What cams do I have?
Jellezwolle
Jellezwolle is offline
PostPosted: Fri Apr 24, 2020 7:00 am    Post subject: What cams do I have? Reply with quote
He guys,
Got a question about 2 cams that I have laying around.
Could you guys help me out, donít know what they are.
This one is I think a engle fk8?
And the next i donít have a clue.. it only says sc1 but that is the material I think?
Thanks! [/b]
AZOffTheWall
AZOffTheWall is offline
PostPosted: Fri Apr 24, 2020 7:18 am    Post subject: Re: What cams do I have? Reply with quote
1st one is an Engle K8, they changed to the FK designation many years ago, I believe the specs are slightly different on the old grind, great cam. If i remember correctly .530 lift with 1.4's 308 duration with about 260 @.050, have one in my motor. No idea on the unmarked one, only way to tell is to mock it up in and check it with a degree wheel
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=665399&highlight=
[email protected]
k@rlos is offline
PostPosted: Fri Apr 24, 2020 11:35 am    Post subject: Re: What cams do I have? Reply with quote
FK8, fantastic all round street cam. Had 1 in my bus, loved it.
Ebel
Ebel is offline
PostPosted: Sat Apr 25, 2020 10:01 am    Post subject: Re: What cams do I have? Reply with quote
You can get an idea of the lift on the unmarked cam by measuring the widest part of the lobe and the smallest part then subtract. You would also need to multiply by your rocker ratio if you want the lift at the valve. I would just use The stock 1.1:1 ratio for that.
