Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Tue Jun 02, 2020 8:36 am Post subject: Re: Thing Engine Fire, Walkure Down! |
Band style hose clamps provide even pressure 360* and with rolled edges they do not cut the hose.
Open barrel crimped terminals are what the factor used.
And as stated, a threaded brass fitting with a barbed end will prevent the hose from coming off.
https://www.ebay.com/itm/1-4-HOSE-BARB-X-1-16-MALE...1461491648
_________________ Glenn
Member #1009
#BlueSquare |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2765 Location: The World's Motor Capital
Posted: Tue Jun 02, 2020 9:41 am Post subject: Re: Thing Engine Fire, Walkure Down! |
FYI-
Joe at https://cycleterminal.com is a good guy with high quality terminals and connectors of all types. |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Tue Jun 02, 2020 2:01 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
This is indeed awful, but your alive and it looks very rebuild-able, after all it's a hobby, give you someTHING to do during lockdown.
I have Hagerty as well but have not needed to filed a claim yet. My question is doesn't the insurance adjuster
have to examine the remains before you clean/remove evidence? Any body experience this? _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Tue Jun 02, 2020 2:27 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Hot Rod Harp, I believe the above photos will pretty much suffice for evidence of the damage. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Semper_Dad Samba Member
Posted: Tue Jun 02, 2020 3:16 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Hot Rod Harp wrote: |
have to examine the remains before you clean/remove evidence? Any body experience this? |
Adjuster came by and made his assessment before I did anything except battery and fuel removal. Handed him a list of parts, part numbers, and prices from 2 different sources. List was probably 90% complete. I'm sure I forgot nickle dime stuff. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Wed Jun 03, 2020 9:46 am Post subject: Re: Thing Engine Fire, Walkure Down! |
Thanks for the reply Semper_Dad. I had a car fire in the late 70s in Fiat 124 Spyder on 42St and 2nd Ave in NYC during Friday afternoon rush hour, same thing carb fuel inlet pulled out, even tho I had a big fire extinguisher fuel was pouring out gravity fed. FDNY put out the fire and I rebuilt it. This past winter I sent my 34PICT Solex to Volkzbitz for throttle shaft bushings, a threaded in barbed inlet, and re-plating.
And I also use the band clamps that Glenn mentioned everywhere.
It's the small things that add up. Best wishes in putting it back together,
now you can make any changes you may have been entertaining. _________________ 74 Thing 1600DP
Ark Samba Member
Joined: August 23, 2006 Posts: 64 Location: Salt Lake City, UT
Posted: Wed Jun 03, 2020 2:40 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
mondshine wrote: |
FYI-
I've used the open barrel terminals from Joe before. They work great.
Hopefully this isn't too much of a thread hijack but do any of you have recommendations for individual pieces of replacement wiring? I have a few cracked wires in the engine compartment that are concerning but not enough to warrant a full harness replacement. I'd really just like to replace 2 or 3 with the stock, color-matched version |
Posted: Wed Jun 03, 2020 4:30 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Maybe ask Mike Basso at thingparts.com or 518 630 0173 _________________ 74 Thing 1600DP
Gene Kisner Samba Member
Joined: September 02, 2012 Posts: 80 Location: Fairmont, West Virginia
Posted: Wed Jun 03, 2020 9:11 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Had our fire three years ago returning home from KTE at Tipp City, Ohio. We drove 1000 miles that week to and from KTE along with sightseeing. Then twenty-three miles from home the pressed in factory carb fitting pulled out of the carb body. I had the fire out within fifteen seconds, thanks to a foam extinguisher. Do not ever even attempt to use a dry powder extinguisher, they are worthless and create a large mess. Always carry two foam extinguishers, one in the driver's door compartment and one in the passenger's door. When needed you do not need to lose time hunting for the thing. The foam extinguishers look like a can of wasp spray and are available at Walmart or Amazon. Absolutely no residual mess to clean up. Good for A B & C fires. I prefer the one with a trigger rather than a top push button. My 74-year-old fingers find them much easier to operate.
I love the picture in the classified ads with the extinguisher neatly mounted in the engine compartment left side on the air cleaner bracket. Wonder who is going to reach through the flames to grab it.
As for Haggerty, they were more than fair with me, they even left the claim open in case I encountered additional cost. Fortunately, I did not.
I have since installed a six-foot Blaze Cut on the top of the engine compartment over the engine. Flame propagation is up and out the side vents. Great peace of mind.
Posted: Thu Jun 04, 2020 6:04 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Still waiting for Hagerty to come up with a number. Guessing it will be somewhere near 6-7K.
In the meantime, taking things down to its basic element.
Confirmed that distributor, fuel pump, carburetor and generator are toast. Holding off on any purchases until I get some sort of number from Hagerty.
Got the engine ready to pull by disconnecting heater cables/hoses and the 2 lower engine bolts. BTW, where is the upper driver's side enging bolt? Can someone give me a landmark? The manual says it is accessed from the transmission side.
