marlinmatt Samba Member
Posted: Thu Apr 23, 2020 8:26 am Post subject: Brake Confusion on my Buggy, Can't ID |
I think I posted this in Gallery by mistake. I'll try again. New to this...
Anyhow, I'm restoring a Manx buggy, and in trying to rebuild the brakes, I have had trouble figuring out which parts to get. Probably a mishmash of years on this thing, like other parts I've run into. It's a linkpin beam, and transaxle rear end.
Part numbers:
front 111 405 615 also,10.7.57,if that is significant. Has double bolt cylinder
Rear 113 501 616C single bolt cylinder.
Maybe someone with more experience can look at these and say Ah Ha! Maybe a clue that I'm not aware of in there somewhere....
Thanks for any help!
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
jsturtlebuggy Samba Member
Posted: Thu Apr 23, 2020 11:05 am Post subject: Re: Brake Confusion on my Buggy, Can't ID |
Your rear brakes are from I think 1965 to 1967 because of the brake shoes have a angle on end that fits into adjuster that has angle on it too. Earlier brakes shoes from 1958 to I think was 1964 used adjusters with straight ends where shoes fit.
Front brakes are 1957 and earlier, I not remembering how early at the moment.
Yes with buggies you never know what you will find that has been done to them by people using the parts they had.
Also the rear bearing retainer/ seal retainer the end that sticking out further is for if seal starts leaking oil with go out backing plate instead onto the shoes. You should see a hole in backing plate that matches up with the hole in the retainer at the bottom. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Apr 23, 2020 12:09 pm Post subject: Re: Brake Confusion on my Buggy, Can't ID |
VW XXX-XXX-XXX (plus alfa character) part numbers whenever possible...
dustymojave Samba Member
Posted: Thu Apr 23, 2020 6:29 pm Post subject: Re: Brake Confusion on my Buggy, Can't ID |
By "transaxle" did you mean "swingaxle"? ALL VWs have a transaxle. Even front wheel drive VWs have a transaxle. That's where the transmission and differential/axle are in one housing.
That rear drum is a 1966 or 1967 drum. The rear brake backing plate is lacking the parking brake cable and lever arm and cross bar. _________________ Richard
SoCalBajas Member
Posted: Fri Apr 24, 2020 5:54 am Post subject: Re: Brake Confusion on my Buggy, Can't ID |
Yes indeed, swing axle is what I meant. and thanks! I finally figured out the brake parts and got them ordered. First time dealing with brakes, it definitely got interesting!
Is it terribly difficult to add an entire parking brake setup? Mine is completely gone, except for the tubes through the frame with the (Cut off) cables inside.
I see various pieces available, but lack the "Overview". Is there a kit available? |
Posted: Sat Apr 25, 2020 11:18 pm Post subject: Re: Brake Confusion on my Buggy, Can't ID |
Replacement hand levers are available new from EMPI. Chrome is an option. The bracket at the tunnel could easily be fabricated of bar stock or cut off a pan that is being cut up for building a rail or something. The cable assemblies are available new also.. The parts inside the drum are sure to be available from other in the classifieds or via the forums here. And that's about all there is to it
As an entire kit...nope. _________________ Richard
SoCalBajas Member
