charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Wed May 27, 2020 9:15 pm Post subject: Up on a lift for 30 days; what should I do? |
got an 81 that ive got up on a rack for the next 30 days.
I had planned on sanding, de-rusting, powdercoating the rims and running the junk for a future wc conversion.
anything else i should be doing while its up? shift linkage, steering column?
ive got access to a powder coating room and a full metal shop- doing a services trade and theyre cool with helping with whatever.
thoughts? |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Thu May 28, 2020 12:23 am Post subject: Re: up on a lift for 30 days, what should i do? |
Depending on just how deep into the rabbit hole you want to go, there's all sorts of stuff, like the 2 or 3 rubber and cord couplers (I don't know how many there are in the different years) that like to slowly break apart.
And if you do it's probably best to use ones that have cordage internally, not the ones used in a ghia (I think) that do not.
Or the litany (depending on how religious you are) of bushings throughout like these in the steering column.
And there's the delrin tabs, or whatever it is, that's attached to the 2 ears on the front of the shifter ears that, if they've never been replaced, must surely (Shirley?) be worn enough to negatively effect shift action. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu May 28, 2020 3:54 am Post subject: Re: Up on a lift for 30 days; what should I do? |
Is it me, or did that area of the van take a hit? I’ve replaced the dampener rings under the van, but the one above after 35 plus years looks new. I’m wondering about it’s working angle.
To the poster, 30 days on a lift will go by quickly. Between ordering parts and discovering more parts as you go, don’t tackle too much that will leave the van immobile if you need to go.
Make your realistic project list and expect to only get a 1/3rd of it done. Good luck. _________________ ☮️ |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Thu May 28, 2020 5:04 am Post subject: Re: Up on a lift for 30 days; what should I do? |
MarkWard wrote: |
Make your realistic project list and expect to only get a 1/3rd of it done. Good luck. |
Wise words here, especially the immobile part. As someone who has to schedule time in my own garage for Westy work, unless you expect to be at it 24/7 that month will fly by before you know it. _________________ '87 Westy in Wolfram Grey Metallic |
Posted: Thu May 28, 2020 6:14 am Post subject: Re: Up on a lift for 30 days; what should I do? |
yeah, i dont want to take off more than necessary. I know the shop owner, so I could get back up if needed. He uses it about once a month.
So it sounds like im in the right direction with:
electrical cleanup
steering column bushings and such
shifting linkage bushings and such |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu May 28, 2020 7:36 am Post subject: Re: Up on a lift for 30 days; what should I do? |
Fuel lines ? (just in case) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Thu May 28, 2020 8:47 am Post subject: Re: Up on a lift for 30 days; what should I do? |
ill add fuel lines to my list. good call |
82westyrabbit Samba Member
Posted: Thu May 28, 2020 5:48 pm Post subject: Re: Up on a lift for 30 days; what should I do? |
With out knowing your van and assuming it doesn’t need a engine or transmission. I would replace all the suspension bushings if they haven’t been done before. I would also check the brakes and replace as necessary and maybe repack the wheel bearings and cv joints. Take a good look at the metal brake lines as well. That would take me a month if I was not working on it full time. Those are all jobs that are hard to do on the ground and looks really good if you paint or powder coat. You must have some ideas if you schedule this time? Let us know your plans. John |
Posted: Fri May 29, 2020 7:27 am Post subject: Re: Up on a lift for 30 days; what should I do? |
i just had the CV, all bushings, brake lines, and shocks replaced recently. Noticed that one of the rear rubber housings connecting the wheel shaft to the transaxle had split apart (though new), so ill replace that.
some of the housings are worn.. i.e. the brake line run to the back and the gas pedal line are exposed, so im gonna tube those and spray some of my motorcycle cable lube all over the place.
Nobody has done anything to the shifter or the steering column, there is some surface rust, so ill probably hit those.
its looking pretty good underneath from a rust perspective.
Someone at some point had sprayed a thick rubber underlayment beneath most the frame, so in the really common areas there is some rust, but its mostly frame/body is in great shape.
Ive been peeling off the rubber underlayment with a chisel (its all cracked and old) and then ill sand/wheel everything and por15, and then 3m rubberized undercoat to everything. |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Fri May 29, 2020 7:36 am Post subject: Re: Up on a lift for 30 days; what should I do? |
Reseal the fuel tank. Shifter bushings. Run a couple extra wires. They will be needed when you convert to WC and want coolant temp gauges and a CEL. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Fri May 29, 2020 2:27 pm Post subject: Re: Up on a lift for 30 days; what should I do? |
Rust would next on my list an fuel lines and tank problems. Most everything else can be accessed from the top. It sounds like you have done a lot of work already. John |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri May 29, 2020 5:40 pm Post subject: Re: Up on a lift for 30 days; what should I do? |
Plus - add a kill switch to the fuel pump ground while you can access the area easily. _________________ Jim Crowther
Vespa GTS 300 |
tjet Samba Member
