Longy Samba Member
Posted: Sun May 17, 2020 12:31 pm Post subject: Gearbox code |
Hi Folks,
Anybody familiar with gearbox code A-21.021...
Suppose to be from oval beetle but haven t found anything...
Appriciate for any info to indentify the year and gear ratios...
Tnx
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Longy Samba Member
Posted: Sun May 17, 2020 2:39 pm Post subject: Re: Gearbox code |
#scotty... seems right...tnx.
So; that gearbox apparantly belongs split screen beetle not oval if i m right?
Thank You |
janerick3 Samba Member
Posted: Sun May 17, 2020 7:50 pm Post subject: Re: Gearbox code |
"A-21.02.1" is not the serial number, but the pre-August 1954 part number for the left-hand casting. The old part numbers were found on split-case transaxles until well into 1955.
The actual serial number will be on the right-hand side, immediately behind the nose cone. _________________ Thanks,
Jan K. |
Longy Samba Member
Posted: Mon May 18, 2020 1:56 am Post subject: Re: Gearbox code |
Tnx... getting closer...
Just found number “22” behind the nose cone and some numbers where meet both casing halfs...
Please have a look to precise which model/year belongs to...
Thank you all
Posted: Mon May 18, 2020 6:45 am Post subject: Re: Gearbox code |
The case halves were cast 13 May 1954.
The serial number will be on the side where the starter mounts, at the front.
There is a possibility this is a unserialized replacement case. There were problems with the early 3-synchro, split case transmissions and many ended up rebuilt or replaced. _________________ Thanks,
Jan K. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Longy Samba Member
Posted: Mon May 18, 2020 10:31 am Post subject: Re: Gearbox code |
#EverettB ... i found it tnx...
Can you tell me more regarding these numbers...
Maybe even belongs to vw T1 bus... not oval as i was thinking 🤔...Getting closer 😀
Thank you
Longy Samba Member
Posted: Tue May 19, 2020 1:52 am Post subject: Re: Gearbox code |
Thank you EverettB .
Assume its bus gearbox apparantly... looks same like yours and numbers as well with 2A prefix... |
donny273 Samba Member
Joined: September 08, 2004 Posts: 50 Location: Massachusetts
Posted: Sun Aug 02, 2020 8:36 am Post subject: Re: Gearbox code |
I am building a 56 oval I bought in pieces. The trans serial # is A2784336. I think this means its a type 2 transmission from early 59. Did I get that right? If so will the gear ratio be wrong for my type 1. It seems to fit the chassis and shift OK. |
Posted: Sun Aug 02, 2020 9:00 am Post subject: Re: Gearbox code |
thank you very much |
Posted: Sun Aug 02, 2020 9:01 am Post subject: Re: Gearbox code |
Any idea as to the last year of manual choke cable on a type 1? |
Posted: Sun Aug 02, 2020 9:27 am Post subject: Re: Gearbox code |
thanks again so much |
