old_man Samba Member
Joined: June 19, 2018 Posts: 1414 Location: Newfoundland
Posted: Wed May 27, 2020 5:41 pm Post subject: I built a tow bar |
Well, I couldn't get a beetle one for cheap to modify so I built my own. I'm still learning to weld so I didn't have 100% confidence in my welds thus I probably over built it a bit.
These are the hook ups that came with the car.
This is my tow bar.
The noble stead. It handled quite nicely on the highway. The bar is perhaps a little low. Took it up to 110 kph (downhill) and there was no swaying or anything of the sort. Hills are....interesting.
Would I recommend someone else do this? No. I think the preferred method is where you build that tube bracket that allows you to use a regular beetle tow bar. Why? because beetle tow bars are usually more readily available to easier to borrow instead of this one off I made.
Hopefully this posts helps someone in the future. |
pedro sainz Samba Member
Posted: Wed May 27, 2020 7:36 pm Post subject: Re: I built a tow bar |
That's originally the one I wanted to do. I couldn't find a beetle tow bar for cheap. I also coudn't find anyone/anyway to bend that size tube without kinking it. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23535 Location: Kimball, Mi
Posted: Thu May 28, 2020 9:53 am Post subject: Re: I built a tow bar |
| old_man wrote: |
I used a Super beetle tow bar as a starting point, and added 24" of 2" tubing to the length, and welded it up. The SB plate, is bolted to the bottom of the beam with U bolts. Here's some pics.
I've used this set up a few times, and have even loaned it out twice. No issues with it at all.
Note: These pics were before I trimmed the U bolts down. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22681 Location: Escondido CA
Posted: Thu May 28, 2020 11:30 am Post subject: Re: I built a tow bar |
| old_man wrote: |
This is my tow bar.
That tow bar looks like it must weigh a ton. Probably needs 2 men and a boy just to pick it up. Definitely over kill. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Thu May 28, 2020 1:24 pm Post subject: Re: I built a tow bar |
| Bobnotch wrote: |
That tow bar looks like it must weigh a ton. Probably needs 2 men and a boy just to pick it up. Definitely over kill. |
Over kill - Yes, probably.
Weights a lot - Yes, but I can carry it myself.
Hook up? - I can do it myself. I just slide it under the front and then it 'levers' easily into place.
1/8" 2" square tube. Irony being that I chose this route over a tow dolly because of weight. Dollies are heavy..... |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13582 Location: Tejas!
Posted: Thu May 28, 2020 1:56 pm Post subject: Re: I built a tow bar |
| Erik G wrote: |
| after seeing a very nice beetle wrecked using a standard towbar, I don't think it's overkill at all. |
True that. _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Thu May 28, 2020 2:34 pm Post subject: Re: I built a tow bar |
| I there a link to this misfortune? I wish to learn. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4702 Location: Pasadena CA/DTLA soon China
Posted: Thu May 28, 2020 8:12 pm Post subject: Re: I built a tow bar |
Pretty awesome towbar Me Oldman!
Martin
Allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
