dkoesyncro Samba Member
Posted: Tue Aug 04, 2020 11:13 am Post subject: Re: Uberaudi's lo-pro ABA swap |
The best I had gotten was a whopping 24 mpg headed home on I5 from Canada after Dela4, cruising speed was 65 and my afr gauge was reading an average 15.2.
Stock syncro running 215/75/15, ABA-T |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Tue Aug 04, 2020 2:19 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
vwhammer wrote: |
dkoesyncro wrote: |
Mmmmm. ABA-Teeeeeeee (in my best Homer Simpson voice)
You can bet that the turbo part of my built will come very shortly after I get my pile running and on the road. |
You do have to recalibrate your right foot with the turbo. I found with mine that I get about the same mileage, in some situation even 1mpg more, than with the NA version if I drive it the same. If I drive it like it begs to be driven, well, almost no mileage is too low
Took a while for reality to reassert itself... _________________ '86 Westy FAS GenV Turbo (Marvin) |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 501 Location: Hi-top Country
Posted: Tue Aug 04, 2020 2:42 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
I bet! Are you using the quick and dirty chip tune, injectors, and 3" maf setup or are you on standalone? _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Posted: Tue Aug 04, 2020 5:22 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
uberaudi wrote: |
I bet! Are you using the quick and dirty chip tune, injectors, and 3" maf setup or are you on standalone? |
If you're replying to me, I'm not running an ABA - I was going to go that route originally, but ended up working much more than I thought (meaning road warrior life) so I started looking for turnkey packages and ending up with the FAS GenV which is an AVH engine. They developed the setup and tune with drive by wire. Mine has the smallest frame Precision turbo, and is intercooled. My waste gate (external) is set at 14 psig, but I normally see around 2 psig just running around town. Personally, I very rarely ever exceed 5K RPM and the most boost I have at that rpm is 9'ish depending on throttle angle.
You really don't need much boost to get some really significance performance improvement. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Tue Aug 04, 2020 9:30 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
I started off obd1 w/ a chip an eBay turbo manifold and a T25 Saab turbo. This evolved slightly but died to the potential from obd2, also chipped from UM. Fred had de-tuned his shelf tune but yes this was the larger maf, injectors.
I then got the Audi intake and wanted to hybrid-ize, I sold off the obd2 stuff and manipulated the AEB 1.8T harness. This is working and so far I'm not convinced I can't make it better....I'll be going stand alone shortly, wide band and map based,I can't wait. |
Posted: Wed Mar 31, 2021 9:24 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
Exhaust drone can make anyone go insane after enough miles of listening to it.
So was the case for me and the latest exhaust I worked (reworked) up for this ABA swap. After a few hundred miles the inexpensive Amazon resonator decided to stop fulfilling it's duty and the terrible noise returned. Drone. A brain hemorrhaging harmonic that ranged from 3.5-4k...my typical cruising rpm. Something had to be done.
I found a muffler from Vibrant that seemed to advertise what I wanted. Stainless, center in and out, and packed to the brim with stainless sound absorbing material. So I ordered up two of them. Inspired by VWhammer's hose clamp muffler strap method, I went to work on the new mounts.
I also beefed up the factory oil pan exhaust bracket with another factory mount as I noticed the old style single plane mount was taking a beating and was about to fail.
Here's the old setup in front and the new Vibrant's in the back. They basically fit in the same space, but the new cans are on either side of the crank pulley instead of occupying the space in front of it.
Mounts ready to go
New exhaust strapped up with stainless bands
The worst thing about exhaust work is you really don't know how loud or quiet it's going to be until you're done, but I'm fairly satisfied with how it turned out. I lost a little ground clearance, but I also lost the drone which was my main objective. The reinforced mounts should hopefully keep it together, longer, but you never really know do ya?
In two days I leave for a 2k+ mile desert trip for some solid backroad shenanigans. If it survives that, then I'll deem it a success. _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5076 Location: denver
Posted: Thu Apr 01, 2021 7:35 am Post subject: Re: Uberaudi's lo-pro ABA swap |
uberaudi wrote: |
In two days I leave for a 2k+ mile desert trip for some solid backroad shenanigans. If it survives that, then I'll deem it a success. |
Damn that's pretty. Stop by Denver on your trip and re-do my exhaust for me? _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
4Gears4Tires Samba Member
Posted: Thu Apr 01, 2021 8:24 am Post subject: Re: Uberaudi's lo-pro ABA swap |
I wonder if oval cans at 45 degrees (overhanging) would have gotten you your departure angle back.
Really pretty work. Looks great. _________________ '87 Syncro
That's a whole lot of muffler and your mounts look way more thought out and beefier than mine.
I assume that they are aluminum?
For mine I just kind of winged it and got what I got but hopefully mine hold up.
Are those the factory style vibe isolators you are using?
My isolators are a bit finicky when trying to get the bolts tight on them so maybe I should look at some of those.
