malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Tue Apr 28, 2020 5:25 pm Post subject: Valves are chipped |
72 1.7 has been sitting in my garage for two years. Gotta take the heads off to fit under my house for the next project. So here we are. What caused the 1 and 3 ex valves problems? #1 piston has a nick. #3 is good. Not sure why this bus had not moved on it’s own power in 30years. These nicks would not stop it.
_________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Tue Apr 28, 2020 5:32 pm Post subject: Re: Valves are chipped |
valve stuck open due to many causes and tagged a piston. That made a hell of a racket and scared the owner who parked it. Or the seat came out, held the valve open and the piston hit the valve, then the seat dropped back in and it is like you see it. That made a heck of a racket too if it happened. The heads have to be rebuilt and there aren't too many people who do a good job of that anymore. The piston set will get replaced, and the rod checked to see if it has any bend to it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Apr 28, 2020 5:36 pm Post subject: Re: Valves are chipped |
Strange to me that it is 1 and 3. Across from one another. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51123 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Apr 28, 2020 6:03 pm Post subject: Re: Valves are chipped |
malcolm2 wrote: |
Strange to me that it is 1 and 3. Across from one another. |
Not strange at all, they are the furthest away from the fan and most starved for cooling. Add in some vacuum leaks and hippie abuse and sometimes things far worse than that happen.
There's so many little things wrong in those chambers there's no way I'd put them back on without some professional work on the heads first. And as Steve says the pistons and rods are also suspect too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Apr 28, 2020 6:05 pm Post subject: Re: Valves are chipped |
I am going to guess that your two damaged exhaust valves are some kind of cheap aftermarket crap. Doesn't look like the valves contacted anything to me, but that they couldn't stand the normal conditions to be found in a VW aircooled engine.
Two of your cylinders have one brand of exhaust valve that is junk and your other two exhaust valves are a different brand and seem to be holding up well from what little we can see of them.
SGKent Samba Member
Posted: Tue Apr 28, 2020 6:07 pm Post subject: Re: Valves are chipped |
malcolm2 wrote: |
Maybe he was headed down a mountain grade at the time it happened. You know what they say, Sh_t rolls downhill............. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21511 Location: Oklahoma City
Posted: Wed Apr 29, 2020 1:58 pm Post subject: Re: Valves are chipped |
While I agree...the ding in the piston is similar to what a valve striking the piston can make...I have NEVER seen a steel valve chipped by an aluminum piston.
And...I have ever seen a valve that has struck a piston that has NOT gotten a bent stem.
However....if the engine "swallowed" something....like a nut or stud....you "could" chip a valve AND ding a piston. But...usually that results in many little dings in the piston.
I am betting it was detonation. Ray |
SGKent Samba Member
Posted: Wed Apr 29, 2020 2:36 pm Post subject: Re: Valves are chipped |
raygreenwood wrote: |
Everyone assumes it was one thing only. Could be really cheap metal in the valve along with something else. I didn't see classic detonation damage on the head or piston - but in all my thousands of heads worked on I have never seen damage to a valve like that - where it flakes off in areas. More like someone prying on it to get it open. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Apr 30, 2020 6:59 am Post subject: Re: Valves are chipped |
busdaddy wrote: |
malcolm2 wrote: |
There's so many little things wrong in those chambers there's no way I'd put them back on without some professional work on the heads first. And as Steve says the pistons and rods are also suspect too. |
Out here we have more dead Volkswagens parked on farms and ranches than anywhere else, so if the hippies were abusing them, they were sneaking on to the old German farmers’ homestead at night to do it. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Thu Apr 30, 2020 7:19 am Post subject: Re: Valves are chipped |
SGKent wrote: |
Everyone assumes it was one thing only. Could be really cheap metal in the valve along with something else. I didn't see classic detonation damage on the head or piston - but in all my thousands of heads worked on I have never seen damage to a valve like that - where it flakes off in areas. More like someone prying on it to get it open. |
Yep....never seen damage like that. Agree....could be a combination of things. But....you can take an exhaust valve (or intake).....anyones valve. Use it as drift with a hammer....to beat holes in "aluminum" pistons all day every day.....and you will never get a "steel alloy" valve.....much less a stainless alloy valve.....to "CHIP"....beating it against any alloy of aluminum on the planet (well.....maybe hard anodized, forged 7030 or similar).....except where the steel hammer strikes the valve.
See what I'm saying?
So.....I think the term "chip" is a poor one. But yes. I have never seen damage like that. Ray |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Thu Apr 30, 2020 7:29 am Post subject: Re: Valves are chipped |
No engine building expert here, but the two valves with the most chips look to be a different brand, maybe. They look to have a deeper recess, the bevel down to the recessed area looks to be a larger bevel. No? |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Apr 30, 2020 8:36 am Post subject: Re: Valves are chipped |
malcolm2 wrote: |
50/50 chance... _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Apr 30, 2020 8:41 am Post subject: Re: Valves are chipped |
jtauxe wrote: |
malcolm2 wrote: |
50/50 chance... |
He is numbering his cylinders wrong, the bad valves are on #1 and #4, so they are not directly across from one another. |
SGKent Samba Member
Posted: Thu Apr 30, 2020 8:47 am Post subject: Re: Valves are chipped |
Wildthings wrote: |
jtauxe wrote: |
malcolm2 wrote: |
50/50 chance... |
They were if he was parked at a 45 degree angle..... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Apr 30, 2020 8:51 am Post subject: Re: Valves are chipped |
Wildthings wrote: |
They were the closest valves to the flywheel. I just looked at the tins on my 914... 1 and 3 are stamped in the tins and they are the closest cylinders to the flywheel.... both are EX valves and use the same cam lobe. truthfully it does not matter the number. I think the white paint will remind me, or the next guy that those valves are damaged. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Apr 30, 2020 9:09 am Post subject: Re: Valves are chipped |
malcolm2 wrote: |
Wildthings wrote: |
They were the closest valves to the flywheel. I just looked at the tins on my 914... 1 and 3 are stamped in the tins and they are the closest cylinders to the flywheel.... both are EX valves and use the same cam lobe. truthfully it does not matter the number. I think the white paint will remind me, or the next guy that those valves are damaged. |
Set your heads so that they face each other as they would if installed on the engine and see where the bad valves end up. |
