frankthetank81 Samba Member
Joined: November 26, 2012 Posts: 238 Location: Belleville, Mi
Posted: Sun May 10, 2020 8:45 am Post subject: Garage Door Opener Bracket for Glove Box Door |
So I always had my garage door opener rolling around in my glove box, last night driving home pulling up to my garage, I couldn't find it. So this morning, i was looking at how to mount it somehow. I just used some scrap aluminum sheet, and cut it out with some shears. Used the dremel to round the edges and texture the bracket. I also used some electrical tape on the back to protect the paint and help hold the opener in a bit more.
Just wanted to share this with everyone.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sun May 10, 2020 8:57 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Nice, trick... custom.
Great job on making your car... YOURS _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sun May 10, 2020 9:36 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
I like this, good job. Plus you didn't have to drill into the love box door.
I have my opener in my trunk. I wired a momentary button switch wires to the internal connections of the opener, drilled a hole under the dash, and mounted the momentary switch there, out of sight. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
anthracitedub Samba Member
Posted: Sun May 10, 2020 12:17 pm Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Nice job. I had a similar issue with my remote floating around in the car. I stuck a piece of Velcro (hook side) to the back of mine... it clings to my carpet quite well. I usually keep it stuck on the tunnel by the hand brake, when I drive my other car I just move it over to that one. |
Cusser Samba Member
Posted: Sun May 10, 2020 12:40 pm Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
anthracitedub wrote: |
I hide the other remote, with strong velcro, in my truck.
Accessible but hidden. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Mon May 11, 2020 5:22 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
I have mine in the 'pocket' on the driver's door. Just reach down and press the button _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Mon May 11, 2020 9:47 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Does your glovebox door lock? Do you park in the garage or in a driveway?
Most folks don't think about how easy it is to "break" into a house by reaching into a car parked in the driveway, or pry/pop a lock or window quickly to gain access. |
Posted: Mon May 11, 2020 10:12 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
KTPhil wrote: |
Door locks for car yes. But based on that theory my Truck and Wife's van would also be susceptible to that. |
KTPhil Samba Member
Posted: Mon May 11, 2020 10:43 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Agreed. Some cars let the built-in Homelink work only when the ignition is on, others anytime (yikes!). Same idea here for the remote. |
Posted: Tue May 12, 2020 3:03 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Yea my Dailies, both very new vehicles, work with no key. |
Cusser Samba Member
Posted: Mon Jun 27, 2022 7:04 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
KTPhil wrote: |
I've repeatedly "tried" to explain just this to Mrs. Cusser.
Most of you folks have no idea what "stubborn" really is...... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jun 27, 2022 8:07 am Post subject: Re: Garage Door Opener Bracket for Glove Box Door |
Quote: |
folks don't think about how easy it is to "break" into a house |
'They use to just drive down the road and press the remote 'they' already have and see which doors open. Also 'they' use to drive down the road with a cordless phone and listen for a dial tone then make long distance calls. Technology pretty much eliminated the latter. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
