Stay with the 74 crank |
Go for the 78 crank |
80% |
[ 4 ] |
Other |
20% |
[ 1 ] |
Total Votes : 5 |
MitchS046 Samba Member
Posted: Sun Apr 19, 2020 5:10 am Post subject: Help on deciding on engine specs |
Hi,
I recently decided to build my motor to a 2054 with a 74 crank and 94 AA c+p. I now found out someone near me is selling a 78 crank with a leightweight flywheel for €450. What should i do? Rest of the specs will be cb performance panchito heads with titanium retainers, dual springs and snakeskin valves. A compression ratio of 9:1. Deck height 0.040” and combination chamber 60cc. FK8 cam. Was thinking on scat 114.8mm H beam rods. 1:1.25 rockers and maybe a EFI fuel injection system. A magnaspark II ignition system. exhaust wil probably be an CSP super competition without j tubes as I want to keer the heating . Cooling wil be a original gol set. Case will have the hoover mods and full flow done to them for optimal lubrication and cooling. Remote mounted oilcooler. AT trans.
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sun Apr 19, 2020 5:41 am Post subject: Re: Help on deciding on engine specs |
It depends heavily on both cam and exhaust choice. There is a significant difference on how a 2074 and a 2165 behaves when/if everything else stays the same.
So if cam etc is already chosen we need to know what that is. Also which engine behaviure you want. |
Posted: Sun Apr 19, 2020 5:51 am Post subject: Re: Help on deciding on engine specs |
Added that i want to use an FK-8 cam and a cup super competition exhaust accidentally forgot it😅 |
Posted: Sun Apr 19, 2020 6:22 am Post subject: Re: Help on deciding on engine specs |
MitchS046 wrote: |
cup super competition exhaust |
eeerhhm, which is that ? CSP super comp EVO, or something else ? |
Posted: Sun Apr 19, 2020 6:24 am Post subject: Re: Help on deciding on engine specs |
Alstrup wrote: |
MitchS046 wrote: |
sorry had to be an CSP super competition exhaust stupid autocorrect |
Posted: Sun Apr 19, 2020 6:25 am Post subject: Re: Help on deciding on engine specs |
MitchS046 wrote: |
Added that i want to use an FK-8 cam and a CSP super competition exhaust accidentally forgot it😅 |
Posted: Sun Apr 19, 2020 6:36 am Post subject: Re: Help on deciding on engine specs |
With the regular std Super comp definitely stay 2054. - 74 stroke.
With the 42 mm Super comp Evo 2165 is ok |
