VanPerson Samba Member
Posted: Tue Jun 02, 2020 10:02 am Post subject: Engine tin fasteners are rusted and stripped |
Howdy,
I've got an 88 vanagon 2.1 with some rusted out engine tin bolts. Surprise!
This is in regards to the tin that sits behind/over the muffler and cat. I was able to break all the bolts loose and pull the tin (yah), but probably half of them just spin freely now. I can't quite see up in there to tell if there were welded nuts that broke loose or what. It appears that I'd need to pull the bumper and the rear bumper body panel in order to access the area. Does anybody have any pointers on how best to address this issue more easily? Ie. are there some type of replacement clips or quick fix to save the day? I figure aside from pulling the rear portion of the van apart, I could drill the spinning bolts out and replace with a sheet metal type screw. Anyone have a better recipe than that? I figured this was certainly a popular topic, yet I was unable to find any leads when googling and searching here.
As always, if I've duped a previous post etc, just let me know. Thank you in advance!
Edit: maybe this would be a better fit on the "official lazy person" thread. Although, I'm not lazy, just seeking the advice of folks who have been there.
Edit: updated title from "Rusty engine tin hardware" to "Engine tin fasteners are rusted and stripped" per Vanagon Nut's suggestion.
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Tue Jun 02, 2020 10:47 pm Post subject: Re: Rusty engine tin hardware |
I think I know the fasteners you refer to and I'd posted to an existing thread or started a new one about them, but can't find it right now.
It might help to change your post title? At first glance, I assumed the topic was about something to do with rusty engine tin VS fasteners.
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Jun 03, 2020 8:10 am Post subject: Re: Engine tin fasteners are rusted and stripped |
Thanks Vanagon Nut, I've updated the title to use "fasteners" instead of "hardware" and reworded it to make more sense
I'll do some Googling re: 'fasteners' now and see what I come up with. Thx. |
Posted: Wed Jun 03, 2020 12:27 pm Post subject: Re: Rusty engine tin hardware |
Vanagon Nut wrote: |
It might help to change your post title? |
And speaking of titles, I used the part name as shown in the diagram I'd originally linked to but most would call it a "heat shield" and P. 13.32 in Bentley, it's shown as a "cover plate rear" LOL. Looking at that image again, I wonder if I showed the correct shield for a WBX. Anyhow.... Here's the thread I was thinking of:
https://www.thesamba.com/vw/forum/viewtopic.php?t=710834&highlight=heat+shield+nut+bolt
I didn't try to remove the spinning bolt/nut as I made a custom heat shield for a non stock engine and mounted it to different points on body.
Neil.
I think this diagram better shows the part in question but also appears to show the same fastener we're talking about:
VE7TBN |
The Carrot Samba Member
Joined: November 18, 2013 Posts: 173 Location: Ontario, Canada
Posted: Wed Jun 03, 2020 3:18 pm Post subject: Re: Engine tin fasteners are rusted and stripped |
They are riv nuts. _________________ 1990 Orly Blue Carat |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Wed Jun 03, 2020 4:06 pm Post subject: Re: Engine tin fasteners are rusted and stripped |
self tapping screws would be my fix _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Thu Jun 04, 2020 2:17 pm Post subject: Re: Engine tin fasteners are rusted and stripped |
Awesome! My side tin/shield use self tapping screws so maybe somebody has already been there done that. Maybe the rear uses riv nuts since it holds the weight of the coolant tank there.
I appreciate the help, as I didn't want to pull the bumper if there was some other strategy , and sounds like I have some acceptable options here.
Knowledge is power... and some level of laziness included
Thanks all, and thanks Vanagon Nut for digging up that other thread!
Mods, I can delete this or link to the source thread in my initial post, just lemme know if there is any preference. Thanks! |
Posted: Thu Jun 04, 2020 7:57 pm Post subject: Re: Engine tin fasteners are rusted and stripped |
If the any of the bolts are still in place you need to remove the head off the bolt somehow (Dremel or other small grinder ?) and then drive the nut upward to get it out of the way. I don't remember having to do any drilling on the old nuts to get them to push up through but maybe I have forgotten. Then install a riv-nut following directions. This would be a nice place to actually have a riv-nut tool but is doable without one.
Maybe practice installing a riv-nut first in an easier to access location so you will know what you are up against. |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Fri Jun 05, 2020 6:13 am Post subject: Re: Engine tin fasteners are rusted and stripped |
I just encountered this a couple weeks ago. Three of the rivnuts held but one was a spinner. I cut off the bolt head with a Dremel and then when I attempted to drill out the spinning rivnut it easily just pushed up and through the hole.
While replacement rivnut would be the best, my fix, as I did not want to wait for replacement rivnut hardware, was to finagle a small bolt through one of the vent opening holes and drop it down through the former rivnut hole.
When I reinstalled the tin, I was able to keep the bolt from spinning with fingers while I threaded on a nut, and then gave it a mild burst from a 12v impact driver to snug up the nut. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Fri Jun 05, 2020 7:32 am Post subject: Re: Engine tin fasteners are rusted and stripped |
Wildthings, I purchased some pop-top struts last year from Gowesty that came with a little riv-nut installer tool made of a bolt and a couple nuts/washers. It worked great. I'll see if I can dig that up and take a similar approach using the smaller hardware for these specific fasteners. I hear you though, might be a good place to have the "right tool for the job" instead of resorting to the MacGyver toolbox.
Teej, I knew there had to be others like me Living in the PNW, almost every vanagon project involves handling rusty hardware. This happened to be an engine swap, and the last thing I wanted to do was button this up half-assededly. Dremel, drill, riv-nut sounds like a winner. I did get 3 of the 4 to tighten back up actually, but that was just so I could complete the broader project. I'll get some of those buslab riv-nuts in the mail, so this time next week it ought to be all fixed up
Thanks again everyone. |
