Loren Samba Member
Posted: Sun Nov 22, 2020 11:25 am Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Jason has been fitting the new windshield frame and getting it ready to weld back in place. This should be the last major welding on the body, then it's on to fixing the pan. At some point the Ghia was rear ended with the top up and the windscreen frame got pushed forward so it had to be removed and a new one sourced. Here are the updated images, enjoy!
Loren Samba Member
Posted: Mon Nov 30, 2020 1:38 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
My friend just wrote me with a little history on this Ghia:
It was owned by Straw Hat Sue, a local fixture in the area, and she drove that Ghia all over the Auburn, CA area. My friend says he saw her drive it as far back as the late 70's and he never imagined at that time, that he would own her Ghia.
I believe she passed away in the late 90's and my friend got the Ghia so he could restore it in her honor. It's been a long time coming, but my friend has been working on this Ghia for the past 20 years and it's finally coming together. |
Loren Samba Member
Posted: Wed Dec 23, 2020 4:10 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Wishing everyone a Merry Christmas!
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Wed Dec 23, 2020 5:05 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
MERRY CHRISTMAS
Loren Samba Member
Posted: Thu Dec 31, 2020 11:02 am Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
The front windshield frame had to be replaced due to a rear end accident that occurred with the top up. The car was hit so hard from the rear that the top mechanism bent the front windscreen frame forward! The screws are just there to temporarily attach the inner frame before it is welded together.
I think this is it for the work on the body. I believe next month Jason will start working on the pan and getting it all sussed out. If all goes well the body and pan should be painted and ready for finally assembly this summer! |
Marcdeb Samba Member
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Thu Dec 31, 2020 12:15 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Wow! I’m just going through this thread and I’m amazed.
It looks like the guy could build one from scratch!
How did the angle of the windshield get determined? Good catch by the way. _________________ Volkswagen!
(Compression 8.7:1) |
obus Samba Member
Joined: March 08, 2001 Posts: 11071 Location: just off Garden State Parkway Exit 81
Loren Samba Member
Posted: Fri Jan 01, 2021 1:30 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Jason has worked on other Ghias before and I believe this is a jig he made for another project. He got the dimensions from an undamaged Ghia. |
Posted: Sat Jan 02, 2021 5:38 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Doesn't the Bently have dimensions? I am pretty sure I saw a windshield jig (dealer build) in there. |
Peter D. Samba Member
Joined: February 25, 2004 Posts: 718 Location: Stamford, CT
Posted: Sat Jan 02, 2021 9:39 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Amazing work! _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
Loren Samba Member
Posted: Sat Feb 20, 2021 4:46 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Getting closer to the finish line. Jason wren has been finishing a few small details on the body and has started working on the pan too. The pan was actually in fairly good condition, but the sections behind the seats had some rust and were very thin. The rusty sections were cut out and new ones welded in.
First up was doing some more work on the windshield frame:
Next, the torsion bar hole area in the driver side fender had some rust and needed to be replaced. Jason made a patch panel from scratch and welded it in:
Finally, some images of the pan repair:
At this rate it should be ready for paint this spring or early summer! |
Posted: Sat Feb 20, 2021 8:35 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Nothing like the smell of fresh metal in the morning..... |
Braukuche Samba Member
Posted: Sat Feb 20, 2021 9:42 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Beautiful work. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Loren Samba Member
Posted: Sat Feb 27, 2021 4:38 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
The pan is done and is ready to bolt up to the body. Getting closer!
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Feb 27, 2021 4:43 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Awesome!! What a journey so far eh?? Looking good!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Loren Samba Member
Posted: Sun Mar 21, 2021 10:08 am Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
We are nearing the home stretch. Jason has fit the pan to the body and is starting to fit the convertible top mechanism before he finishes the windshield frame. Next month he will assemble the doors and make sure everything fits properly, finish installing the complete top mechanism and finish welding in the windshield frame. At the end of April the Ghia should be going home and some time it May it should be in the paint shop!
Posted: Sun Mar 21, 2021 3:38 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
SWEET |
Karmann Gheezer Samba Member
Posted: Sun Mar 21, 2021 5:50 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Amazing craftsmanship. _________________
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Sun Mar 21, 2021 7:04 pm Post subject: Re: June 58 Ghia cabriolet - Amazon Green restoration |
Such a beautiful shop. Amazing photos and work. |
