vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun May 24, 2020 8:53 am Post subject: Re: numbers |
By the number you do not have the stock 6V swingaxle that would have come in a '64. I'll guess you have a stock 12V swigaxle out of a 67-78. No telling what is inside if it has been rebuilt. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Dale M. Samba Member
Posted: Sun May 24, 2020 6:14 am Post subject: Re: numbers |
Here is transmission codes....Should be another set of numbers on case...
http://www.vw-resource.com/transaxle.html#codes
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Sat May 23, 2020 10:12 pm Post subject: Re: numbers |
need a bigger picture of the transmission showing what type it is. IRS? Swing Axle? Type II? The numbers are not helping identify the transmission and probably will not. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
elansmith70 Samba Member
Joined: May 21, 2020 Posts: 18 Location: Leeds, Yorkshire UK
Posted: Sat May 23, 2020 4:13 pm Post subject: Re: numbers |
A photo of the transmission numbers. In the correct place and very straight so implying factory. I know the corrosion is hiding them in the picture. They are easier to see in reality but can't see a letter.
YDBD Samba Member
Posted: Sat May 23, 2020 12:35 am Post subject: Re: numbers |
Pictures would help, also these pages:
https://www.thesamba.com/vw/forum/viewtopic.php?t=658674
http://vw.zenseeker.net/Transaxle.htm
Hard to tell what the numbers mean if it's been rebuilt at any time and stamped with those numbers.
I'll go check my '67 swing axle and see if I find anything like that and report back. _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
Posted: Fri May 22, 2020 5:03 am Post subject: Re: numbers |
Thanks for the info people. Can anyone help me with the transmission 9947051 that doesn't have any letters in front of it? |
Posted: Fri May 22, 2020 5:00 am Post subject: Re: numbers |
joemama wrote: |
If your engine comes up as a 1966, 1300, you cant go by that, because the 1300 case had the same size hole for cylinders as a 1500, or 1600, and could also take slip in 87 and 88 cylinders, only the heads had to be changed, and could even be upgraded to a dual port. So, chances are that at this point in time its been rebuilt at least once, and as what? |
I've had the heads off to investigate and refurbish. Fitted new piston rings, it's a 1600. So new barrels and pistons at some point. |
Posted: Fri May 22, 2020 4:56 am Post subject: Re: numbers |
erichevy wrote: |
From JBUGS site...
F0, F1, F2 engine code = 1966-1970 - 1300cc 40bhp DIN, 50HP SAE (only 1966 in USA, 66-70 elsewhere) |
Thanks for that. I had some conflicting info. What you have said or that F2 engines were only exchange units. |
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Fri May 22, 2020 4:43 am Post subject: Re: numbers |
You may like to register on the UK buggy club site for more specific info
http://www.beachbuggy.info |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Thu May 21, 2020 2:53 pm Post subject: Re: numbers |
erichevy Samba Member
Posted: Thu May 21, 2020 11:57 am Post subject: Re: numbers |
From JBUGS site...
Posted: Thu May 21, 2020 5:01 am Post subject: numbers |
I'm restoring a GP Buggy with, I believe is a 1964 frame (number 718927). Engine number F2078327. Transmission 9947051. As its a buggy, it's a hybrid creature. Could anyone confirm what year engine is but of most interest transmission. It has no letters before the numbers (I can see). I have gone through the charts but I am none the wiser. I know these type of questions have been asked a million times before but I'd like to know what I have. |
