Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Sun May 24, 2020 12:00 pm Post subject: Solex 28 vfis |
Does anyone know if the solex 28 pci float is the same for a solex 28 vfis .. I'm looking to buy some solex 28 vfis but they are missing the floats and I know they sell new solex 28 pci floats and was wondering if I could use them on the solex 28 vfis ... |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sun May 24, 2020 10:49 pm Post subject: Re: Solex 28 vfis |
I know it doesn’t address your question, but I wanted to share my experience with 28vfis. In my 52 Beetle I built a mild sneaky hotrod 25hp look alike, 69mm Okrasa crank with 36hp pistons and heads.
On the dyno my NOS and freshly rebuilt 28vfis produced slightly less hp than the stock 26vfis. Both were jetted on the dyno. There are several variants of 28vfis, the particular one that I found did not have a larger Venturi than the 26vfis. Final note, the engine upgrades made my 26vfis a more driveable carb than it had been on the stock 25hp, probably due to the increased vacuum pulse. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Sun May 24, 2020 10:53 pm Post subject: Re: Solex 28 vfis |
I love any advise or information on folks experience..keep it coming I don't mind ..... |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Mon May 25, 2020 1:00 pm Post subject: Re: Solex 28 vfis |
Mr. OGPaint wrote: |
On the dyno my NOS and freshly rebuilt 28vfis produced slightly less hp than the stock 26vfis. Both were jetted on the dyno. There are several variants of 28vfis, the particular one that I found did not have a larger Venturi than the 26vfis. Final note, the engine upgrades made my 26vfis a more driveable carb than it had been on the stock 25hp, probably due to the increased vacuum pulse. |
I have plans for a similar build, what manifold did you use? |