Passenger Upper engine bolt visible through fan shroud. Still looking for the driver's upper one.
Some changes being considered:
Change over to alternator
Changer over to electronic distributor
Color change on body - dark silver grey with black accents? _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Thu Jun 04, 2020 6:25 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
I usually remove the left rear tire, then you can see it through the wheel opening without getting under the car. Ratchet with an extension will do it. There is no loose nut in the engine compartment like the passenger side, it threads into a bung in the engine case. |
KAmes Samba Member
Posted: Thu Jun 04, 2020 6:32 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Semper_Dad wrote: |
Color change on body - dark silver grey with black accents? |
Personally, yes on all three. I especially like the silver grey idea. |
Posted: Thu Jun 04, 2020 7:28 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
On the driver's side upper engine bolt, it's right behind the clutch lever.
I switched to an M10 stud in that location, and use a JIS flange nut on that stud.
JIS nuts (for M10) have a 15mm hex (instead of 17mm), and access is much easier with a flex socket and a long extension.
Yes for alternator.
I use a CD ignition, so I prefer to trigger it with standard points.
For color, I always liked the factory colors Blizzard White and Avocado Green.
For non factory, for some reason, I am partial to the Chrysler Jeep color "Anvil", a non-metallic gray.
Check the body for any distortion caused by the weight of the spare tire mount.
Now would be a good time to reinforce the area, or delete the thing.
Good luck with the repair! |
Posted: Fri Jun 05, 2020 8:06 am Post subject: Re: Thing Engine Fire, Walkure Down! |
So Hagerty called and they want to total out the car. I insured it with an agreed value of 12.5K. Minus the salvage value, their offer is $11,309 and I keep the car. Only issue is it will be regarded a salvage vehicle. Is this a problem in Indiana? _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
KAmes Samba Member
Posted: Fri Jun 05, 2020 11:55 am Post subject: Re: Thing Engine Fire, Walkure Down! |
I don't know much about it, I don't think it's much of a problem here in Illinois, I know that doesn't really help. What I read in a 5 minute Google search looks like not too big a deal in Indiana. Regarding the future value of your car I suspect it matters less and less the older the car is. Here's another random thought, don't take it too seriously. Insurance companies are "thrifty" I always wondered what if one were to counter offer "just pay me $9000 and don't mess with my title". Not making a suggestion or anything, random thought. |
Glenn Mr. 010
Posted: Fri Jun 05, 2020 12:01 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Semper_Dad wrote: |
Only issue is it will be regarded a salvage vehicle. Is this a problem in Indiana? |
Do you plan on keeping it?
I would document EVERYTHING when you repair it. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jun 05, 2020 12:44 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
I'm a bit still on the fence about what to do. The way I look at it there are 3 options.
1) Accept the $11,300 and car. Restore it and deal with the "rebuilt" process. [Currently the preferred option]
2) Accept 12,500 and they come and pickup the car
3) Accept the $11,300 and car. Part out the car. They estimate the salvage value at $1,200. The fenders alone are worth that. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
KAmes Samba Member
Posted: Fri Jun 05, 2020 1:00 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Semper_Dad wrote: |
3) Accept the $11,300 and car. Part out the car. They estimate the salvage value at $1,200. The fenders alone are worth that. |
You're right about the value of the fenders etc. You could go ahead and keep the car and settle up with insurance,with the idea you can still think about weather to fix or not. One thing at a time. Having said that I'm personally glad to hear #1 is currently preferred. |
Posted: Fri Jun 05, 2020 1:33 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
Semper-
Nobody knows whether the car is worth saving better than you do.
Consider the condition of the car that was not effected by the fire; stuff like ball joints, brakes, steering, interior, etc.; the work you have already done that was not ruined, and whatever work you know it needed before the fire.
You probably have a good idea about what $12,500 buys in a Thing, and what a Thing at that price will need in parts and effort to get it where you want it.
After all, even a 30 grand Thing will need something.
It seems to me that the least expensive way to remain in the Thingdom (if that's what you want to do) would be to repair yours yourself.
If you spend 2/3 of your settlement on a top, side curtains and an engine, that leaves money to put toward body & paint.
Very sorry this happened to you; I hope whatever you decide works out for you. |
Posted: Fri Jun 05, 2020 2:15 pm Post subject: Re: Thing Engine Fire, Walkure Down! |
I think my first course of action will be to get the engine pulled and inspected. I don't think it ingested any water or burnt bits. I can turn the main pulley by hand. Worse case scenario, I'll need a rebuild from the cylinders up. Compression numbers were OK last time I checked. I figure at least $1,000 to replace all the burnt bits.
Alternator Conversion Kit - $200
New Carb (Volksbitz) - $300
Distributor - $50
Coil - $60
Fuel Pump - $50
Air Cleaner elbow - $30
Various hoses - $100
Tin repair/replace -??? _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
