markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Thu Apr 23, 2020 12:07 pm Post subject: What is this strap? In trunk - (photo included) |
Gents-
I thought the strap tacked on the inside wheel well was for the washer fluid bottle. But mine has the kind that attaches to the tire.
What would be put there? I don't know what to search for.
Thank you
-Mark
Xevin Samba Member
Posted: Thu Apr 23, 2020 12:18 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Charcoal canister
https://www.thesamba.com/vw/forum/viewtopic.php?t=...686e1507b3
Edit: just has another look at your photo. See my second post. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Thu Apr 23, 2020 12:19 pm Post subject: Re: What is this strap? In trunk - (photo included) |
And details of the whole system
https://www.thesamba.com/vw/forum/viewtopic.php?t=...4b34d96f50 _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Thu Apr 23, 2020 12:21 pm Post subject: Re: What is this strap? In trunk - (photo included) |
I have never heard of this ... thanks for the thread.... |
Posted: Thu Apr 23, 2020 12:23 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Xevin... do people still use this? Do you know if I could live without it? I don;t mind chasing one down, just curious hos "serious" the component is. |
Xevin Samba Member
Posted: Thu Apr 23, 2020 12:27 pm Post subject: Re: What is this strap? In trunk - (photo included) |
markeaton wrote: |
Please use second link for the info. Should make more sense. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Thu Apr 23, 2020 1:27 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Doing some reading on the thread Xevin posted... (thanks to AlmostHeavenWV_VW, lot of work)
Looks like the straps I am referring too are actually the expansion chamber and the charcoal canister goes on the right and rear side of the beetle. One more item to search for... great thread. |
Xevin Samba Member
Posted: Thu Apr 23, 2020 2:03 pm Post subject: Re: What is this strap? In trunk - (photo included) |
markeaton wrote: |
Yep. Caught myself when I read your post title a second time
Big thanks to AlmostHeaven for that great write up and being an all around good guy. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Thu Apr 23, 2020 2:07 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Almostheaven is awesome. I have learned a lot from him. And having a 1973 Standard Beetle like him, helps !!! |
sb001 Samba Member
Posted: Thu Apr 23, 2020 3:13 pm Post subject: Re: What is this strap? In trunk - (photo included) |
markeaton wrote: |
It was my understanding the early models that used one (I think maybe 70-71, not sure) the charcoal canister WAS located in the hood and that's what your strap is for.
Is that not the charcoal canister itself in the photos in AlmostHeaven's thread?
I have always thought the expansion chamber was something completely different- it was the long tubular plastic piece that sits under the top back side of the dashboard inside the trunk. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Thu Apr 23, 2020 3:52 pm Post subject: Re: What is this strap? In trunk - (photo included) |
sb001 wrote: |
markeaton wrote: |
I have always thought the expansion chamber was something completely different- it was the long tubular plastic piece that sits under the top back side of the dashboard inside the trunk. |
Ya sb001....I am still going through all the threads to see the parts I need and position for everything. A lot of work ahead of me I had no idea I had awaiting me |
sb001 Samba Member
Posted: Thu Apr 23, 2020 4:18 pm Post subject: Re: What is this strap? In trunk - (photo included) |
markeaton wrote: |
Here is another thread that might help you out if you hadn't come across it already:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Thu Apr 23, 2020 4:31 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Yes thanks.... It was embedded in Almostheavens.... so much great information here to the novice guys like me. |
Double-Double Samba Member
Posted: Thu Apr 23, 2020 4:43 pm Post subject: Re: What is this strap? In trunk - (photo included) |
My 70 had one inside the trunk and another inside the passenger rear wheel well area. I took them both off and ground off the straps. Makes the fuel system muuuuuuuch simpler! |
Posted: Thu Apr 23, 2020 4:46 pm Post subject: Re: What is this strap? In trunk - (photo included) |
Double Double.... did you gauge what they were like prior and after? Any noticeable difference? Just curious.... |
Posted: Thu Apr 23, 2020 4:56 pm Post subject: Re: What is this strap? In trunk - (photo included) |
markeaton wrote: |
Negative. Car hasn’t run in a year or greater... (current state of car)
However, if the system is working properly and not clogged you shouldn’t get any noticeable difference whatsoever. I got rid of my system and converted to an earlier 30 PICT-1 carb so I could get rid off all this and the altitude correction and throttle position emissions garbage. I want my car as simple as possible. |
