77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Wed Mar 30, 2022 4:56 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Aren't the signal lense covers side specific? _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Semper_Dad Samba Member
Posted: Wed Mar 30, 2022 5:49 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
77kafer wrote: |
Aren't the signal lense covers side specific? |
Yes, they are. There’s a “blinder” on the inboard side of each cover. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
mainstreetprod Samba Member
Joined: March 09, 2017 Posts: 313 Location: Tennessee
Posted: Wed Mar 30, 2022 7:32 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Beautiful color! Just a word of warning, in case your painter didn't seal off the gas filler before painting. If the inside is painted (as mine was), the fumes will eventually melt the paint and it will end up in the tank and filter, clogging up the works. I was able to take a rag and remove the residue in mine in a few seconds.
Semper_Dad wrote: |
So after waiting over a year for paint and body come to fruition, the deed gets done and the car comes home. Photos taken after two days of reassembly.
Posted: Wed Mar 30, 2022 7:37 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
mainstreetprod wrote: |
Beautiful color! Just a word of warning, in case your painter didn't seal off the gas filler before painting. If the inside is painted (as mine was), the fumes will eventually melt the paint and it will end up in the tank and filter, clogging up the works. I was able to take a rag and remove the residue in mine in a few seconds. |
Thanks, I'll check it out. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sun Apr 03, 2022 7:14 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
looking good, glad it is moving along. Will I see it in Louisville in Sept? |
Posted: Sun Apr 03, 2022 8:08 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Ron Domeck wrote: |
That's the plan. Hoping be be doing road trials by Memorial Day. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sun May 01, 2022 3:58 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Replaced almost every wire using The Thing Shop's wiring harnesses. The only one not replaced was the brake harness. If you like playing with puzzles then this is the route you want to go. Thing Shop provided no instructions so the main reference was a 2' x 3' blowup of the wiring diagram in the Technical Section. Found several "extra" wires in the front harness that was addressed earlier. Repurposed one of them for power to the electric windshield washer.
Spent an embarrassing amount of time troubleshooting the horn circuit only to discover a missing "S" wire that should go from the turn signal switch connector to the trunk. The Thing Shop's front harness now relocates the "T1b" connection from the luggage compartment to behind the instrument panel.
Almost completed the OEM part of the electrical. All the lights, wipers, and horn are working as they should. No giant puffs of smoke.
Now into the mods and upgrades portion of the electrical. Installing engine monitoring gauges such as Oil temp and pressure, CHT, Tach, and voltmeter. Added a 8ga hot wire directly off the battery along side the tunnel. That wire is protected by a 30a circuit breaker at the battery.
Deleted the useless swivel eye light which is supposed to illuminate the heater controls. Map light moved to new location under glove compartment and outfitted with red bulb. Making better use of my secondary fuse panel. It will be used to power up the fog lights, electric washer motor, gauges, and whatever additional accessories need power.
Also planning to tap the "SU" connection at the ignition switch (a la Modshine) for different options.
I reworked one of my older mods of removing the water valve and replaced it with a micro switch. This time I think I did a better job. The micro switch can't handle the current the electric wash pump needs very long so it will also get a relay to reduce the current going through it.
There are slots available on the wiper switch so If I can find a source for the male pins on the wiper's connection tray, I can reroute the wires through there and eliminate the GM connector. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Posted: Sun May 01, 2022 4:29 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Is that all? Kidding, great work. Glad it is coming along. Hope to see you guys in Louisville in Sept. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun May 01, 2022 5:39 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
What the heck Ron...
I was hoping to see him in Flat Rock in July!
Dad-
My SU wire triggers a standard Bosch relay which powers the radio, the glove box light, the gas heater switch, and a garage door transmitter.
All of that stuff only works with the key in the ignition switch.
Posted: Mon May 16, 2022 5:56 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Project Update:
Reassembly complete for the most part. Still waiting for engine to return for install. Waiting for front passenger seat cover (expected tomorrow) to arrive. Ordering Blazecut shortly.
Bikini Top installed. New top with frame and side curtains expected sometime later. Probably late summer.
Chrome OEM side mirrors are temporary. New ones will be "off-roadish" and flat black.
Wheels are just rattle can painted to match body cover. Powder coat next
Preliminary electrical checks completed. All lights, horn, wipers ect.. functioning. Any additional wire added was marine grade.
In addition to engine install, will need to bleed and adjust brakes.
Chrome Baby moon hubcap temporary. Will be modifying a donor cap into a license plate holder. Powder coat black of course.
Engine bay eagerly waiting. Secondary harness for engine monitoring; Tach, Oil temp and pressure, CHT.
How far we have come
Posted: Mon May 16, 2022 6:21 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
looking great. Very nice detail. |
Posted: Tue Jun 07, 2022 3:27 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Engine finally in!
Unfortunately, misplaced the accelerator cable tube. No road test today. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Tue Jun 07, 2022 4:15 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Looking very nice! Keep it going! |
Posted: Wed Jun 08, 2022 9:54 am Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Put a couple of gallons of gas in the tank. No apparent leaks. What could possibly happen now
Oh SNAP!
Luckily the cap was in unlock mode and could easily be removed. Not sure what I would of done if it had been in locked (spin) mode.
But on a happier note....
First startup in engine bay in 2 years.
germansupplyscott Samba Member
Posted: Wed Jun 08, 2022 7:57 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Engine sounds perfect! _________________ SL |
Posted: Wed Jun 08, 2022 8:15 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
....and this boys and girls is why you don't use cheap Harbor Fright impact drivers on 48 year old lug bolts.
I'm afraid the heat, humidity, my age (what was I thinking), and deadline getting the better of me. Took the rest of the afternoon off (with pay)
Won't do this again. Back to the breaker bar,
Learning by one's mistakes is good.
Learning by someone else's mistakes,...much better _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
KAmes Samba Member
Joined: February 16, 2014 Posts: 877 Location: Illinois
Posted: Wed Jun 08, 2022 8:45 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
I do feel that I have learned from your mistake. |
Posted: Thu Jun 09, 2022 12:33 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Used a 1/8 reverse twist(left twist) drill bit. Threaded shank popped right out. Didn’t even have to use an easy out. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
KAmes Samba Member
Posted: Thu Jun 09, 2022 2:51 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Glad it came out easy, that kind of thing can ruin an afternoon. I am surprised it broke in the first place. |
Posted: Thu Jun 09, 2022 4:17 pm Post subject: Re: Walkure Down! Phoenix Rising (Rebuild Thread) |
Cheap Harbor Fright tools aren’t calibrated all that well. I suppose it would be ok to use when removing wheel bolts but when tightening the threads in the bolt bottoms out and all the torque goes to the head. Should use a torque wrench for the final tightening anyway. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
