Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Sun Jun 27, 2021 11:58 am Post subject: Re: Low Voltage at Fuel Pump |
Those images remind me of the note in Bentley regarding the transaxle to body ground strap. It occurred to me there might be a same or similar note re: battery ground strap. There is:
P. 27.6 _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
jimf909 Samba Member
Posted: Sun Jun 27, 2021 8:09 am Post subject: Re: Low Voltage at Fuel Pump |
FWIW, the OP posted this a few days after asking about low voltage at the fuel pump. I'm not sure if it's directly related to the fuel pump problem but it's worth considering.
Mark Lewalski wrote: |
I finally got around to inspect and change out ground cables on my 89. tencentlife has a good article on his website that covers some of this as well as the post here in the Forum that covers all the ground locations.
I mainly want to show folks that the concern is real about dirty/corroded ground points on our vehicles.
I removed the negative battery cable. It's not corroded much at all but here is the connection at the body:
Obviously, the cable will have no metal to metal contact other than the threads of the fastener.
Here is the fastener:
underside:
topside and threads:
Next up is the transmission to frame ground strap. I didn't take photos of the frame and transmission attachment points but they were very dirty under the strap eyelets.
Here is one end of the ground strap:
Again, the bolt (frame side) and nut (transmission mount side) were dirty and corroded on the threads and contact surfaces.
Here is the engine to body ground strap connection at the body. You can see that the connection point is painted with no bare metal contact surface:
Here is the engine block connection point:
Dirty but not corroded.
However, here are the fasteners from both ends:
and
Only the threads would be serving as the metal to metal connection on the body side and they don't look too good.
So, like I said, I just wanted to give some visual evidence of what we all probably are dealing with. My 89 is pretty clean and I believe it was garage kept for many years before I purchased it. Other vehicles may see much worse conditions of their grounds.
Thanks,
Mark |
_________________ - Jim
Abscate wrote: |
Blakesinclair Samba Member
Joined: January 22, 2021 Posts: 60 Location: Santa Ana, California
Posted: Sat Jun 26, 2021 7:11 pm Post subject: Re: Low Voltage at Fuel Pump |
The original ones were busted, so I fixed all that when I replaced the pump. I’ll double check nothing is loose or vibrating against the frame, but before I installed the new one I did a real quick test on the bench. It seemed loud, but figured it was just because it had no fuel in it. This was like a 1 second zap test, but it was pretty buzzy right there in my hand.
I’ll try digging around for one of those Yugoslavian ones. Probably not a bad idea to be driving with a working spare anyways. _________________ ———————
1985 Weekender Vanagon 1.9L - Manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32571 Location: Reading Pennsylvania
Posted: Sat Jun 26, 2021 3:53 pm Post subject: Re: Low Voltage at Fuel Pump |
Update. After bench testing the old pump and getting nothing, I ordered a new pump. Installed it today and it works! Gonna do some researching because the pump is loud. I got the cheaper option GoWesty had on offer, so maybe that has something to do with it. The old pump was quiet as a mouse, but OEM. So I’ll run this one for a bit and hope I didn’t mess up any venting causing the noise. But I have a feeling it’s just a crappy cheap fuel pump. _________________ ———————
Posted: Wed Jun 16, 2021 12:30 pm Post subject: Re: Low Voltage at Fuel Pump |
Vanagon Nut wrote: |
Blakesinclair wrote: |
... I’m getting about 11.8v to the pump with the relay out and being jumped. So I got a little more juice, but not the full 12.5v seen everywhere else. |
I can't say for sure but I'd guess the 0.8 volt difference is acceptable. |
Jeepers. I love math SO much....
Meant: ... the 0.7 volt difference....
VE7TBN |
Posted: Wed Jun 16, 2021 12:23 pm Post subject: Re: Low Voltage at Fuel Pump |
Good to know. I'll start with a new pump, and start digging around the ventilation to avoid any cavitation issues. Worst case, I have a backup if my original is fine.
