a new brass float in it. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Apr 14, 2020 9:37 am Post subject: Re: IDA floats brass or new plastic |
IDA's are inherently Alcohol friendly.
Brass floats are part of that... |
Posted: Tue Apr 14, 2020 10:07 am Post subject: Re: IDA floats brass or new plastic |
from the eurocarb link, it shows the float is not brass.
maybe the material is not plastic but it black and light. will drop eurocarb an email |
Posted: Tue Apr 14, 2020 10:20 am Post subject: Re: IDA floats brass or new plastic |
pupjoint wrote: |
You are correct. Must be my old tired eyes are failing me.
Carry on. _________________ I have learned over the years.
Buy Once, Cry Once!
richierich Samba Member
Posted: Tue Apr 14, 2020 11:10 am Post subject: Re: IDA floats brass or new plastic |
I put plastic floats in my IDA's after chasing an issue for ages with a needle valve being overcome that eventually turned out to be a pinhole in the brazed seam of one of the brass floats. No problems with the plastic items so far and dimension wise, they were spot on. _________________ Blah..... |
