VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Mon May 25, 2020 6:55 pm Post subject: Stuck, seized, rusted radius rod... |
1990 2WD Westy
Working on the front suspension, replacing all bushings. I am unable to get the radius rods to move, on either side (where the radius rod itself connects with the lower control arm (LCA). I've had no problem unscrewing the nuts on the bushing side).
What I've done so far: wire-brushed the threaded portion at the end of the control arm, where it screws into the LCA. Several squirts of PB Blaster on several locations. Applied some heat (propane torch) on the rod itself, close the threaded portion. Can't heat it up a lot, the lower ball joint is right next door.
It just won't move.
My last bet is to get a 1 1/16" wrench, instead of the 27mm I have. The 27 mm has just a little bit of play, which prevents me from putting an extender on it, by fear of rounding the rod's bolt section.
Passenger side:
Driver side:
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Mon May 25, 2020 7:07 pm Post subject: Re: Stuck, seized, rusted radius rod... |
Remove the lower control arm from the frame so you can remove the radius rod bushings and slide a box end of the correct wrench size onto the base of the radius rod. Then you can brace the subassembly in a vise or other fixture and apply the required amount of leverage to the rod.
You have to remove the spring and shock to do this as well... _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
beach_creature Samba Member
Posted: Mon May 25, 2020 7:15 pm Post subject: Re: Stuck, seized, rusted radius rod... |
Once you remove the LCA, you can drive on top of it with the tire of a vehicle to sandwich it between the tire and ground. Then you can get good leverage on it. I’ve done this. It worked.
Edit: recommended only for the (late) cast LCA (which you have) not the stamped (early) LCA. _________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
VicVan Samba Member
Posted: Mon May 25, 2020 8:10 pm Post subject: Re: Stuck, seized, rusted radius rod... |
To clarify, all I'm trying to do is change the bushings. I don't need in itself to remove the rod.
If I unbolt the LCA from the frame, and remove the lower shock bolt, will it give me enough play to pull the rod back a couple of inches so I can replace the bushings?
@beach_creature, I like your technique! Since I don't have a proper vice yet, it might come in handy one day _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon May 25, 2020 8:27 pm Post subject: Re: Stuck, seized, rusted radius rod... |
If you unbolt the LCA, I think you’re gonna have to unbolt the UCA and deal with the spring. I remember someone having difficulty trying to bolt in the LCA with the spring in place.
You could try and keep at it with the PB blaster, applying frequently for a day or two. _________________ 84 Westy
1.9TD AAZ
Abscate Samba Member
Posted: Tue May 26, 2020 2:53 am Post subject: Re: Stuck, seized, rusted radius rod... |
Get some fire in that, minimum two minutes with propane on the threads.
You can touch the ball joint area and let it get too hot to touch without worrying about the rubber.each time you heat, the cycle is breaking up corrosion in the threads, so 5 cycles might be needed. Hot cold, then pb blaster or, best, ATF IN ACETONE 1:1 _________________ .ssS! |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Tue May 26, 2020 4:38 am Post subject: Re: Stuck, seized, rusted radius rod... |
VicVan wrote: |
@beach_creature, I like your technique! Since I don't have a proper vice yet, it might come in handy one day |
I removed the lower control arm assembly altogether with the radius rod attached to change my bushings- so yes. Obvs, I'd also removed the tie rod end, sway bar drop link, etc.
Hint: Don't figure out on the second one that you can remove the steering knuckle without removing the lower ball joint- in other words, the lower ball joint unbolts from the steering knuckle without you having to press the lower ball joint out. Do this on both. The lower control arm is very unwieldy with the steering knuckle attached- trust me. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
VicVan Samba Member
Posted: Tue May 26, 2020 6:57 am Post subject: Re: Stuck, seized, rusted radius rod... |
Thanks.
