What have you done (to your bus) on quarantine?
Page: 1, 2, 3, 4, 5  Next
electronictofu
electronictofu is offline
PostPosted: Sun Apr 19, 2020 4:41 pm    Post subject: What have you done (to your bus) on quarantine? Reply with quote
Thought we could start a fun post.
What have you put off for years (with your bus) that you've finally gotten to?
Also, what do you plan on doing, this upcoming week?
Photos encouraged! Feel free to comment by number below.
I'll get the ball rolling:
1) Finally replaced door seals and felts, LOVE IT.
2) (In process) of fixing 2 rear dents/ block sanding filler
3) Might consider shortening my bumper brackets, they need work anyways, to "tuck" the bumpers in closer to the body.
Stay safe cool peeps!
GeorgeA
GeorgeA is offline
PostPosted: Sun Apr 19, 2020 5:43 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Installed a headliner and new interior in my ‘66
Malokin Martin
Malokin Martin is offline
PostPosted: Sun Apr 19, 2020 5:47 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Perhaps not the bus, but I did finally get the signs up. My neighbor is likely less than enthusiastic.
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sun Apr 19, 2020 5:58 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
First off...nice bus and great idea for a thread.
As far as your bus plans go, well done on starting back at it. It does feel good to complete something that you've put off far too long.
Your plans for the bumper gap...best investigate that one before diving in.
I know all the hot rod shows make a real point out of taking up that gap. Foose, Kindig and The Count all love to fix that problem.
The problems you'll run into with just shortening the brackets are: splash pan alignment, or support bolt alignment. And, the bumper can't just come closer in one direction. The bumper would need to be cut and shortened to take up the side gap as well or it would just look like it was already in an accident. The level of skill it takes to do this correctly and not look weird is way up there. So, dive in and do it if you want, but go in with your eyes open.
As far as my bus goes, I'm considered essential services and am still working, but with abbreviated shifts. This has given me a bit more time to work on my bus, which is in the ninth year of it's project status.
Stay safe people, you bus won't give you covid, so you know where you should be.
gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
electronictofu
PostPosted: Sun Apr 19, 2020 6:07 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Good lord that's hot!
electronictofu
PostPosted: Sun Apr 19, 2020 6:08 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Your plans for the bumper gap...best investigate ....
Yeah the more I look at it, and the corners, it would be a pretty tough challenge, def. more so than looking at it at a glance and be like "Sure I'll just cut off an inch and be done" ha... not quite, interesting idea, probably will keep at cleaning up my body work and finishing my interior.
electronictofu
PostPosted: Sun Apr 19, 2020 6:09 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Laughing Love it!
VWAdam
VWAdam is offline
PostPosted: Sun Apr 19, 2020 7:26 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
I'm still essential so I've just driven it to work some and to the grocery store.
Driving my Bus is therapeutic. It's my little escape from life's complexities, so driving it has helped me stay sane and keep some normalcy.
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
62DoKaGuy Premium Member
62DoKaGuy is offline
PostPosted: Sun Apr 19, 2020 8:17 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Removed engine and replaced a stripped oil cooler stud, which had let oil into the fan and promptly distributed throughout the engine compartment. Cleaned up whole engine of oil, replace soft lines since I was there and all accessible. Cleaned and adjusted spark plugs, basically checked and cleaned/tightened everything. Reinstalled engine and drove the piss out of it, then had a leaky passenger side valve cover gasket - damnit - replaced that, then continued on driving.
Not quarantined and still working, but the timing was right for something to need fixin’. Going to remove and re-install a rebuilt steering box next weekend, then all tierods, draglink, dampener, and shocks. My double cab gets better maintenance than anything else I own hahaha
Wenige Menschen denken, und doch wollen alle entscheiden.
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
4/59 Single Cab
langsmer
langsmer is offline
PostPosted: Sun Apr 19, 2020 10:36 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Well, I had my 65 shipped from storage in Oregon to my new house in Colorado where I'm from. Showed up a few days ago. Got the engine out last night to pull the tins off to replace the oil cooler seals, clean out the heat risers, clean the long block, etc. Got the parts to rebuild the brakes with a dual circuit master in the mail. Hopefully it will be ready to take into the mountains for some social distancing in a few weeks.
npbusguy
npbusguy is offline
PostPosted: Mon Apr 20, 2020 2:12 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
I've been driving my bus as much as possible in Poland's beautiful spring weather, but as far as projects are concerned, I wired up my clam shell lights.
Installed and wired my water pump
And installed my breadbox
I also researched and found some of the parts for my future projects.
Looking forward to more inspirational posts, keep up the good work.
perello
perello is offline
PostPosted: Mon Apr 20, 2020 4:27 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Changed oil
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
vwuberalles
vwuberalles is offline
PostPosted: Mon Apr 20, 2020 10:12 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
My bus is at my parent's place 200 miles away, but dad has been cranking away on the cargo doors metalwork! I've knocked out the gauges and some other things on my drift car. My next project is building a Westfalia-style table for my Previa. I may even finally get to the brakes on my 66 bug!
1973 Superbeetle: 1st car, owned since age 12.
1966 Beetle: My new project. Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040
electronictofu
PostPosted: Mon Apr 20, 2020 10:59 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
I am looking to do similar, and make my interior, not really a camper, but something a little more "hang out" friendly for outtings, table, or shelving, extra seat across from my "rock n' roll bed/ bench"
That green bus getting up on the the lift, what a great photo!
c21darrel
c21darrel is offline
PostPosted: Mon Apr 20, 2020 11:59 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
tail light holes caught my eye. And frenched lic plate spot.
GhiaBuild
zozo
zozo is offline
PostPosted: Mon Apr 20, 2020 12:02 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Fixed "Joy" as she's called. She was naked. I was bored. I sort of sprung it on her. Pun intended.
I also stuck a neodymium magnet on the bottom to mount her on the dash.
electronictofu
PostPosted: Mon Apr 20, 2020 6:20 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Compliments of the previous owner in the 90's. Not something I would have done but I've grown to love her for all of what she is. My bus also had suicide doors (done incorrectly) it was terrible, first thing I changed back as the new owner.
hitest
hitest is offline
PostPosted: Mon Apr 20, 2020 7:12 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
She makes all your oilers happy Cool
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '68 L30k 141, '71 L12 113, '74 ORG 181
FU#5
Help Help
Help Help is offline
PostPosted: Tue Apr 21, 2020 8:59 am    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
1) Changed out the radio head unit.
2) Started messing with a bamboo headliner (a little different than the usual).
And tonight I'm going to pull the engine to look at the heads/cyls and probably replace them and change out my fuel sending unit.
electronictofu
PostPosted: Tue Apr 21, 2020 2:03 pm    Post subject: Re: What have you done (to your bus) on quarantine? Reply with quote
Did you buy a bamboo kit or going from scratch? Ive looked into this myself. I tried birch, but I couldnt get it to bend the way I needed, maybe too thick.
Page 1 of 5
