tjbayless Samba Member
Joined: September 24, 2007 Posts: 27 Location: Kechi Ks
Posted: Fri May 22, 2020 9:43 am Post subject: Hood hinge area bent |
Is there any way to fix this. Car had front end hit sometime in its past and bent the hinge attachment area of the hood. The first 2 pictures are of the hood damage and the third is how the hinge area is supposed to sit.
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9950 Location: Huntington Beach, CA
Posted: Fri May 22, 2020 2:16 pm Post subject: Re: Hood hinge area bent |
Drill out the spot welds. Remove the piece and take it over to the work bench. Get it back into shape and plug weld it back into place. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Fri May 22, 2020 3:14 pm Post subject: Re: Hood hinge area bent |
Thanks I’ll give that a try |
bomberbob Samba Member
Posted: Sun May 24, 2020 7:38 am Post subject: Re: Hood hinge area bent |
How does the hood fit now? Is it that bad? _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Mon May 25, 2020 5:53 am Post subject: Re: Hood hinge area bent |
bomberbob wrote: |
How does the hood fit now? Is it that bad? |
Gaps on both sides were 3/4 of an inch and hood was short at the front apron making it hard to close. |
Posted: Mon May 25, 2020 10:59 am Post subject: Re: Hood hinge area bent |
Removed the hinge attachments from the hood. Took some hammering and twisting to get it to lay closer to the original shape. The hardest parts was getting it back under the pinch seam along the back. I was surprised by how much rust was under this area so I took the time to treat that and paint it why I had it apart.
Posted: Mon May 25, 2020 11:56 am Post subject: Re: Hood hinge area bent |
tjbayless wrote: |
Removed the hinge attachments from the hood. Took some hammering and twisting to get it to lay closer to the original shape. The hardest parts was getting it back under the pinch seam along the back. I was surprised by how much rust was under this area so I took the time to treat that and paint it why I had it apart. |
Nice! The rust is everywhere on these cars. Moisture gets in and just stays. It is what it is. Clean it good. Naval Jelly what is left. Follow that up with a weldable copper primer. Then weld it back into place. _________________ Jimbo
TDCTDI wrote: |
