charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Fri May 01, 2020 6:39 am Post subject: 2.0 Aircooled, Alternator Shot, Upgrades? |
Ive got an 81 aircooled. The alternator has now burned out 2 of my voltage regulators...
So im thinking shes shot.
Instead of getting another stock alternator (they are 55a or 65a, right?). Should I upgrade the alternator?
i.e. (https://www.qualitypowerauto.com/item_447/VW-Vanagon.htm)
Ive got a battery isolator in there, and will be dropping a second battery in shortly for internal aux junk.
Thoughts? |
Posted: Wed May 06, 2020 3:14 pm Post subject: Re: 2.0 Aircooled, Alternator Shot, Upgrades? |
wow, nobody has a word on alternators? |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10347 Location: Sunshine Coast B.C.
Posted: Wed May 06, 2020 4:45 pm Post subject: Re: 2.0 Aircooled, Alternator Shot, Upgrades? |
I bet there's info in the Bay forum about this.
Depending on how you wire things up, if you upgrade to a higher output alternator, you might want to look into upsizing the wire from alternator B+ akin to what the WBX crowd would do. It may be there's two B+ posts on the higher Amp alternator or room on the single B+ connection for another connector to a new wire. Then run that to the battery isolator.
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed May 06, 2020 4:48 pm Post subject: Re: 2.0 Aircooled, Alternator Shot, Upgrades? |
If you want your heat to work then staying with the stock style alternator is the easiest option. |
