JonL Samba Member
Joined: March 07, 2002 Posts: 308 Location: Highlands Ranch, Colorado
Posted: Tue Apr 28, 2020 7:10 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Thanks for the ideas, I appreciate it! and I'll get some more pics soon, it's coming along, pretty happy so far. _________________ 65 Notchback
65 21 Window |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Wed Apr 29, 2020 1:30 am Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
You make it look so easy JonL
JonL wrote: |
been polishing for the past month....some random pics, not necessarily in order
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
JonL Samba Member
Posted: Wed Apr 29, 2020 8:38 am Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Thank you, PM'd you, hope it helps! _________________ 65 Notchback
65 21 Window |
JonL Samba Member
Posted: Thu Apr 30, 2020 4:54 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Being a driver, I wanted safaris and went with Wolfgangs. Pretty straight forward installation.
The yellowish color has to go though; I’ll paint those later. Fit is nice as I could expect.
You can also see other work that’s complete- all trim with sea blue insert is on, new turn signals, the polishing, etc
Getting closer
65 21 Window |
JonL Samba Member
Posted: Thu Apr 30, 2020 5:09 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Also installed some sound deadener- I went with a thin one, didn’t feel the need for a thick one.
Very happy with the difference; feels and sounds more solid.
Simple install, but the time to do it was now.
65 21 Window |
JonL Samba Member
Posted: Tue May 05, 2020 7:01 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Finishing up the rust repair, and also picked up the seat frames and sunroof header from powder coat. Super happy with the way they turned out. Also got some sub assemblies done- pop outs, etc.
Can’t wait to get the rust repair wrapped up so I get the engine back in! I decided to have a local shop weld up a few areas,, then I’ll finish them up.
65 21 Window |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
BusJunky Samba Member
Joined: February 27, 2009 Posts: 568 Location: Norwalk, ohio
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Fri May 15, 2020 12:09 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
JonL wrote: |
Cool! I bought the same safaris, and was miffed by the color. I was told white, but they're more like a cream color. Nothing I've found even close to that color in the VW colorwheel. I wish I had just gotten the unpainted ones and had them painted myself. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
c21darrel Samba Member
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Fri May 15, 2020 2:03 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
I can't complain much about the product itself and mine are getting painted anyways but your are right, its like an antique white or almost cream. Hell even just bright refrigerator white would be better than that ugly yellow- white they paint them with!
peecee69 wrote: |
JonL wrote: |
Cool! I bought the same safaris, and was miffed by the color. I was told white, but they're more like a cream color. Nothing I've found even close to that color in the VW colorwheel. I wish I had just gotten the unpainted ones and had them painted myself. |
JonL Samba Member
Posted: Sat May 16, 2020 3:55 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Thank y’all, I appreciate it!
I actually scuffed and painted the safaris-they were really together tight and I wasn’t too worried about it if they weren’t perfect. The tabs were also welded instead of screwed and painted those blue white.
I had a little rust going through on the window corner, so addressed those areas too.
This is all out of my garage, but I’m pretty happy about how it’s turning out!
65 21 Window |
TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Sat May 16, 2020 4:03 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
I need to do exactly this to my safari’s. Did you pull back the rubber or just taped where rubber meets the metal? |
JonL Samba Member
Posted: Sat May 16, 2020 4:06 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
And rust repair is done, working on bodywork and blending.
Getting close!
65 21 Window |
Posted: Sun May 17, 2020 8:12 am Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Wow JonL looking good, I have been contemplating using that adhesive based thin insulation Kilmat but was uncomfortable about if I needed to ever remove it. I'm glad to know it works as well as the aluminum over bubble wrap insulation I bought but haven't used. Can any moisture get between the inside metal and the mat itself? I guess it can't right? I live in always damp NJ and I'm always preparing for future rust. Tips/suggestions please
JonL wrote: |
Maui Roadsters
Lind wrote: |
JonL Samba Member
Posted: Sun May 17, 2020 4:58 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
TheVintageVw wrote: |
I was going to blow them apart originally, but those things are in super tight!
But I’m also not looking for a “show car”
I did take off all latches and the 4 screws on each window and then masked them off. I scraped the edge of a razor to take any over spray off, which wasn’t much.
I would highly recommend using a good quality tape that’s meant for this. Not the normal blue Home Depot. I used this:
65 21 Window |
JonL Samba Member
Posted: Sun May 17, 2020 5:10 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
LAGrunthaner wrote: |
JonL wrote: |
This sound deadening is more of a rubber with a thin aluminum type top. Once you roll it on, it’s on. No air, no moisture, nothing. I wouldn’t hesitate to use it in any climate. I also had some leftover from another car I did, and I totally forgot I had it. I might throw it on too, it’s basically the same stuff, little better known brand:
65 21 Window |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Mon May 18, 2020 7:44 am Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
Looking good. Close to rolling it down the road. |
Posted: Mon May 18, 2020 8:38 am Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
did you consider doing the sound pads on the front floor by any chance? Thinking about this myself. |
JonL Samba Member
Posted: Mon May 18, 2020 1:13 pm Post subject: Re: New purchase to me, 1965 21 deluxe, semi-build thread |
You easily could and wouldn’t hurt, but I didn’t. My front, stock insulation was in perfect shape, so I left it in that area too.
My package tray was a different story. It was either missing or falling apart. I got this to cut up and put in like original. I have a stock style carpet to go over it from Wolfsburg west- we’ll see how it goes. Being above the engine I thought was important.
Also, with the sunroof and pop outs, I’m not going for super quiet, just some of the road noise and more of a “thud” on the doors
Hope it helps
65 21 Window |
