Tully Mars Samba Member
Joined: November 30, 2006 Posts: 93 Location: Wheat Ridge CO
Posted: Tue May 19, 2020 3:13 pm Post subject: Instrument Circuit Foil Replacement Kits |
Hello All,
So I am going to pull the trigger to replace my horribly screwed up instrument foil with a "new technology" kit. Looking for some guidance.
Van Cafe sells the GoWesty kit which seems to get good reviews here and elsewhere but is more expensive. (Sold out at GoWesty.. but it looks like Van Cafe has some)
The Vangaon.org one is affordable but the version that I need (84 Wolfsburg Westy) is sold out. Have not heard back yet on when they will have more.
Campervan Culture has one that is also affordable. Can not find any feedback on that one here.
So.. comments, pros, and cons on these various options please?
Are there other kits out there?
Thanks in advance.... _________________ I'm a man. But I can change.
If I have to.
I guess.
_______
84 Wolfsburg Westfalia
Hobie Cow |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 781 Location: WestWorld Nanaimo BC
Russpauly Samba Member
Joined: January 13, 2019 Posts: 134 Location: San Diego
Posted: Tue May 19, 2020 3:37 pm Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
I'm thinking of giving this a try. Like the clock, looks like he's been working on it for a while if you check out the YouTube vids.
https://www.thesamba.com/vw/classifieds/detail.php?id=2367183 _________________ 1988 Wolfsburg Edition - TinTop
2.1L Watercooled
The Space man Van |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Tue May 19, 2020 3:57 pm Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
I bought the vanagon.org harness because it was the cheapest and I'm cheap. Works as advertised but the circuit board connection on this new harness is a little thinner than the OEM one. Ever so slightly, but enough to cause my oil buzzer to go off. I had to bend up the spring contacts in the van's harness plug to apply more pressure on the new unit's board when connected. If that makes any sense. Zero issues since. _________________ '87 GL w/ Reimo top |
plummerdesign Samba Member
Posted: Tue May 19, 2020 5:25 pm Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
The SA Cluster Master kit from Eric at Vanagon.org is a gem and worth waiting for. I believe campervanculture.com has them in stock.
Cheers,
Jeffery _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Tue May 19, 2020 5:37 pm Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
^^ agreed. When I hooked up the Vanagon.org kit I was like wow wires that carry electrical signals fancy. It’s simple and it works. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9918 Location: Orbiting San Diego
Posted: Tue May 19, 2020 6:20 pm Post subject: Re: Instrument Circuit Foil Replacement Kits |
The site says they have the Diesel-CMDT version in stock and that should be the same as the gas one other than the color of the lowest LED.
The diesel uses a yellow led there while the gas has a red.
If that is all it is then it isn't an important difference for a gas van.
Mark
Tully Mars wrote: |
Westified Samba Member
Posted: Tue May 19, 2020 7:36 pm Post subject: Re: Instrument Circuit Foil Replacement Kits |
This is my GoWesty install of the instrument cluster harness in my 1984 westy Wolfsburg. I can't believe its been 5 years since I installed it. It is still working great and the install was easy. I was so happy to get my tachometer working again. Good luck with your decision. I don't think the vanagon.org one was available at the time and GoWesty gave me good support on the install. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
mdub Samba Member
Joined: February 05, 2020 Posts: 48 Location: Bellingham, WA
Posted: Tue May 19, 2020 8:47 pm Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
That is a neat clock. It looks like it's just a generic lcd dot screen, it would be cool if someone could expand on the idea and add even more functions, like an external temperature reading, volt meter, etc.. _________________ '86 Syncro / Reimo Poptop / EJ22 |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Syncro Jael Samba Member
Posted: Wed May 20, 2020 4:02 pm Post subject: Re: Instrument Circuit Foil Replacement Kits |
I have the GW Kit installed for years. Flawless. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Posted: Fri May 22, 2020 10:07 am Post subject: Re: Instrument Circuit Foil Replacement Kits |
Thanks for the responses folks.
Vanagon.org is getting a shipment in about a week so I went ahead ordered the proper one there.
I was Very Very tempted to get the one advertised here that comes from Taiwan. 100 bucks from Taiwan versus 170 Vanagon.org. But given shipping times and my inclination to support our US Vanagon vendors... I have spent the extra bucks. _________________ I'm a man. But I can change.
If I have to.
I guess.
_______
Hobie Cow |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Fri May 22, 2020 10:42 am Post subject: Re: Instrument Circuit Foil Replacement Kits |
I installed the GoWesty version on our ‘91 2.1L a few years back - easily to install and worked great. I liked that you could kill the “RPM oil pressure” buzzer with a flip of a dip switch - handy while we we’re dealing with hot oil on long drives in triple digit temps (we have a tired engine but an oil gauge installed).
Only flaw I found is the little board with the tachometer pins seems to come off easily - I’ve twice now lost the tach upon re-assembling the cluster to the dash and had to take it back out to properly secure it.
I just recently installed Vanagon.org’s Diesel CMBDT for my ‘91 1.9L AAZ European doka, install was easy and worked like a charm.
Both up grades were well worth it in my opinion.
Tempted to try the clock offered in the Samba classifieds but other more pressing things to address first.... _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
KarHaus1984 Samba Member
Posted: Sun May 16, 2021 1:15 pm Post subject: OXY led light in dash |
I replaced my instrument foil with the Cluster kit from Vanagon.com. They say that my OXY red LED light on the bottom right should light with the battery and oil pressure lights when the ignition is turned 'on' before starting engine. My OXY light does not come on. Does someone have an '84 Westy with the water-cooled Digijet engine that can confirm or not that the warning light briefly comes on before engine start? I cannot seem to find the answer to this in my owners materials or my Bentley manual and just don't remember if it came on before the foil fix. Thank you. |
thebigben Samba Member
Joined: October 22, 2020 Posts: 94 Location: California
Posted: Sun May 16, 2021 4:45 pm Post subject: Re: Instrument Circuit Foil Replacement Kits |
Another vote for the GW kit. Worked perfectly, took about an hour.
_________________ Ben
'85 2WD Westy w/ Peloquin TBD + 2.2 Subi (Kurt Vannegut) |
zandon Samba Member
Joined: March 15, 2009 Posts: 6 Location: Trenton, South Crolina
Posted: Mon May 17, 2021 7:08 am Post subject: Re: Instrument Circuit Foil Replacement Kits |
'84 Westy all original: key on before engine start... battery light on, oil light on, oxy light on, and flashing water temp light. |
Posted: Mon May 17, 2021 7:48 am Post subject: Re: Instrument Circuit Foil Replacement Kits.. |
Just noticed that I never followed up on this. I ended up going with this kit from Taiwan, with Kai. Honestly a great kit and no issues. Would recommend again for another alternative and believe he sells them on Ebay. _________________ 1988 Wolfsburg Edition - TinTop
2.1L Watercooled
The Space man Van |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 919 Location: Sammamish, WA
Posted: Mon May 17, 2021 9:32 am Post subject: Re: Instrument Circuit Foil Replacement Kits |
Has anybody used any of these replacement kits (GoWesty, Vanagon.org, Kai from Taiwan) on a van with a Subaru (EJ25) conversion? Are they compatible or is there anything that needs to be changed/modified?
My clock is shot, my tachometer stopped working a couple weeks ago, my dash lights are flaky, the usual... _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Mon May 17, 2021 11:17 am Post subject: Re: Instrument Circuit Foil Replacement Kits |
Zandon - thank you very much. I'll now check the Oxy sensor and the grounding now that I know the indicator LED should light briefly when ignition is on. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6242 Location: Portland OR
