KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Thu May 14, 2020 3:26 pm Post subject: Re: Blue 1970 Squareback |
Yikes? Well, the second engine looks complete, though of course all rubber parts will have be replaced. Do you have the ability to crank the engine while out of the car to check compression? |
donpedro Samba Member
Joined: January 17, 2003 Posts: 73 Location: Twin Falls, ID
Posted: Thu May 14, 2020 7:46 pm Post subject: Re: Blue 1970 Squareback |
I can turn it over by hand and feel some compression throughout the rotation of the crank shaft. I am looking around for a test stand but I think it would be easy enough to put it in the car...
From the pictures can you see what I’m missing in the FI setup besides replacing the rubber? _________________ 1972 SB Baja "Lola"
1970 Squareback |
KTPhil Samba Member
Posted: Thu May 14, 2020 10:09 pm Post subject: Re: Blue 1970 Squareback |
You will want to check and write down the part numbers for the ECU, MPS, and TVS at a minimum, to see if you have a properly matched set of FI components. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
KTPhil Samba Member
Posted: Fri May 15, 2020 11:42 am Post subject: Re: Blue 1970 Squareback |
Bobnotch wrote: |
Did you get the FI harness too? If not, I'd try to resurrect the carbs for now. |
X2. The harness should be solid or it will drive you nuts with faults, especially intermittent ones. I'm an FI fan, but this is good advice. |
Posted: Fri May 15, 2020 3:21 pm Post subject: Re: Blue 1970 Squareback |
Yeah, it didn’t come with a harness. I think I’m going to pull the carb setup off of the current motor and move it over to the newer one. _________________ 1972 SB Baja "Lola"
1970 Squareback |
KTPhil Samba Member
Posted: Fri May 15, 2020 4:28 pm Post subject: Re: Blue 1970 Squareback |
That will get it running if not well. But you can check for overheating, oil pressure, compression... before spending money on it. |
Posted: Wed Jun 03, 2020 6:05 pm Post subject: Re: Blue 1970 Squareback |
I got the carbs finished today, cleaned up, new gaskets, and reassembled. I pulled the heads to get them cleaned up and put the new gasket kit on the long block. I finally got the heads off and the motor is not turning by hand anymore... it was giving some resistance this morning and now it’s pretty well stuck within about a 30 degree window of rotation. I don’t know what could have happened with hand cranking the engine? I’ve got the heads off and the push rods out. Is there some chance that I broke the crank or cam? What would be limiting it once the heads are off? I wasn’t planning on cracking the case. It’s getting to be a much bigger project than I intended ( as is often the case.)
If anyone has any thoughts or tips I’m all ears. I wasn’t planning on a full rebuild. _________________ 1972 SB Baja "Lola"
1970 Squareback |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Wed Jun 03, 2020 11:55 pm Post subject: Re: Blue 1970 Squareback |
Were you turning the motor over with no distributor?
If the drive was left in the hole while doing that,
You could have buggered up the brass timing gear on the crank. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Thu Jun 04, 2020 9:35 am Post subject: Re: Blue 1970 Squareback |
Clatter wrote: |
You could have buggered up the brass timing gear on the crank. |
That was my first thought too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jun 06, 2020 10:17 pm Post subject: Re: Blue 1970 Squareback |
I think that is exactly what happened... I talked with a local mechanic and he came to the same conclusion. Looks like a case split is in my future. _________________ 1972 SB Baja "Lola"
1970 Squareback |
Posted: Sun Jun 07, 2020 7:54 am Post subject: Re: Blue 1970 Squareback |
donpedro wrote: |
I think that is exactly what happened... I talked with a local mechanic and he came to the same conclusion. Looks like a case split is in my future. |
I think I'd try and re-sink the drive back into place. You might be able to get close. After all at this point in time you want to hear it run, so you can determine it's health (any rod knocks). If you can find an old wooden clutch alignment tool, with a little sanding you can make it fit into the center hole of the drive (make it a press fit (tight)) as that will allow you to maneuver it where you want. You might be able to do this with a length of dowel rod too. They do make a specific tool for this job, but it's possible to fake it.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Nov 01, 2021 9:35 am Post subject: Re: Blue 1970 Squareback |
UPDATE:
It’s been a while since I posted. I’m almost to the point where I can drive the Squareback. I pulled a motor from another Squareback that we are converting to an EV.
I’ve replaced all of the front suspension, brakes, fuel lines, and gotten the motor running. I bought some knock-off centerlines and and out new tires on them. The last things I need to do are replace the rear torsion bushings Nd figure out how to mount these wheels.
The center lines are a lot thicker than the stock wheels and take longer bolts. The wheels don’t have a recessed acorn style holes. Has anyone mounted these style wheels?
I’ll post pictures soon. _________________ 1972 SB Baja "Lola"
1970 Squareback |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Nov 01, 2021 10:21 am Post subject: Re: Blue 1970 Squareback |
https://www.ezaccessory.com/lug_nuts_s/18779.htm
has a good selection of wheel fasteners. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Nov 07, 2021 9:25 am Post subject: Re: Blue 1970 Squareback |
Turns out I have Mag style wheels that take a different fastener than the stock acorn style lugs. So I ordered a stud/lug nut kit and should be in good shape! _________________ 1972 SB Baja "Lola"
1970 Squareback |
Posted: Sun Nov 28, 2021 4:31 pm Post subject: Re: Blue 1970 Squareback |
I got the wheels installed and it looks great! Now bleeding the brakes. I ordered some calipers from CB, opted for the less expensive ones. They've got 2 bleeder bolts each which was confusing and I was having trouble getting the caliper to bleed. I went back with the vacuum pump and was able to get some brake fluid to come through so I think it will work once I get a friend to come pump the brakes for me again. _________________ 1972 SB Baja "Lola"
1970 Squareback |
Posted: Tue Nov 30, 2021 1:07 pm Post subject: Re: Blue 1970 Squareback |
donpedro wrote: |
I got the wheels installed and it looks great! Now bleeding the brakes. I ordered some calipers from CB, opted for the less expensive ones. They've got 2 bleeder bolts each which was confusing and I was having trouble getting the caliper to bleed. I went back with the vacuum pump and was able to get some brake fluid to come through so I think it will work once I get a friend to come pump the brakes for me again. |
Just remember that 2 screw calipers use the upper screw for bleeding, and the lower screw for draining/changing the fluid. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Dec 08, 2021 9:40 pm Post subject: Re: Blue 1970 Squareback |
Thanks for that info Bob!! _________________ 1972 SB Baja "Lola"
1970 Squareback |
Posted: Sun Oct 23, 2022 7:15 pm Post subject: Re: Blue 1970 Squareback |
Bringing back the dead threads on the Samba tonight! I got the Blue Squareback "Lucille" running last year. Pulled a donor motor from my EV project so this one is cruising around. I put some centerlines on it with new tires, updated the suspension components and brakes and now it's a pretty dependable driver.
I hauled it down to Vegas a few weeks ago for the Let's Talk Dubs One Crazy Weekend and had a ball hanging out with the other Type 3 guys. Probably put about 130 miles on it without any trouble.
Next up: Rear hatch seal, trunk seal, rear torsion arm bushings, and a big tune up on the motor. Hopefully, some new interior pieces are in my future because the front seats are BAD. _________________ 1972 SB Baja "Lola"
1970 Squareback |
