blacka1vw Samba Member
Joined: September 11, 2013 Posts: 89 Location: N. Central PA
Posted: Thu May 14, 2020 6:07 pm Post subject: Redline 44 idf not ida mixture screws differ |
I’m putting a kit in this 44 idf for a friend. I thought it was strange that it has different mixture screws on each barrel. One blunt mixture screw without a seat and one tapered with a brass seat. Is this normal? I’m not experienced with this carb.
Dale M. Samba Member
Posted: Thu May 14, 2020 6:29 pm Post subject: Re: Redline 44 ida mixture screws differ |
Think both barrels are supposed to have brass needle seats and pointed idle mix screw...
mcdragracer Samba Member
Posted: Thu May 14, 2020 7:00 pm Post subject: Re: Redline 44 ida mixture screws differ |
Ditto. |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Thu May 14, 2020 7:02 pm Post subject: Re: Redline 44 ida mixture screws differ |
almost looks like the "blunt" one is the seat pushed through the housing,,,
did you unscrew them both? |
Posted: Thu May 14, 2020 7:49 pm Post subject: Re: Redline 44 ida mixture screws differ |
I unscrewed them both removed the deal and washer and spring looked them over. In this picture they are just hand threaded in to their stops. The one pictured on the left is the blunt no brass. The one on the right is the brass seat you can see. Owner assured me he bought it new from redline with these mixture screws. |
Posted: Thu May 14, 2020 7:54 pm Post subject: Re: Redline 44 ida mixture screws differ |
The blunt one is also a hex head with slot. The one that is tapered is the knurled type Head with the slot just like the ones that come in the kit. Tomorrow I’ll snap picture of the screws. |
Posted: Fri May 15, 2020 5:43 am Post subject: Re: Redline 44 ida mixture screws differ |
Here are the mixture screws
Posted: Fri May 15, 2020 7:23 am Post subject: Re: Redline 44 ida mixture screws differ |
blacka1vw wrote: |
You got lied to by PO... One of left IS NOT STANDARD WEBER part....
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Fri May 15, 2020 7:38 am Post subject: Re: Redline 44 ida mixture screws differ |
Looks to me like you have a IDF, not IDA, and it has a mixture screw with the needle broken off and your missing your brass seat.
You need more parts to make that carb work correctly. If you rebuild it without those parts, it will be a waste of a kit.
For example of how it should look, one of my IDF cores:
Posted: Fri May 15, 2020 8:07 am Post subject: Re: Redline 44 ida mixture screws differ |
[quote="jpaull"]Looks to me like you have a IDF, not IDA, and it has a mixture screw with the needle broken off and your missing your brass seat.
You are correct it is an idf that was my bad.
I do believe the owner that he bought this carb “new”as part of a kit. And the blunt tip hex screw doesn’t appear to be broken it’s actually threaded longer than the other tapered one. I’m gonna see if we can’t get any information from the dealer. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Fri May 15, 2020 9:27 am Post subject: Re: Redline 44 idf not ida mixture screws differ |
The top picture of the screws, is the repair kit, the middle screws are the early and late fuel mixture screws, along with an original style brass insert to the body, and the bottom screw is an idle stop off a dellorto, and from the other carburetors I just finished for a customer you can see the idle stop screw heads, the early style is hexed head and the later style is around knurled head for the idle stops on the IDF carbs, so the one screw you have appears to be a idle stop screw that somebody put in to the fuel mixture circuit |