Since I still have not started mine yet, I am hoping that the cat in my system coupled with the muffler is quiet enough but I suspect it's going to be pretty loud.
I like the idea of a straight through style muffler for performance but perhaps one of the big round truck style mufflers that some people have used would be better at making it quieter.
I have even considered building my own muffler so I can make it fit and sound the way I want but as you mentioned it's hard to say what it will sound like until it is done.
Anyway your system looks pretty nice. _________________ Pretty normal daily driver build
https://www.thesamba.com/vw/forum/viewtopic.php?t=708418&highlight=
4x4 build
https://www.expeditionportal.com/forum/threads/volkswagen-vanagon-4x4-conversion.162055/ |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12114 Location: Port Manteau
Posted: Thu Apr 01, 2021 8:40 am Post subject: Re: Uberaudi's lo-pro ABA swap |
Wow! That's way prettier than it needs to be, and beefy too.
I still need to figure out how to hang my exhaust from the engine, rather than the body. My 15 degree install will require outriggers to carry the exhaust like yours. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Thu Apr 01, 2021 12:00 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
That looks really well done, nice work! I've got a porter resonator and its surprisingly smooth but my van is still built like a WW2 bomber (tin can). I'm hoping when the interior is done it'll quiet. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Thu Apr 01, 2021 12:16 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
As usual, super great fabrication! That mid point access to pulley is a great idea.
Some unsolicited thoughts.
Are wide exhaust mounts meant to help stabilize motion of the resonators to prevent possible "premature" failure at tube between resonators?
That added 4th isolator should really help. ?Waldo? has done same. My 50º ABA DV type exhaust recently had the single passenger side isolator fail early.
I now feel a bit of a wiggle play at my longer than stock tail pipe on Ernst 1.9 WBX muffler. I now wonder if a long tail pipe invites premature wear either at outlet tube to muffler body or at some point inside muffler.
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Apr 01, 2021 1:16 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
Vanagon Nut wrote: |
I went through the trouble of making a long tail pipe only to bail on it at the last minute as it certainly seemed like it would be an added stress on the rest of the system and I did not want to build a mount that hung only the tail pipe from the body.
Quality exhaust materials help but I feel that building an exhaust is all about allowing for expansion and contraction of the whole system as well as eliminating low frequency vibration.
I guess that seems totally obvious now that I have said it. _________________ Pretty normal daily driver build
4x4 build
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Apr 01, 2021 8:30 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
this thread is awesome.
I like the back bumper a lot. especially those fat tow hooks.
What are the ports to the right of the license plate? nice frame btw |
Posted: Thu Apr 01, 2021 9:45 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
Thanks for the kind words fellas!
Even though redoing the back section is somewhat of a time consuming ordeal, it is satisfying when it's complete...as long as this is the last time damnit. I'll be using the other 'gen2' setup for a 1z tdi
swap which will also mount at 50 degrees using most of the same componants. It should be a bolt in affair. So technically, I didn't really waste any effort since I would have to make a new system for the other swap right? Riiiigghhht...
The mounts are 1/8 x 3" steel strap, with a few dimples for good measure. I've been trying to add structure and reduce weight in more and more of my projects and dimples do a good job at that. The reason I went so wide is because of the two factory mounts on the driver's side. In order to cover them both with the same width of material, I had to go to a wider 3". I figured additional surface area that the cans rested on would only help. Because they're boxed and only 1/8", the mounts are surprisingly light for how torsionally stiff they are. I hope these are the last ones I'll need to fab.
The driver's side factory rubber mounts were still in good shape so they got reused, but the single passenger one was torn. I have a feeling that the longer tailpipe influenced its destruction. So now, I'm using four of the factory mounts. Last time I ordered they were about 10 bucks a pop....not something I want to burn through every 4k miles.
The mounts and muffler system are most definitely stiffer all all-round then the previous version. Hopefully they still have enough compliance so other components don't get overworked.
The bumper is about 50lbs overweight but the price for the material was right, therefore throwing the whole 'lightweighting' idea out the window. Those clevis mounts are 1" thick lol...I don't even think hardcore Jeepers need that level of beef. The top 'port' is the Schrader valve for the Hi-Jacker air shocks, and the lower one is the trailer connection. The plate frame came from a junkyard _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Posted: Thu Apr 01, 2021 10:24 pm Post subject: Re: Uberaudi's lo-pro ABA swap |
Where are you on your 1Z project. I just want to be sure I can get my act together and not impede your progress with the small part I'm playing. I can't wait to see what you do with that project. _________________ Casey--
y u rune klassik? |
Posted: Fri Apr 02, 2021 8:08 am Post subject: Re: Uberaudi's lo-pro ABA swap |
Had some unexpected house projects come up so the van got pushed out to the driveway again. I hoping by the end of summer it will be driving out of the garage....lots to do yet. _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
