HoboBus Samba Member
Joined: December 29, 2016 Posts: 347 Location: Massachusetts
Posted: Thu Apr 16, 2020 11:50 am Post subject: Re: Rattle Can paint job.... |
Eh, tough to ask about something like this to the general public.
Some people like a bus with patina. Some don't.
Some dont like anything other than OG paint.
Some dont like Harbor Freight tools and will call you an idiot for shopping there, others will tell you to go buy a cheap HF spray gun to spray your bus.
Everyone is entitled to their opinion.
My thought -- I think it looks great. Do it your way, and enjoy your bus. Don't get bothered by what other people think.
malcolm2 wrote: |
I will have a ready supply of touch up and not feel bad about parking at Walmart. |
I like this philosophy.
Keep at it!
Hobo. _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Apr 16, 2020 12:13 pm Post subject: Re: Rattle Can paint job.... |
HoboBus wrote: |
malcolm2 wrote: |
Keep at it!
Hobo. |
It’s a public forum, everyone has an opinion and you get the bad with the good. Some people get offended by comments that don’t support their own opinions and others take those contrasting opinions with an open mind. Some aren’t as artful as others at pointing out issues/flaws so sometimes opinions can come off as mean/condescending but it’s best to just take the useful information and ignore the rest.
For me when I thought I was doing something good and it was pointed out the potential issues I might face I found the criticisms helpful. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
subliminaldood Samba Member
Joined: January 23, 2020 Posts: 21 Location: Seattle, WA
Posted: Thu Apr 16, 2020 12:44 pm Post subject: Re: Rattle Can paint job.... |
I have the other problem, I've been rattle canning some trim pieces, hubcaps, etc and recently a section of rear quarter panel... My paint job is not OG and over 20 years old... It wasn't properly finished then like they never sanded and polished... just shined up the orange peel... It's white ('66 Ford Wimbledon White to be precise) so it looks good at 10 feet. So my rattle can bits are shinier and prettier than the rest of the Bus!!
Duplicolor Perfect Match is what I've been using... Expensive at $10 per can!!
And not quite a perfect match, but close for some things, but not a body panel... I'm going to explore the idea of getting a custom blend from a paint store in a rattle can... Only have a pancake compressor with 3scfm output, so not so good for a HPLV gun.
My method has been: smooth with scotch pad - primer - sand with 600 - base color x3 - clear x 3 then sand with 600, scotch pad, 1000, 2000, then 3000 wet sand and finally polishing compound. Comes out mirror smooth. _________________ 1969 Panel
double door
walk through |
Posted: Thu Apr 16, 2020 12:48 pm Post subject: Re: Rattle Can paint job.... |
subliminaldood wrote: |
My method has been: smooth with scotch pad - primer - sand with 600 - base color x3 - clear x 3 then sand with 600, scotch pad, 1000, 2000, then 3000 wet sand and finally polishing compound. Comes out mirror smooth. |
I suck at painting so I decided to go the powder coating route. If you have the space for the oven and the media blaster it’s a good option as you’ll get a really good AND durable finish with a minimal amount of work. Of course the drawback is that I can’t do large pieces but I could get the same powder I use and take it to a professional powder coated. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Thu Apr 16, 2020 5:31 pm Post subject: Re: Rattle Can paint job.... |
Used that setup on several occasions, just get a water separator and n-line regulator. I’ll never win an award for Best Paint but that simple system has served me well for my purposes. YMMV
It was this color before but I'd already done a graphite bike so I changed this GS550 to purple
_________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
SGKent Samba Member
Posted: Thu Apr 16, 2020 6:07 pm Post subject: Re: Rattle Can paint job.... |
ImAddicted wrote: |
looks a lot better than rattlecan. That is pretty impressive for such a small compressor. One thing folks can do, is if you see an inexpensive unit someone is in a hurry to get rid of, you can parallel the tanks if they are similar pressures. Run to two different outlets/breakers in the house with really heavy duty short extension cords, and you'll get twice the output. I bought a Craftsman unit years ago and found out it wasn't enough. Found one on CL someone was getting rid of cause he bought a new one. The only issue was he had a wood shop and the filter was plugged with sawdust. Swapped that, paralleled the tanks and now I have plenty of air. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Apr 18, 2020 6:16 pm Post subject: Re: Rattle Can paint job.... |
Siamese compressors, not a bad idea - more volume should help sustain low pressure, in turn running the motor(s) less. Gonna have to give that a try next time, thanks. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
SGKent Samba Member
Posted: Sat Apr 18, 2020 8:13 pm Post subject: Re: Rattle Can paint job.... |
ImAddicted wrote: |
Siamese compressors, not a bad idea - more volume should help sustain low pressure, in turn running the motor(s) less. Gonna have to give that a try next time, thanks. |
Siamese the tanks and not the outputs. I added a tee and a quick F disconnect to each tank inlet, then ran a hose with a M disconnect on each end. You only need to feed the sprayer from one tank and regulator. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sun Apr 19, 2020 6:15 am Post subject: Re: Rattle Can paint job.... |
You can be like my PO and be so lazy as not to even remove the spare tire!