I'll try the easiest heat first, heat cycles and 1 1/16 wrench, and if that doesn't cut it, well I'll take everything apart! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Tue May 26, 2020 7:14 am Post subject: Re: Stuck, seized, rusted radius rod... |
If you're leaving the steering rack in place and remove the outer bushing, can't you pull the arm out of the hole by turning the wheel? I know there's a way to do this because I've replaced radius rod bushings alone when one blew out, but I just can't remember how I did it. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
VicVan Samba Member
Posted: Tue May 26, 2020 7:33 am Post subject: Re: Stuck, seized, rusted radius rod... |
Not sure. I did change the steering tie rod ends 2 years ago, so they shoudn't be too bad and I should be able to separate them. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Tue May 26, 2020 8:51 am Post subject: Re: Stuck, seized, rusted radius rod... |
An open end wrench on that radius rod is not going to cut it. You need the full engagement of the box end. Take the assembly apart. Avoid injury to yourself, and avoid rounding off the hex component of the radius rod. _________________ 1988 Vanagon
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Tue May 26, 2020 9:04 am Post subject: Re: Stuck, seized, rusted radius rod... |
I removed mine with an open-end wrench using a floor jack to apply force to the wrench. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue May 26, 2020 9:26 am Post subject: Re: Stuck, seized, rusted radius rod... |
Lucky... _________________ 1988 Vanagon
Posted: Tue May 26, 2020 9:31 am Post subject: Re: Stuck, seized, rusted radius rod... |
Sorry for the semi-hijack... just make sure it's a super high quality wrench if you try something like that and I'd even try to figure out how to set up a shield or something. I have a good friend who lost an eye when a good quality wrench broke from two people torquing on it with an extension. Better eye protection probably would've helped him, but there's a lot of other parts to one's body. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
VicVan Samba Member
Posted: Tue May 26, 2020 9:34 am Post subject: Re: Stuck, seized, rusted radius rod... |
SCM wrote: |
I removed mine with an open-end wrench using a floor jack to apply force to the wrench. |
I thought of it, but the 27mm wrench still has a tiny bit of play, enough to round off the nut if I put too much pressure on it I believe. I'll buy 1 1"16, which is a tad smaller, and see. But I won't push my luck on that method. The problem is that, if it doesn't work, my nut is rounded. Not good. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Tue May 26, 2020 9:39 am Post subject: Re: Stuck, seized, rusted radius rod... |
Here's a nice pic of the radius rod
I'll try adding a socket on the front end, to add some more torque on it. But it's so far out from the seized thread, I'm not sure it'll help.
I'll have a go this afternoon and keep you posted. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
RogerT Samba Member
Posted: Tue May 26, 2020 4:50 pm Post subject: Re: Stuck, seized, rusted radius rod... |
I rounded the flats on the hex at the base of the radius rod, as I could only get an open spanner on there. My solution was to remove the outer rubber Bush at the front, wind the nut back on and farther down, to let me get the other nut from the other radius rod on top. Then tightened them together using the ring end of the spanner on the inner nut, and a socket on the outer nut. Tightened them with all my strength (I’m only 11 stone) with a foot on one and a breaker bar on the other. May even have slipped an extension over the spanner. Then slip the spanner off, socket back on covering both nuts, and - in the end - it gave way with a mighty crack. The tightened nuts never moved, but the rod soaked up 1/8 of a turn in twist I reckon. |
VicVan Samba Member
Posted: Tue May 26, 2020 6:31 pm Post subject: Re: Stuck, seized, rusted radius rod... |
Roger, Thanks for the suggestion. I might give it a try too.
Something confuses me: I understand that you put the two nuts as far back as possible (i.e. closer to the lower control arm)? If so, how did you slide the ring end of the spanner? I'm not able, because the radius rod sticks out 2 or 3 inches out of the suframe mounting hole, towards the front of the van.
Or do you put both nuts at the front? That would make more sense. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
VicVan Samba Member
Posted: Thu May 28, 2020 4:31 pm Post subject: Re: Stuck, seized, rusted radius rod... |
Kinda stuck here.
I am not able to unscrew the radius rod from the lower control arm. I've tried different things mentioned above, without success.
Before I give up, there is one last thing I can try. What if I unbolt different things so I can have some play on the lower control arm, so I can move it backwards for the radius rod to clear the subframe mounting point, and then I remove the inner bushing.
I am thinking of removing:
- schock lower bolt
- lower control arm to frame bolt (I have to change the bushing anyway)
- Upper control arm to steering knuckle
1/ will the spring be a problem if I do this? I tried raising the LCA a bit, with a jack, in order to remove the shock lower bolt, all it did was lift the van. I am afraid I won't be able to compress the spring back in place.
2/ The real question is will removing all these bolts give me enough play in the LCA to pull it backwards 3 inches?
Thanks for your input. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu May 28, 2020 7:07 pm Post subject: Re: Stuck, seized, rusted radius rod... |
VicVan wrote: |
Kinda stuck here.
Let me pinch hit for Ricardo/Terry Kay.
What you need is a real oxy-acetylene torch. Make that sucker cherry red all the way through and it will spin off there nicely! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
