marlinmatt Samba Member
Posted: Wed Apr 15, 2020 10:05 am Post subject: Steering box input shaft leak |
Hi all, I'm starting assembly on my buggy. Probably 66, not totally sure. Anyhow, I noticed oil leaking from where the steering shaft enters the steering box. I can't exactly ID this box, but it is VW OEM. It does not have grease caps.
Anyone fixed this seal before?
Does it require dismantling the box? I've been searching for hours, have yet to see one with the pinchbolt at the input shaft! Any help much appreciated!
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Wed Apr 15, 2020 10:09 am Post subject: Re: Steering box input shaft leak |
That is an earlier style box than what the 66 would have had.
Here is a link to the seal
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111415285A
You can replace the seal without dismantling the box. You can look through my gallery I have a fair amount of pictures of the disassembly/reassembly of a box like this one. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Apr 15, 2020 10:17 am Post subject: Re: Steering box input shaft leak |
welcome
You can remove the seal, measure it and source it local doesn't have to be a VW seal
60ragtop wrote: |
smaller "Input" seal - #552505 - 16x24x7 size
larger "Output" seal - #10939 - 24x40x7 size
This is the size of seals needed. |
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Apr 15, 2020 12:44 pm Post subject: Re: Steering box input shaft leak |
Wow! thanks so much! I've been searching here for hours, shoulda waited, I could have got some painting done.
So, it appears that the adjuster sleeve around the input shaft (With the flat spots) can be removed without removing the worm or other parts. Is that right?
Also, I see you swapped oil for grease, does that work out OK in the worm/sector old box? I've seen varying opinions, mostly leaning toward grease.
Or...Do you think a grease fill would eliminate leaking, thus negating the need for the seal altogether?
Thanks again! |
Posted: Wed Apr 15, 2020 2:55 pm Post subject: Re: Steering box input shaft leak |
marlinmatt wrote: |
Thanks again! |
I used the corn head grease, I'd still use a seal with this style of grease especially as it would leak out too. As you mentioned there are varying opinions on grease vs oil for the earlier boxes. I felt better with grease and this style of grease is designed for applications like this.
And you're right about adjuster sleeve but you can replace the seal without removing it too. It goes on from the side that faces out so you don't have to take it out to do. Just have to remove the end that bolts to steering coupler since it's bigger than the seal is of course. |
Posted: Tue Apr 21, 2020 2:38 pm Post subject: Re: Steering box input shaft leak |
Thanks! Makes total sense to me. I ordered the grease, and the seal, too. Appreciate the help! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
