LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Mon May 18, 2020 3:47 am Post subject: Front door weatherstrip frame to door. |
As you can see my new weatherstrip will need to be cut of which I'll assume line up the slots and then cut. I'm a little nervous about cutting until I get some feedback. If I cut as lined up in the images of the strip on the bus it will be open on the end and in a "U" shape instead of a "box" shape in birds eye view. I lined up the old seals to the new seals (seals from Germany).
Do I live with that "U" shape on the ends or do I glue in some extra to box it in?
Do I glue it in place? Auto weather striping adhesive?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Mon May 18, 2020 1:27 pm Post subject: Re: Front door weatherstrip frame to door. |
I've had several NOS sets that end up in the "U" you mention. There actually isn't a place for the across ends to sit. The top-of-window door-scraper could extend down past the door-to-slider-frame rubber.
Personally I've never used cement as the outer bulbous keeps water out and the bolts and nuts that hold the frame on tighten against the seal.
See what others say before cutting anything. You will want the drain holes to line up for sure. |
Posted: Tue May 19, 2020 3:24 am Post subject: Re: Front door weatherstrip frame to door. |
Thanks BarryL, I'm not an adhesive type of person in the first place as everything is subject to change and removing adhesive is a PITA. If I don't hear back I'll start searching and PM those who have trimmed and get their opinion. It's too bad they made the last end "U" cuts in the rubber as I would prefer to have done that myself with an Exacto knife.
Is there a bonding agent that I can melt the rubber together to ad the end piece? I'm getting so close to finishing my camper if campgrounds do not open I'm going to park it on my lawn and camp all summer.
This "U" cut is a shame.
BarryL wrote: |
Maui Roadsters
Lind wrote: |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Tue May 19, 2020 8:01 am Post subject: Re: Front door weatherstrip frame to door. |
I have never had NOS sets, but have done four or so buses with new rubber on door tops. WCM rubber I think?
Regardless, I had to cut and snip and fit each time to get what I considered a proper fit.
U channels on the ends, elongating drain holes and post holes to line up, even shaving some of the inside of the outer channel to get the middle post to sit down flush.
My philosophy was that as long as the outer channel seals properly end to end, the inner channel looks contiguous end to end from the inside of the bus, cut what you need to cut to get the frame to sit down flush with the door.
I had to do probably 5 or more test fits per side before I had a good flush fit.
It is a somewhat tedious process, but not difficult - don't overthink it.
No adhesive. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Tue May 19, 2020 8:07 am Post subject: Re: Front door weatherstrip frame to door. |
LAGrunthaner wrote: |
BarryL wrote: |
Linda, to rejoin the U slice in the weatherstrip, check this video out:
https://www.youtube.com/watch?v=DwdQFiuGKkQ
I used CA glue (aka superglue) to mend my floormat. I used two pieces of thick metal since that doesn't form a bond. Any excess glue I carefully sliced off with an x-acto knife. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
Posted: Tue May 19, 2020 2:15 pm Post subject: Re: Front door weatherstrip frame to door. |
Wow that was a great tip, thanks peecee69. Have you ever tried it? The video cut out when he said if you don't have lac thinner, then he poured the white bottle was that alcohol? I could see this working when you're in a pinch too.
peecee69 wrote: |
BarryL wrote: |
I used CA glue (aka superglue) to mend my floormat. I used two pieces of thick metal since that doesn't form a bond. Any excess glue I carefully sliced off with an x-acto knife. |
Maui Roadsters
Lind wrote: |
Posted: Tue May 19, 2020 6:07 pm Post subject: Re: Front door weatherstrip frame to door. |
Yes, I used this video, but for the front floor mat of my doublecab. I used two pieces of sheet metal and clamped them together for about an hour while the CA was drying. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
