fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Wed May 20, 2020 12:10 pm Post subject: Will Porsche 356 cam gear fit a vw 36hp? |
I was wondering if since 356 cam gears have the same p/n as the vw 36hp gear (111 109 111) as long as the gear teeth pitch between the porsche part and the vw part match up would the cam gears be interchangeable? |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1468 Location: San Carlos, CA
Posted: Wed May 20, 2020 1:47 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Yes, they'll work.
_________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Wed May 20, 2020 2:16 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Thanks! Is that stack of 36hp gears by chance yours and if so does it happen to have a -2, -1 or 0 gear you'd be willing to part with? |
Posted: Wed May 20, 2020 2:36 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Yes, they're mine. I'm going to use a case that didn't come with a cam gear, so I'll end up using the one that fits best, and selling the rest.
I'm not interested in selling them right now. This shop has a wide selection of cam gears for sale: https://bugcity.com/shop/shop.lasso?cid=1&scid...ort=name_a
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue May 26, 2020 6:52 am Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
For the life of me, I can't figure why VW increased the helix angle in the first place. It isn't like the early version was noisy, and an increased helix needlessly increases thrust. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2344 Location: San Clemente, Ca.
Posted: Tue May 26, 2020 8:39 am Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
I’ve wondered that myself _________________ Jack Staggs
Actual name |
Braukuche Samba Member
Posted: Wed May 27, 2020 9:08 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Porsche used VW cam gears, so... _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Jacks Samba Member
Posted: Wed May 27, 2020 9:39 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
You’re right! They used the early ones that “gears” and I were referring to. And they stuck with them for the entire 356/912 production ending in late 1969. Unlike VW. Try and keep up _________________ Jack Staggs
Actual name |
Posted: Tue Jun 02, 2020 7:07 am Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
I obtained a nice -2 356 gear from ebay, so good to go hopefully. It appears identical in all aspects to my worn -2 gear except it has both bolt holes and rivet holes. I'm now on the hunt for some 1/2" 8 x 1.25 bolts to complete the install to my WW performance .345" lift cam.
I see that CIP is branching out now, with an aluminum hub fiber gear ("noiseless") 25/36hp gear, and also an aluminum gear that looks to have been supplied by BBT in Belgium. |
Posted: Tue Jun 02, 2020 8:06 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
When a fiber gear fails, it fails spectacularly.
Cheers,
Richard Feynman |
Posted: Wed Jun 03, 2020 8:23 am Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Ok then... EWWWWWwwww not good! I'll back away from the fiber dealio then.
I'm going to double check my Bentley manual but IIRC I think I even saw where VW replaced the fiber gear in later years because it wasn't durable.
thanks for the heads up! |
pharos Samba Member
Posted: Fri Nov 11, 2022 4:17 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
Excuse my question, but what is -2,-1,0,+1 or +2 Gear Pitches and what it do? _________________ http://www.facebook.com/groups/vwbug/ |
Posted: Fri Nov 11, 2022 6:17 pm Post subject: Re: Will Porsche 356 cam gear fit a vw 36hp? |
My understanding is that the different gears (e.g. -3, 0, +3, etc.) are intended to make up for slight manufacturing variations of the cam/crank centerlines. I've read someplace that most cases should be in the -1 - +1 range.
Cheers,
Richard Feynman |
