virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Sun May 24, 2020 4:48 am Post subject: Alternator issues. Any thing that can help me get home? |
I decided to bring my newly rebuilt super vert to the outer banks of NC for Memorial Day week. She drove perfectly on the highway, averaging 230 degrees oil temp at 70-75 mph for 5 hrs. Then on the first errand trip here to get groceries, idle speed was erratic and there is a distinctive chirping noise coming from my alternator. I suspect one of the bearings is in the process of seizing. I can actually see the belt jerk when the chirp occurs. I have basic tools with me, but I believe the bearings are sealed and it’s not possible to get a part shipped out here before we leave. Any advice on how to keep this chirp from turning into an all out failure? Alternator is the original Bosch—44 years old—and the only major part I chose not to replace (though I did clean the armature and brushes) during the rebuild because it seemed to be working very well. Thanks! _________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1505 Location: Buford GA
Posted: Sun May 24, 2020 6:32 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
New bearings is the only way. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun May 24, 2020 6:44 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Wow - not sure what to tell you finding those or an alternator in stock in a FLAPS is going to be a challenge. I would STRONGLY suggest a post titled "NEED TYPE 1 ALTERNATOR HELP NOW OUTER BANKS NC. You are hoping to find someone close by that may have what you need in their stash and hopefully their garage is close by. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sun May 24, 2020 6:54 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Look up "Island Cruisers" in OBX. They rent dune buggies, nice folks. They might be able to point you to some VW parts places. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Sun May 24, 2020 7:37 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Are you sure it's the bearing? There might be a bit of debris lodged between the armature and the stator, which I've had happen to me before. It might even be that the woodruff key sheared off in the pulley.
At any rate, the rear cover is easy to remove with simple tools, and can be done with the alternator still on the engine. Once you get the belt and pulley off, there are only three little screws that secure the cover plate to the body of the alternator. That will expose the stator and the back end of the armature, and the rear bearing.
Good luck, man. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sun May 24, 2020 8:06 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
If you dont get it fix hopefully if you baby it no more than 55mph you can make the trip back ,i had bearing on alt make all kinds if noise for a while with out failure till i was able to replace alt , good luck |
Posted: Sun May 24, 2020 8:36 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Q-Dog wrote: |
Look up "Island Cruisers" in OBX. They rent dune buggies, nice folks. They might be able to point you to some VW parts places. |
Holy small world. Our rental house is 0.3 miles from Island Cruisers. I called them and the owner is incredibly helpful. He didn’t have the part but he referred me to a shop 30 minutes away that can get a remanufactured Bosch in by Tuesday morning, and either the owner or his father—also both less than a mile from me—can install it. Thanks so much for the suggestion!! _________________ 1976 Convertible Super Beetle, "June Bug".
Posted: Sun May 24, 2020 8:50 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Floating VW wrote: |
Good luck, man. |
I’m pretty sure it’s the bearing. When I first assembled my engine (about 500 miles ago), the rear bearing was grumbling (a low rumbling noise every 30 seconds or so) quite a bit at idle. I loosened the belt by a few shims and the noise went away. But I should have taken the hint. _________________ 1976 Convertible Super Beetle, "June Bug".
Q-Dog Samba Member
Posted: Sun May 24, 2020 10:12 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
virusdoc wrote: |
Q-Dog wrote: |
Holy small world. Our rental house is 0.3 miles from Island Cruisers. I called them and the owner is incredibly helpful. He didn’t have the part but he referred me to a shop 30 minutes away that can get a remanufactured Bosch in by Tuesday morning, and either the owner or his father—also both less than a mile from me—can install it. Thanks so much for the suggestion!! |
There you go. Good luck.
Are the beaches open? I bet a buggy ride on the beach would be a great deal of fun right about now, and a good way to make the VW part of your trip a little bit less disappointing. _________________ Brian
'69 Dune Buggy
'70 Beetle |
vamram Samba Member
Posted: Sun May 24, 2020 10:58 am Post subject: Re: Alternator issues. Any thing that can help me get home? |
Q-Dog wrote: |
virusdoc wrote: |
Q-Dog wrote: |
Are the beaches open? I bet a buggy ride on the beach would be a great deal of fun right about now, and a good way to make the VW part of your trip a little bit less disappointing. |
Way to go Q-Dog! That's some Samba greatness there! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun May 24, 2020 12:54 pm Post subject: Re: Alternator issues. Any thing that can help me get home? |
Q-Dog wrote: |
The beaches are open with social distancing orders in place. It’s chilly and cloudy though so there aren’t many people anyway. _________________ 1976 Convertible Super Beetle, "June Bug".