The old hoses/grommets were a disaster, so the tank probably had no problem venting, albeit improperly. So now I'm a little worried I did a disservice by fixing all those busted hoses and creating more back pressure for the fuel system. _________________ ———————
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9918 Location: Orbiting San Diego
Posted: Wed Jun 16, 2021 12:03 pm Post subject: Re: Low Voltage at Fuel Pump |
With the meter probes right on the + and - terminals of the pump with pump running, that 11.8v is fine. (engine off)
It is important to measure right at the pump terminals. Then move the negative probe to clean bare metal on the body to compare the voltage that way. That will show if the ground is a weak link.
Mark |
Posted: Wed Jun 16, 2021 10:39 am Post subject: Re: Low Voltage at Fuel Pump |
Ok so this morning I made fresh new connectors at the little junction behind the air cleaner box, cleaned up the grounds by the pump and I’m getting about 11.8v to the pump with the relay out and being jumped. So I got a little more juice, but not the full 12.5v seen everywhere else.
I notice some people talk about restricting the voltage to the pump, so I’m wondering if this is plenty voltage. The pump gets hot, and I can feel some slight erratic vibration in the pump and fuel filter, so something is going on in there. It’s just not nearly as loud as it was before I did the fuel tank reseal.
Thanks for all the help! I didn’t try starting it with a jumper in place of the relay. Would a bad relay cause a drop in voltage? |
Fuel pump relay removed, no jumper wire installed, did you see the 12.5 Volts at fuel pump relay socket 30?
Since the ground current path to fuel pump goes through vehicle metal, that metal could easily account for that voltage drop. If it was me, for testing & learning purposes, I'd run a new wire from battery negative to fuel pump negative then measure voltage at fuel pump wiring.
In my limited experience, I think that since the electrical path in/out of the relay switch portion is short and even if the switch contacts were slightly pitted due to normal wear/tear, I can't see the relay as being a significant voltage drop point if all else inside it is ok.
Assuming your pump was noisy due to cavitation (before tank reseal job), noise you hear/feel now is likely cavitation noise. If the fuel tank is not vented properly, that might account for the noise.
VE7TBN |
Posted: Wed Jun 16, 2021 8:57 am Post subject: Re: Low Voltage at Fuel Pump |
Thanks for all the help! I didn’t try starting it with a jumper in place of the relay. Would a bad relay cause a drop in voltage? _________________ ———————
Ronzo_volvo_guy Samba Member
Joined: December 31, 2015 Posts: 194 Location: Connecticut
Posted: Wed Jun 16, 2021 7:10 am Post subject: Re: Low Voltage at Fuel Pump |
Blake;
FuPu is a 12VDC part!...any less voltage and it might not start, or run more highly stressed (I was going to first say "hotter", but that won't be the case, since it is a "wet" pump constantly being cooled by fuel!), or maybe not make the required pressure for the FI sys (which is pretty important!).
So before you (maybe unnecessarily!) buy a replacement, I recommend you follow the entire power supply and current path (so this includes return path to chassis!) and locate the VDrop (and note this only occurs while load current is flowing, so tests need to be performed while engine is running OR to be a bit safer, FuPu Relay (which is controlled by FI ECU, and which times out when engine is not sensed to be running) can be dummied up to remain ON continuously during troubleshooting, and measure V along the entire path, until you find those 3V!
When you locate the place where 12V come in and 9V go out, that will typically give a manner to proceed with remedies...terminals get loose or corroded, contacts get carbonized, etc. Shiny clean metal and tight are the general recommendation, and long-term protected with ACZP will keep them that way, supplying a full 12V to the FuPu (including submerged, for the Synchro drivers reading this!) See: http://www.sw-em.com/anti_corrosive_paste.htm
Good Hunting! |
Posted: Tue Jun 15, 2021 3:32 pm Post subject: Re: Low Voltage at Fuel Pump |
Any update on this? Going through something similar. Did a reseal of my tank and hoses, but I’m afraid I maybe ran the pump dry and it gave up the ghost. Ran fine the day I put everything back together, but the next morning it doesn’t wanna run. Voltage at my fuel pump is about 9.5 volts. Which seems low. Trying to cross out electrical gremlins before throwing parts at it. New pump is ordered, just preparing for the possibility that the issue is farther up the line than the pump itself. _________________ ———————
Mark Lewalski Samba Member
Joined: June 19, 2010 Posts: 406 Location: Safety Harbor, FL (Tampa Bay)
Posted: Wed May 20, 2020 3:54 pm Post subject: Re: Low Voltage at Fuel Pump |
So I checked the connector behind the air filter housing. Good voltage on the relay side but only 7 vdc on the pump side while the connector was still connected together.
