LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5505 Location: 1st Coast
Posted: Fri May 15, 2020 3:21 am Post subject: Butt welding sheet metal the easy way. |
I just got this video from my other car club. Fitzee's Fabrications page is amazing and he is a natural at teaching. This particular method blew me away, unfortunately limited in use. What was amazing to me was his 45 degree angle cut to limit the opening. I can't wait till school is out and I can get my MIG out to play. I'm watching his YouTube's like they are Netflix now, enjoy .
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
wheel607 Samba Member
Posted: Fri May 15, 2020 10:50 am Post subject: Re: Butt welding sheet metal the easy way. |
LAGrunthaner wrote: |
Never thought of that!!!!!!! Thanks |
eebus Samba Member
Posted: Fri May 15, 2020 9:30 pm Post subject: Re: Butt welding sheet metal the easy way. |
Nice, simple trick. Pretty cool. |
frenchroast Samba Member
Posted: Sat May 16, 2020 8:04 am Post subject: Re: Butt welding sheet metal the easy way. |
That is a great technique. I've got some apron work to do inside the wheel well that doesn't require it to be this pretty but I might try it. No one will see it but I'll know . I'll probably mig weld it although you can get nicer spot welds with gas and less grinding. |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1045 Location: Jacksonville, FL
Posted: Mon May 18, 2020 5:19 pm Post subject: Re: Butt welding sheet metal the easy way. |
I just got this video from my other car club. Fitzee's Fabrications page is amazing and he is a natural at teaching... |
The YouTube algorithm must be working overtime trawling The Samba and other car forums. This video appeared in my recommendations a few days ago. I too was amazed by it but You beat me to the post. Someone posted on The HAMB that he used to post tutorial videos there before he moved to YT. I have a panel tacked in place ready to be welded in using his method.
I posted a comment on this video asking him to cover the specifics for butt welding sheet metal and he replied that he will include it in a future video. I can get good looking practice tacks on inboard metal but the minute I get to the gap I end up Swiss cheesing the metal. I will wait for his tutorial before I move ahead with this repair for the second time
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Tue May 19, 2020 4:22 am Post subject: Re: Butt welding sheet metal the easy way. |
Evil_Fiz, that was my concern as well, doing great on the tack and then the butt weld turns into Swiss cheese. I have't had that problem in the past but I was fortunate to have a pro help me set up my new Lincoln MIG. If I were you I would try Fitzee's MIG settings as seen in this YouTube.
I also follow HAMB it's a great site. Can you post before and after photos either here or in your own thread as we all learn from others
Linda
How to setup your MIG
Evil_Fiz wrote: |
Emil |
Maui Roadsters
Lind wrote: |
Posted: Tue May 19, 2020 4:23 pm Post subject: Re: Butt welding sheet metal the easy way. |
...I was fortunate to have a pro help me set up my new Lincoln MIG. If I were you I would try Fitzee's MIG settings as seen in this YouTube.
I did just that and spent about six hours playing monkey boy with the welder settings. I also tried several suggestions from the Eastwood videos. I know I am at a bit of a disadvantage because I am using .030 Flux core instead of .023 MIG but I have seen others succeed with the .030 (long story on why flux core.) I have a further disadvantage because I suffer from retinal degeneration and night blindness so lining up the wire is a bit of a chore. I'm not making excuses, I'll get it figured out eventually.
Thanks for the tip and encouragement. I'll shoot a video of what I am doing and how so the experts can pick it apart and offer much needed advice.
kiwighia68
Posted: Wed May 20, 2020 4:49 am Post subject: Re: Butt welding sheet metal the easy way. |
Evil_Fiz, when you say you are using Flux core, is that MIG without gas and it uses flux to keep it clean instead of argon? I'm no expert but have and use oxy acetylene welding and arc welding. I am a slob with arc but I am like a seamstress with oxy acetylene
I have received great suggestions from the body paint forum, maybe they can help dial you in?
https://www.thesamba.com/vw/forum/viewforum.php?f=13
Looking forward to seeing your success! I can hardly wait to open up my garage and start welding again, its so much fun and productive. Hummm that is probably why I love this silly auto hobby "it's so productive".
Evil_Fiz wrote: |
Emil |
Maui Roadsters
Lind wrote: |
Posted: Thu May 21, 2020 2:50 am Post subject: Re: Butt welding sheet metal the easy way. |
Thanks administrators for moving this to the right place _________________ American Red Cross Safe And Well:
Maui Roadsters
Lind wrote: |
