SandHamwich Samba Member
Joined: April 26, 2020 Posts: 95 Location: Orangevale
Posted: Mon Apr 27, 2020 5:20 pm Post subject: Sams 1968 California KG project |
Hello! My name is Sam. I’m from Northern California and I’ve been a long time ACVW fan since I was a kid. It’s been many years since my last T1 and I’m excited for this New project.
1968 all original California survivor!
Runs drives and stops but there will be lots of work done very soon. Everything original. Engine code says H5 indicating early 1968 build date.
I’ll be doing my best to update regularly.
Thanks for looking!
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Mon Apr 27, 2020 6:08 pm Post subject: Re: Sams 1968 California KG project |
Nice paint job. And the car is nice too.
Welcome to the '68 club. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Mon Apr 27, 2020 6:10 pm Post subject: Re: Sams 1968 California KG project |
So far from I can tell it has a narrowed, lowered beam with adjusters. The adjusters look to be the ‘heavy duty’ style, not puma. However, they were welded in pointing nearly straight down. I’m surprised they haven’t been completely ripped off by an angry pot-hole by now.
I may eventually put an unmodified (rebuilt) beam back in with drop disc spindles.
Another immediate concern is the shifter being extremely wobbly. Difficult finding 1 and 2. My guess is the bushing is toasted. So that appears to be first on the list of repairs.
The speedo also was bouncing all over on the freeway until it stopped completely. My guess was it needed lubricant until it might have broken all together. Time to investigate the cable. |
Posted: Mon Apr 27, 2020 6:13 pm Post subject: Re: Sams 1968 California KG project |
kiwighia68 wrote: |
Welcome to the '68 club. |
Thank you I’m happy to be in the club!
Anything specific to ‘68 that I should be aware of? One year only features? |
Posted: Mon Apr 27, 2020 7:24 pm Post subject: Re: Sams 1968 California KG project |
SandHamwich wrote: |
kiwighia68 wrote: |
The seats are one-year only - apparently unpopular everywhere. I replaced (but kept) mine with Porsche 924 seats. Disk brakes in front and 1500 motor. Small blinkers in front, small taillights at the rear. I would say it was a good year - but I may be biased. _________________ Festina lente - hasten slowly
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Mon Apr 27, 2020 11:46 pm Post subject: Re: Sams 1968 California KG project |
Welcome to the Forum Sweet ride you have there! All things considered, 68 may be the best model year, as it has the old look but with improved gear underneath Enjoy it! _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
LVGhia72 Samba Member
Joined: April 22, 2020 Posts: 282 Location: Lost Wages
Posted: Tue Apr 28, 2020 9:29 am Post subject: Re: Sams 1968 California KG project |
Nice find. Looking forward to follow your journey. |
Ant B Samba Member
Joined: December 24, 2019 Posts: 157 Location: surrey, UK
Posted: Tue Apr 28, 2020 11:50 am Post subject: Re: Sams 1968 California KG project |
Love it sir.
mine is a 68 too.
i will be following with anticipation.
Ant |
Posted: Tue Apr 28, 2020 4:46 pm Post subject: Re: Sams 1968 California KG project |
Took some pics today and gave it a quick inspection. Very very little rust. Overall this thing is in amazing shape.
There is one major area of concern and that’s the rear quarter(s). There seems to have been a collision and lots of body filler. Not a professional job either. Eventually I’m sure I’ll be replacing the outer skin of the entire right rear section. Not something I’m totally afraid of but also not something I want to dive into right away.
And it’s all there! A complete CA original. Interior looks to be all original.
Here’s some pics:
Posted: Tue Apr 28, 2020 5:26 pm Post subject: Re: Sams 1968 California KG project |
It looks good. Some OG parts still on it like the washer bottle and horns etc... Hopefully, the rust areas around the inside and outside of the rear glass don't become a huge rabbit hole. If you know what I mean. I will certainly enjoy watching your progress on the Ghia. |
Posted: Mon May 18, 2020 10:42 am Post subject: Re: Sams 1968 California KG project |
So I decided to do the first repair on the car. The dreaded shift rod bushing and coupler. It wasn’t nearly as bad as I want expecting, having read all the tech articles about it.
What did make it difficult was the top beam adjuster sitting right in front of the access hole. Since the shift rod is bent it had to be ”encouraged” to be removed. I had to partially disassemble the adjuster to get clearance.
I also measured the beam to see what was what and it looks like it’s 31’’ across at the center seam of the towers, so apparently stock width. The adjusters are pointing straight down so I’m assuming it was turned to get the front to drop.
I have acquired another unmodified beam that I’m planning to rebuild with drop spindles, eventually.
Under the back seat revealed some rusty pans but so far this is the only rust I have found. The heater channels looks great. It does look like the front was too low at one point and beat up the body under the nose cone. One more thing to fix!
Here’s a few more photos.
And lastly...my father in laws newest project. A one owner 1967 Triumph GT6! I have a lot of history with this very car. It belonged to a long time friends dad so I’ve been drooling over it for almost 30 years. He finally decided it was time to part with it so I felt I had to find it a new home.
Hopefully this doesn’t take up too much Ghia time haha!
Posted: Mon May 18, 2020 11:00 am Post subject: Re: Sams 1968 California KG project |
The radio tag is a nice piece of history. It has a date and address on it. I would preserve that, as it dates and identifies the cars location back in the day. |
Posted: Mon May 18, 2020 11:31 am Post subject: Re: Sams 1968 California KG project |
LVGhia72 wrote: |
Yeah I was surprised to see it still intact. There’s a few other bits of paperwork that was in the car as well like the original dealer receipt.
I purchased it in San Francisco area and I don’t think it ever left until now. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Mon May 18, 2020 6:55 pm Post subject: Re: Sams 1968 California KG project |
If you use a stock beam with dropped spindles they might ad width and could create a tire rub issue with the outer fenders. Im not positive but I think that CB dropped spindles ad 5/8” per side. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Tue May 19, 2020 1:08 pm Post subject: Re: Sams 1968 California KG project |
lonotch wrote: |
If you use a stock beam with dropped spindles they might ad width and could create a tire rub issue with the outer fenders. Im not positive but I think that CB dropped spindles ad 5/8” per side. |
Thanks for the info. From what I’ve been reading on here, most say the spindles will add width but unclear on how much. Maybe I should consider narrowing by 2’’ if I do add spindles? |
kingkarmann Samba Member
Posted: Wed May 20, 2020 7:35 am Post subject: Re: Sams 1968 California KG project |
Thanks for looking!
Great find and welcome!
You in the "Witness Protection Program"? _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
c21darrel Samba Member
Posted: Wed May 20, 2020 10:04 am Post subject: Re: Sams 1968 California KG project |
Thanks for the tip, that convinces me. I do want as wide of a tire as possible. My wife has a lead foot!
And as for the face, I was drawing in
Procreate while I was forum surfing. It was a rainy day... |
scottandhis68 Samba Member
Posted: Fri Aug 28, 2020 4:50 pm Post subject: Re: Sams 1968 California KG project |
68 would have had a wood veneer dash face. Paint looks good too. Just a preference. Also it would have had round reflectors on the rear quarter panels. Also something some people remove and weld up. Good luck and have fun. Make it your's. How you like it. |
Posted: Fri Aug 28, 2020 4:52 pm Post subject: Re: Sams 1968 California KG project |
Also, be glad you have good bumpers, trim, and seats. Good bumpers are hard to find. Seats are one year only so those are hard to find too. |