_________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
cmonSTART Samba Member
Posted: Sun Apr 19, 2020 9:03 am Post subject: Re: Rattle Can paint job.... |
Is that like when you paint your bathroom and don't bother to move the toilet? _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Sun Apr 19, 2020 11:15 am Post subject: Re: Rattle Can paint job.... |
shano63 wrote: |
Did he just not remove it or has the paint just aged differently behind the cover and tire? |
Posted: Sun Apr 19, 2020 11:50 am Post subject: Re: Rattle Can paint job.... |
That's the original paint behind the spare. You can see it on the door where it has flaked off _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Posted: Sun Apr 19, 2020 2:53 pm Post subject: Re: Rattle Can paint job.... |
cmonSTART wrote: |
Is that like when you paint your bathroom and don't bother to move the toilet? |
lol, BTDT. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Posted: Sun Apr 19, 2020 4:04 pm Post subject: Re: Rattle Can paint job.... |
cmonSTART wrote: |
Never let the guy doing the tile or other flooring work, just lay the flooring with the toilet in place. It forces you to either never replace your ugly old toilet or to have further flooring work done when you do. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Mon Apr 20, 2020 8:26 am Post subject: Re: Rattle Can paint job.... |
Wildthings wrote: |
cmonSTART wrote: |
And it's so much harder to tile around it than remove it! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Apr 20, 2020 10:42 am Post subject: Re: Rattle Can paint job.... |
I managed a rental house in Palm Springs that the owner had a handyman tile the flooring thru the whole house.
But when the kitchen was tiled, the handyman very precisely cut the tiles to fit around the front of the refrigerator. It would have been much simpler to roll the fridge out and tile under it. But this handyman was not known for his Mensa abilities... |
Posted: Mon Apr 20, 2020 11:01 am Post subject: Re: Rattle Can paint job.... |
KentPS wrote: |
I've cut tile, I'd rather move the fridge with my teeth than cut out around it. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
westy Samba Member
Joined: June 16, 2004 Posts: 154 Location: isle of misfit bus owners
Posted: Mon Apr 20, 2020 6:54 pm Post subject: Re: Rattle Can paint job.... |
[quote="malcolm2"]
.........not sure I would have done it the same way, but it's your Bus.
Looks fine. Use the hell out of it, that's what they're for.
Have fun. Be safe. _________________ ...everyone has something to teach you.
Support our troops. Not all injuries are visible ones. |
Abscate Samba Member
Posted: Tue Apr 21, 2020 3:34 am Post subject: Re: Rattle Can paint job.... |
Hopefully the workmanship is better than the invoicing method. _________________ .ssS! |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Tue Apr 21, 2020 7:48 am Post subject: Re: Rattle Can paint job.... |
Wildthings wrote: |
cmonSTART wrote: |
Yup. And you will miss the chance to rip out all the layers of moldy luan, peel and stick tile and punky subfloor lurking underneath from a toilet flange that has been leaking for decades. While you’re at it, rent a chain cutter and replace the old cast iron stink pipe.
Buses and bathrooms have a lot in common. |