I was able to separate the two halves and when I did, a small cloud of dust and dirt popped out! I removed the blade connectors and they were VERY dirty - not corroded, just dirty. I cleaned them up and then tried to remove the female connectors but just couldn't figure out how to release them from the plastic connector. Tried my best to clean them out and then inserted/removed the blades a few times to try and get a good connection surface.
After that, I reattached everything and had only gained 2.5 volts through the connector. I then took matters into my own hands and replaced the connector with two sets of male/female bullet crimp connectors. Now I finally have 12 volts at the pump.
But it doesn't work.
I tapped on it a bit just in case it was locked up but no go.
So I'm now getting ready to purchase a new fuel pump.
I'm wondering if the poor running of my 89 was possibly due to intermittent (or low) voltage to the fuel pump along with an intermittent (or failing) pump.
Next step in the evolution of things I guess... that's the way my VWs roll.
I'll keep you posted.
Mark _________________ '89 Vanagon GL Wolfsburg "Bluestar" (given to and owned by my son now)
'87 Vanagon Weekender
'74 Thing |
kamzcab86 Samba Moderator
Posted: Mon May 18, 2020 10:46 pm Post subject: Re: Low Voltage at Fuel Pump |
I was also thinking of grounds...
I read a previous thread that details (w/photos) all the ground locations but the ground shown for the '86 fuel pump example is right above the pump itself. My wires both come from somewhere else - anyone know where that fuel pump ground would be on an '89?
Below the coil: https://www.thesamba.com/vw/forum/viewtopic.php?t=548492
Digifant ProTraining Manual _________________ ~Kamz
2016 Golf GTI S
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Mon May 18, 2020 10:38 pm Post subject: Re: Low Voltage at Fuel Pump |
Look up how to test for voltage drop and find where your electrons all got used up. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Nickel_Nackel Samba Member
Joined: February 07, 2018 Posts: 187 Location: Bellingahm WA
Posted: Mon May 18, 2020 1:08 pm Post subject: Re: Low Voltage at Fuel Pump |
maybe a dumb simple question but are the two relays above the ign coil in the box the same (interchangble?) im having similar issues and this will help me a little on diagnosis _________________ 1985 1.9L Potato |
Posted: Mon May 18, 2020 4:03 am Post subject: Re: Low Voltage at Fuel Pump |
I know that I can trace them out (and normally I would do that) but I guess I'm looking for a bit less time under the vehicle or bent over the engine bay if possible - my back just can't take that much anymore.
If someone knows where that ground point is, please let me know.
Thanks,
'74 Thing |
Posted: Sun May 17, 2020 3:09 pm Post subject: Re: Low Voltage at Fuel Pump |
The fuel pump wiring has a 2 pin connector behind the air cleaner and you might check the voltages there as well.
When checking in either place, do another test with the negative meter probe on clean body metal instead of on the ground wire. This can help determine whether the voltage is low or the ground is weak.
Mark |
Posted: Sun May 17, 2020 2:57 pm Post subject: Low Voltage at Fuel Pump |
I realized that my 89 fuel pump wasn't vibrating when I would turn the ignition on. I feel the relay in the relay box in the engine compartment is clicking as the ignition is turned on.
I hooked up a multimeter to the fuel pump posts while everything was still connected and it momentarily reads 7.8 vdc as the ignition is turned on.
I'm a little rusty with working on my Vanagons since some medical issues arose and put a stop my tinkering. I could use some troubleshooting help here please.
Thanks,
'74 Thing |
