sonoma_vw Samba Member
Joined: May 19, 2013 Posts: 464 Location: Sonoma County
Posted: Fri May 08, 2020 1:35 pm Post subject: Original engine tin paint finish |
Ive weeded thru a bunch of threads, but can't find an answer yet.
What was the stock engine tin paint finish? I'm guessing it was semi-gloss.
Is there a certain gloss percentage for original 1960 engine tin?
Thank you. |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Fri May 08, 2020 3:31 pm Post subject: Re: Original engine tin paint finish |
Hi,
I do not know about different gloss. On my 1967 SO42 with all the original engine bits I was advised to powder coat. Glad I did! Holds up much better in an environment of oil and gas and looks wonderful! Used gloss black. Have pictures if you care to see.
Bill |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat May 09, 2020 9:14 am Post subject: Re: Original engine tin paint finish |
Dont know gloss percentage. Its semi gloss for sure. Maybe slighlty more glossy than a satin. Single stage paint... WAS not powder coated originally. I use some basic satin single stage urethane for engine tin... it looks very good to me and I'm all about that original factory fresh look.
Good properly cured single stage is heat and chemical proof. You can touch up paint... but you cannot touch up powder coat if it chips or scraches.
My dad had the tin for his 912 powder coated... he told me if he could do it over he would have just had it painted... but I think that's mainly because the gloss level didnt turn out exactly how he wanted also... I think powder coat is harder to fine tune the gloss level. It simply comes offered as flat, satin, semi gloss, or gloss. Where as paint can be customized and mixed more easily. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
