Oct52zwitter Samba Member
Joined: December 28, 2013 Posts: 5 Location: Tavistock,Devon UK
Posted: Sat Apr 25, 2020 1:49 pm Post subject: Weird contraption on generator |
Hi I wonder if anyone might know what this does or may have seen anything like this before it's welded onto the fan nut on the end of my generator. I've probably got 30 thousand miles on the car and it's not affected anything but I've always wondered what it's for. If anyone could enlighten me that'll be great .
Danwvw Samba Member
Posted: Sat Apr 25, 2020 2:04 pm Post subject: Re: Weird contraption on generator |
Wow, Wonder what whoever made it was trying to have it do? It obviously conserves momentum. Looks like it needs Oil. Maybe increases MPG's. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sat Apr 25, 2020 3:35 pm Post subject: Re: Weird contraption on generator |
Is it an early clutch device to disengage the fan. Maybe during warm up? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
chthemonkey Samba Member
Joined: July 30, 2008 Posts: 105 Location: united kingdom
Posted: Sun Apr 26, 2020 4:46 am Post subject: Re: Weird contraption on generator |
could it be a homemade balancer where weights screw into those holes |
geneL3c Samba Member
Joined: October 08, 2007 Posts: 296 Location: Bridgehampton,NY
Posted: Sun Apr 26, 2020 9:02 am Post subject: Re: Weird contraption on generator |
Whatever it is, it can't be doing any favors to the rear generator bearing ! Might be something that someone forgot to remove ? |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Sun Apr 26, 2020 11:00 pm Post subject: Re: Weird contraption on generator |
geneL3c wrote: |
Have to agree with genel3c, this will cause vibration problems and I would be removing it. Get some new bearings into it and check the bearing bore for wear. _________________ [url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL] |
Posted: Mon Apr 27, 2020 12:44 pm Post subject: Re: Weird contraption on generator |
Thanks for all the replies and ideas what it could be. It's now been removed. I couldn't get my grinder to reach the welds on the nut so had to chop it up into bits. I was wondering if it was fitted to an industrial engine at some point . I guess the only guy that knows is the one who made and fitted it. |
yellowcrawler Samba Member
Posted: Mon Apr 27, 2020 5:17 pm Post subject: Re: Weird contraption on generator |
It reminds me of a speed governor. It looks like the weights were removed. As the speed would increase, the bar in the center would slide away from the generator, towards the spring from centrifugal force. But why was it done? |
Posted: Mon Apr 27, 2020 8:49 pm Post subject: Re: Weird contraption on generator |
If it was a governor of some kind, I doubt it would fit into an engine compartment, so the industrial engine theory would make sense. |
Wade Samba Member
Joined: February 13, 2007 Posts: 125 Location: NorCal
Posted: Mon Apr 27, 2020 9:57 pm Post subject: Re: Weird contraption on generator |
OK. I'll play. . I say that the stock rear fan nut that you can see has been gutted such that it somehow holds the fan simply by pressure from the added spring thing. So, when the fan gets going fast enough, the centrifugal force of the weights on the device pull the nut rearward, thereby releasing the fan and letting it spin freely.
Not sure why you'd want to do that, but it's all I can come up with.
-Greg |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 767 Location: New England
Posted: Wed Apr 29, 2020 8:56 am Post subject: Re: Weird contraption on generator |
Oh,Oh! I have a guess! I think it might be some sort of ball governor missing the weights (balls). But instead of dis-engaging the fan it would push on a rod fitted into the hole on the end of the shaft. As the speed increased the more it pushed. As to what the rod was connected to... Throttle? Some sort of homebuilt flyball tachometer? Who knows. |
sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Wed May 27, 2020 3:46 am Post subject: Re: Weird contraption on generator |
Yes thats a centrifugal governor. But if its welded to the nut which is screwed onto the dynamo shaft then its not releasing the fan, so I expect there was a rod down the centre that engaged with something. Might have beed an industrial engine set up at some point. Maybe a speed vs load device. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Thu May 28, 2020 12:00 pm Post subject: Re: Weird contraption on generator |
Clean it up a little bit. After you have it cleaned up hold the pulley where the belt connects and then try to turn it to see if it puts pressure on the spring. _________________ www.vwnos.com [email protected]
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Thu May 28, 2020 1:59 pm Post subject: Re: Weird contraption on generator |
That spring looks pretty well compressed already. The problem is with this contraption being in the situation it is, it will impede the airflow into the eye of the fan, and reduce the output. Appears to have been designed and built by a certain Mr Heath Robinson! |
