Starting issues on a 1969 beetle
Page: 1, 2, 3  Next
Bertsuko88
Bertsuko88 is offline
PostPosted: Thu May 21, 2020 5:49 pm    Post subject: Starting issues on a 1969 beetle Reply with quote
About a week ago I took the battery out to do some cleaning and repairs on the floor of the car. Fast forward to now I was so excited that I got the car to where I wanted it to be and I go to start and the starter goes but nothing starts. It’s getting gas but the spark is the issue I think. I changed the spark plugs and wires to the cap but I have a new cap and rotor and etc to change. It tries to start as in I can hear it try to start but it still floods. What can my problem be? The old rotor and other parts? Any help is greatly appreciated!!
Matt Wilson
Matt Wilson is offline
PostPosted: Fri May 22, 2020 7:40 am    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
It may be as easy as the spark plug wires are in the wrong order. Check there before you start messing around with the carburetor or anything else.
1972 Standard Beetle
1969 Baja Beetle
sjbartnik
sjbartnik is offline
PostPosted: Fri May 22, 2020 7:52 am    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Since you mention that you changed the spark plugs and wires, and now it doesn't start, logic would tend to suggest that you did something wrong while changing the plugs and/or wires. Most common would be getting the firing order wrong when hooking up the new wires.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Bertsuko88
PostPosted: Fri May 22, 2020 9:07 am    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
It wouldn’t even start before I went changing anything is what I’m confused about
sb001
sb001 is offline
PostPosted: Fri May 22, 2020 11:25 am    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
How about posting a photo of your engine bay so we can take a look?
Did you ever get your wiring up front figured out? With the mess going on up there I would not be surprised if its a wiring issue.
How do you know you are getting gas to the engine?
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Bertsuko88
PostPosted: Fri May 22, 2020 4:39 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
I never had the wiring figured out. The relays in the car are coming on Wednesday I believe but i took the fuel line to the carb off and tried to start the car and put that line in a jar and I had gas coming out of it. That’s how I was told to check that. But here are some pictures added in to maybe help. I was so close to having it be ready to get insured and on the road but my luck always stops me haha. Thanks again!
Bertsuko88
PostPosted: Fri May 22, 2020 4:50 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Update I sprayed some starting fluid in it and tried to start it and it started real slow and I didn’t have time to try to hit the gas to keep it going since i don’t have seats in it at the moment. I don’t know what else I can check for to be the problem
Cusser
Cusser is offline
PostPosted: Fri May 22, 2020 5:07 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
I have zero idea what this means
Huh? Heard of a folding chair? Heard of a wooden box?? Or concrete blocks???
I'd try that again, and tell us something "concrete" !!! Pun intended !
Bertsuko88
PostPosted: Fri May 22, 2020 5:09 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
It idled very low for a couple of seconds and it was really smokey
Xevin Premium Member
Xevin is offline
PostPosted: Fri May 22, 2020 5:57 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Is that fuel pump pivot pin without a c clip and starting to back out? Shocked
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Bertsuko88
PostPosted: Fri May 22, 2020 6:43 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
I don’t know what you are talking about. What exactly is it?
Xevin is offline
PostPosted: Fri May 22, 2020 7:10 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Here you go.
https://www.thesamba.com/vw/forum/viewtopic.php?t=536315&highlight=pivot
Keep on Busin'
SGKent wrote:
sb001
sb001 is offline
PostPosted: Fri May 22, 2020 7:25 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
The fuel pump pin Kevin is referring to is this:
It should have a circlip on it to prevent it from backing out of the stand. If it backs out too far your fuel pump will no longer function.
But, I also notice that your spark plug wires seem to be out of order around the distributor cap. (It looks like they might be one off counterclockwise from where they should be but I can't tell for sure.)
Here is where each plug wire should go, IF your distributor drive gear is set up properly down in the distributor shaft hole:
Just try moving all your plug wires one position CLOCKWISE around the distributor cap and see if the car starts then.
1600 SP engine
Cusser
Cusser is offline
PostPosted: Sat May 23, 2020 6:48 am    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Read text on this one
Bertsuko88
PostPosted: Sat May 23, 2020 1:46 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
I changed the wires to what you show in your diagram and I put a new distributor cap and rotor on it. It still didn’t work
sb001
sb001 is offline
PostPosted: Sat May 23, 2020 3:17 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Did you try what I said? Question
Look at cusser's diagram above, but instead of that positioning, place #1 plug wire where #2 is in that diagram, then go around clockwise around the cap 1-4-3-2. IF everything else is equal and the drive gear was installed correctly, then THAT is the correct orientation for an SVA distributor like what you have.
1600 SP engine
Bertsuko88
PostPosted: Sat May 23, 2020 3:22 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
I also tried what you said too but it didn’t work. Sorry I thought I put a reply on both replys
Cusser
Cusser is offline
PostPosted: Sat May 23, 2020 4:30 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Not bragging, but bet I could get it running or diagnose exactly what is wrong in under 15 minutes if I was there with it.
Can you show me better the large connector on the coil and its wire going to the center of the distributor cap? Your lack of shepherd's crook somewhat makes that confusing.
Bertsuko88
PostPosted: Sat May 23, 2020 5:19 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
Hope that helps and that’s what you mean. Sorry if I’m not getting what you ask I’m new to all this but trying my best to learn!
Cusser
Cusser is offline
PostPosted: Sat May 23, 2020 5:40 pm    Post subject: Re: Starting issues on a 1969 beetle Reply with quote
1. Get some aerosol starting fluid; spray some into the air cleaner, floor the pedal, see if the engine runs a few seconds or more. Try several times; if it does start and run a few seconds, your issue is fuel related. If not, then spark related.
2. If above test is done, and engine won't run at all: Is the small wire from the distributor connected to the POSITIVE terminal #1 on the coil? And all the other wires on distributor on coil terminal #15?
3. With the ignition key in the run position, do you have positive voltage to coil terminal #15?
4. If you hook a static light to coil terminal #1 and a helper cranks the engine, does the static light go on/off/on etc.?
5. If you hook a dwell meter to coil terminal #1 and a helper cranks the engine, us the dwell between 44 and 52 degrees?
If you don't have a points-type distributor, I don't know if #4 and #5 even apply.
Page: 1, 2, 3  Next
